Old Aug 16, 2010, 12:12 PM
cfe7 is offline
Find More Posts by cfe7
Failureisalwaysanoption
cfe7's Avatar
Norway
Joined Nov 2006
Anyone tried some kind of a catapult to launch this bird? I don't have access to launch capable club members every day. Could be nice to have some device to launch myself.
cfe7 is offline Find More Posts by cfe7
Old Aug 16, 2010, 12:15 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I'm also interested in any design/plans for a bungee launch.
Ohmic is offline Find More Posts by Ohmic
Old Aug 18, 2010, 03:37 PM
petranf is offline
Find More Posts by petranf
petranf's Avatar
Greece
Joined Jun 2007
All you need is plastic plumb pipe and fittings. You will find a couple of threads about catapult launch using search engine. Just to get an idea...
petranf is offline Find More Posts by petranf
Old Aug 21, 2010, 10:14 AM
Ohmic is offline
USA
Joined Jan 2002
I see the manual recommends MULTIPLEX Nano Pro MG digi4 servos, but these don't appear to be available in the USA. Anyone know what the best equivalent HiTec, JR, or Futaba would be?
Old Aug 21, 2010, 10:39 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Hitec HS-5065MG digital
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Aug 21, 2010, 10:59 AM
cfe7 is offline
cfe7's Avatar
Norway
Joined Nov 2006
I have put Futaba S3150 in my FJU. They fit almost 100% in the slots in the wings, and work perfectly at high speed
Old Aug 21, 2010, 11:05 AM
Ohmic is offline
USA
Joined Jan 2002
Thanks guys. I'll have a look at both.
Old Aug 21, 2010, 12:07 PM
jeeeeeeright is offline
Find More Posts by jeeeeeeright
Seaplane submariner
Norway
Joined Sep 2007
Smoked my HET2w-25 today when trying to push it beyond 120amps on 6s...
Has anyone tried to mount a 36mm diameter inrunner in the Ultra?
jeeeeeeright is offline Find More Posts by jeeeeeeright
Old Aug 21, 2010, 12:14 PM
petranf is offline
petranf's Avatar
Greece
Joined Jun 2007
You guys have the luxury of low temperatures.Check this out:
funjet on stereoids by thunb numb
http://www.rcgroups.com/forums/showthread.php?t=744411
Old Aug 21, 2010, 12:20 PM
Seaplane submariner
Norway
Joined Sep 2007
Mine were faster until it left the elevons behind on i full-speed pass. We radared it at 167mph on 6s1p220045c lipo, CC Ice 160amp esc and the HET2w25.
Old Aug 21, 2010, 12:38 PM
petranf is offline
petranf's Avatar
Greece
Joined Jun 2007
God mercy. Why guys you dont install hinges at the elevons with this speed. I was almost killed by this faillure by another guy. Now you know.
The 154mph from the thread i gave you belongs to a guy using a turnigy motor. The fj with the 36mm motor that thumb numb is building, has not flown yet. Test flights are expected this weekend.
Old Aug 21, 2010, 12:41 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Unless you just want to build something, all you need is a short length of tubing or bungee cord, a stake and a suitable hook on your model. I bungee launch an unpowered Multiplex Twinjet and other models for "slope on a rope" flights, with sections of tubing from an old high start.
DT56 is offline Find More Posts by DT56
Old Aug 21, 2010, 01:37 PM
Ben D Wing is offline
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
What did you expect? It's only rated at 50A for max efficiency.
http://www.wemotec.com/shop/product_...ess-Motor.html
Ben D Wing is offline Find More Posts by Ben D Wing
Old Aug 21, 2010, 06:26 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
jeeeeeeright,
I would be worried with 100A or close to it when after max power out of that nice HET motor.......but you put 120A in that motor, especially given this airframe's pisssss poor cooling airflow for motors!!!!!
I'm sorry for your loss.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Aug 21, 2010, 11:38 PM
Seaplane submariner
Norway
Joined Sep 2007
Originally Posted by GryphonRCU View Post
jeeeeeeright,
Gryphon
I saved the plane. Motor just lost power/magnetism due to heat. Oh and the solder on the plugs melted(!).
I knew it was just a question of time before it could not stand up to the increasing abuse anymore, but as I have a identical replacement motor (with a bent shaft from a unfortunate landing - just need to swap the shafts now) I wanted to see how far it would go.
I just upgraded from the standard FJ to the ultra, and I'm wondering if I should order a cheapo hobbyking 36mm inrunner just to test it. If all is OK I can always exchange it with a better one...
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
