Old Mar 19, 2011, 06:59 PM
rimripper is offline
Find More Posts by rimripper
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
Maybe do a few low amp discharges,break it in.
rimripper is offline Find More Posts by rimripper
Old Mar 19, 2011, 11:23 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by FLAME747 View Post
You tell me buddy, I'm not making this stuff up, here is the direct link to Tower
http://www3.towerhobbies.com/cgi-bin...&I=LXZWK9&P=ML
In the description is says "This is a Brushless Power Pack for the Funjet Ultra Kit, MPUA2145.
Nobody has accused you "making things up".
Contrary to the description, the picture in above link clearly shows a MPX/Graupner Speed prop.
As mentioned in this thread before, the Graupner Speed prop 6x5.5" performs much better than the APC 6x5.5" on the FJU. Normally MPX uses APC props, but there is a good reason they made an excemption here.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Mar 19, 2011, 11:24 PM
Gear Swinger is online now
Find More Posts by Gear Swinger
Foam Bender
Gear Swinger's Avatar
United States, CA, Thousand Oaks
Joined Jan 2010
Maybe it's a typo and instead of APC it should say MPX/Graupner 6x5.5 Speed prop
I have wondered the same thing. They mention APC twice in "Tech" notes. That is why I shyed away from their offering a month ago and the part numbers weren't making sense.
Gear Swinger is online now Find More Posts by Gear Swinger
Old Mar 19, 2011, 11:58 PM
Foam Bender
Joined Jan 2010
It was pretty good day. Went to the RCx expo and still had time to put in two flights on the plane before the sun set.
I had a chance to play around with a doppler program during the week. That can be a little frustrating to figure out and depending on where you plot, can offer different readings. So, I am working on trying to get some consistent readings with the radar gun.
We experimented with adding some foil to the bottom of the plane to aid reflectivity. Fastest recorded today was 122 mph on stock motor and prop and 2250mah 3s pack. I need to go out in the field and stand by the gunner instead of 50 feet away, so I can line up better and get consisitency.
GS
Old Mar 20, 2011, 01:56 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Got to test the speed on my Funjet today. Unfortunately, I was having some issues that I later resolved, which kept me from WOT for more than 4 to 5 seconds. So, I could have built up a few more MPH's.
Two radar guns, 16mph winds, down wind runs, up wind runs.......... several passes, little math
My setup is good for a solid 130mph.
I hit 146mph out of a dive, down wind.
Trying to figure out my new Video camera, but I got some of the passes.
I will post them tomorrow.
Now it's time for new batteries and more prop!!
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Mar 20, 2011, 10:33 AM
Foam Bender
Joined Jan 2010
Great to hear your combo is putting out some good numbers for you and has room for more.
GS
Old Mar 20, 2011, 10:47 AM
wise guy is offline
Find More Posts by wise guy
"Where are the shovels?"
wise guy's Avatar
Joined Apr 2010
Jurgen, how many of your buddies have done turbines with their FJ's?
wise guy is offline Find More Posts by wise guy
Old Mar 20, 2011, 02:18 PM
Joined Sep 2000
There are quite a few FJU with turbines in Germany, but in our club, it is just one guy.
Jürgen
Old Mar 20, 2011, 02:27 PM
Joined Sep 2000
Normal FJ with FJU drive set ...
Seen today at my local flying field, this combination worked surprisingly well, although 84A max. is rather high for the battery used:
Old Mar 20, 2011, 04:04 PM
ccoxconejo is offline
Find More Posts by ccoxconejo
Joined Aug 2007
[QUOTE=Gear Swinger; Fastest recorded today was 122 mph on stock motor and prop and 2250mah 3s pack. I need to go out in the field and stand by the gunner instead of 50 feet away, so I can line up better and get consisitency.
GS[/QUOTE]
122 mph stock? - Do you have any video?
ccoxconejo is offline Find More Posts by ccoxconejo
Old Mar 20, 2011, 08:20 PM
Foam Bender
Joined Jan 2010
Stock FJU 122mph pass 3-19-2011 (0 min 11 sec)
Last edited by Gear Swinger; Mar 20, 2011 at 09:40 PM. Reason: learning how to use a Mac -added freeze frame at end of video
Old Mar 21, 2011, 02:59 PM
novemberalpha is offline
Find More Posts by novemberalpha
India
Joined Oct 2010
I liked the idea of attaching the motor in reverse will have to try rigging simillar prop mounting option by drilling & tapping the fan unit of my motor but would have preferd to mount it internally by installing the motor mount from behind. Thanks for the inspiration will try mounting my scorpion hk 3026-1900kv setup this way.ordering my 2nd funjet ultra for it.
novemberalpha is offline Find More Posts by novemberalpha
Old Mar 21, 2011, 06:19 PM
xyz-2-xyz is offline
Find More Posts by xyz-2-xyz
California
Joined Mar 2008
my opinion of this prop ordeal is the apc 6 5.5 is the way to go atleast on my plane graumpner just dosent put out what i get w/ the apc
xyz-2-xyz is offline Find More Posts by xyz-2-xyz
Old Mar 21, 2011, 07:25 PM
rimripper's Avatar
Alberta,Canada
Joined Nov 2009
What power system are you running,it can make the difference if your really looking to dial the power in.
Old Mar 22, 2011, 09:34 PM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Pics of my MFJ
I know this is not the FJU, but I couldn't find a thread for the MFJ that was't closed. So here are some pictures of my MFJ with DonsRC 3000kv motor running on 2200 20c 3s. It is very stable, and lots of fun, as its name implies. It is not supersonic, but is still plenty fast for me. The vertical climbs are pretty impressive also. I am running an EMP 4.5x4.5 prop. It was pretty difficult to get pictures of it screaming by. My buddy has a super high tech camera though and he always gets some great shots. If anyone has a link for an active thread on the MFJ, I would appreciate it. If on the other hand, this thread is MFJ friendly, then thats cool too.
Cub
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: GWS Funny Park
Discussion Funjet Ultra, more fast more fun.... tbmg1 FPV Talk 34 Jul 28, 2010 08:36 AM
Discussion Muliplex EasyStar WBFlyer FPV Talk 9 Mar 10, 2010 03:09 PM
Sold muliplex ASW 27 NIB bushpilotx1 Aircraft - Sailplanes (FS/W) 7 Aug 31, 2009 05:41 PM
Question Muliplex Alpha Junior Radio Instalation Allan Glover Sailplane Talk 3 Apr 09, 2004 01:37 AM
Muliplex MultiCharger 4010DC - is mine faulty ? borgs Batteries and Chargers 0 Jul 12, 2003 07:01 AM
