Old Aug 05, 2010, 08:57 AM
Ben D Wing is online now
Find More Posts by Ben D Wing
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
I love that launch technique!
Ben D Wing is online now Find More Posts by Ben D Wing
Old Aug 05, 2010, 09:16 AM
petranf is offline
Find More Posts by petranf
petranf's Avatar
Greece
Joined Jun 2007
lol. Fellows in the field go nuts.
This is applied when you have a lot more thrust than weight.
My thrust is 1800 grams and weight 1050.
So Thrust/weight=1.67.....and could easily be 1.73
I wonder what is the above ratio record at an rc airplane?
petranf is offline Find More Posts by petranf
Old Aug 05, 2010, 09:18 AM
jimmy34256 is online now
Find More Posts by jimmy34256
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
What motor comes with the high performance power pack (m993245)???
jimmy34256 is online now Find More Posts by jimmy34256
Old Aug 05, 2010, 09:46 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
The Himax C 3514-2980 outrunner.
http://www.rcgroups.com/forums/showp...ostcount=14210
Old Aug 05, 2010, 09:52 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I haven't had a go-fast plane since I totaled my Stryker a while back and am now seriously looking at the new FJ Ultra as a replacement. I miss the Stryker, but also want to go faster!
I still have the two motors I purchased for the Stryker:
1) Medusa MR-028-040-2200 which is 28mm x 40mm 2200Kv
2) Mega ACn 16/25/2
I used the Medusa in the Stryker and it worked well. I never got to try the Mega.
Just wondering how each of these motors would do in the FJ Ultra or whether there is something better worth considering for the FJ Ultra? I'm interested in achieving 125-150mph. Also, how would a CC Ice 100 do? I had used a Phoenix 80 with the Medusa on the Stryker and was running 3S. I'm thinking about 4s or more for the FJ Ultra.
Ohmic is offline Find More Posts by Ohmic
Old Aug 05, 2010, 09:59 AM
Ohmic is offline
USA
Joined Jan 2002
Originally Posted by petranf View Post
And a quick pass with the wind behind...No cheat dive
http://www.youtube.com/watch?v=txPOJTw6Bz0
What a beautiful sound! What is the FJ Ultra in that video running?
Old Aug 05, 2010, 10:03 AM
petranf is offline
petranf's Avatar
Greece
Joined Jun 2007
I would recommend:
-inrunner motor
-medusa is out of business, so HET1w30, ARC 28.47.1.5 or 2
-5cell 2500-3000mah 35c setup. You could start with 4cells but 5cells...oof man this is the best choice. For me 6cells is an too much (hard landings, tough handlaunces)
my setup is:
ARC 28-47-1.5
5cell 2500Mah bionik battery
80 amps ESC, considering to upgrade to 100ICE
5.2x5.2 graupner
85 amps max
1050 grams total load
220 km/h top speed (no cheating)
see my vids at the previous page to get an idea
regards
Old Aug 05, 2010, 10:13 AM
Destructive Tester
jimmy34256's Avatar
Tampa, FL
Joined Apr 2008
Thanks, trying to find a setup for the Ultra FJ that can utilize a set of 4S 3200 batts and a Phoenix 80 ESC which I already own.
Old Aug 05, 2010, 11:27 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
You can easily increase this figure by using a bigger diameter/ smaller pitch prop. Better acceleration, but less speed.
F3P (Indoor Aerobatics) models set-up for Freestyle can have thrust-to-weight ratios of 2:1 to 4:1.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Aug 05, 2010, 11:32 AM
Ohmic is offline
USA
Joined Jan 2002
I would recommend:
-inrunner motor
my setup is:
ARC 28-47-1.5
5.2x5.2 graupner
85 amps max
regards
Thanks, petranf. I only mentioned the Medusa because I have one already. I will look into the HET and ARC models you mentioned.
Old Aug 05, 2010, 01:18 PM
petranf is offline
petranf's Avatar
Greece
Joined Jun 2007
Originally Posted by PeteB View Post
Thanks, petranf. I only mentioned the Medusa because I have one already. .
aahh. You can try it but it will not give what u want. I used this size for the microjet (28.40.2800 i think)
Old Aug 05, 2010, 03:10 PM
Ohmic is offline
USA
Joined Jan 2002
Will there be a big difference between the ARC 28.47.1.5 or 2?
I'd like to understand what the differences are.
Old Aug 05, 2010, 04:24 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
PeteB,
I hope you are not going to step down in quality and power from MEGA 16/25/2 and run an ARC 28-47-X….and spend extra money doing it.
Maybe there are misunderstandings going on here by me, you, or others.
Be 100% clear on this, the MEGA will handle more power and stay together.
The KV is different so you will just run different size prop to fly at same speed as ARC.....or increase prop size and leave the ARC in your dust.
While ARC is falling behind it will either sizzle and let out smoke or puke its guts out of the end cap coming lose or bend its shaft much easier in comparison during landing.
Want max out of your MEGA; run it on 5S
Your 100A ESC is perfect match in every way for your motor.
________________________
Also NEU bought out part of Medusa and can do service/repair for your Medusa motor in future.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Last edited by GryphonRCU; Aug 05, 2010 at 09:53 PM. Reason: Edited last line for clarification.
Old Aug 06, 2010, 03:59 AM
petranf is offline
petranf's Avatar
Greece
Joined Jun 2007
Originally Posted by GryphonRCU View Post
PeteB,
Gryphonrcu,
I am a recent owner of arc and i am very pleased so far. I posted my setup and uploaded a vid with the performance. You claim that mega is supirior and of course i can not doupht about this cause i havent used mega. Could you infom us about the max watt it can handle and which prop you use with mega 16-25-2 ? Any video prooving performance?I have seen the motor properties and manufacturer suggests max amps 35 for 15 secs.
http://www.espritmodel.com/index.asp...OD&ProdID=3198
p.s what the numbers 16 and 25 represent?
Old Aug 06, 2010, 07:09 AM
Ben D Wing's Avatar
The Peak District
Joined Dec 2006
I've got a couple of Mega 16/15/3 motors and they have an advised max of 30A. I regularly run mine at 40-48A with no ill effects, but they are very well cooled. I don't doubt Gryphon's claims as they really are great motors.
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
