Old Mar 15, 2010, 12:56 PM
lucidmonkey is offline
Find More Posts by lucidmonkey
CurrentBuild: Boulogne Etaples
lucidmonkey's Avatar
Canada, ON, Hornings Mills
Joined Dec 2008
Question
DUAL RC switch from robotmarketplace
Hoping for some guidance from all you master builders and electronics wizards
As i am a complete newbie at this and not very good with a soldering iron i saw this product a while back and thought it might save me some grief when putting lights in my Nordkap.
http://www.robotmarketplace.com/products/0-DGSW5.html
if i understand it i could plug one end of this doohickey into my receiver and run some wires from the other end and magically turn my lights on and off from my Dx5e.
Also, it says "for handling loads up to 2.5A per switch" is that plenty for a few leds?
ideally i would like to have the nav and mast lights on one switch (6 leds), the deck lights on another (2 leds) and maybe have interior lights (2 or 3 leds) and one spot light on another pair of switches so if i had 2 of these things i would still have a spare channel as i am using one for throttle and one for rudder right?
any thoughts or suggestions welcome. should i group them differently? should i not bother with some of them for some reason?
thanks
christophe
lucidmonkey is offline Find More Posts by lucidmonkey
Old Mar 15, 2010, 02:07 PM
Shaun Hendricks is offline
Find More Posts by Shaun Hendricks
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
LED's have very low amp draw (milliamps is normal) so 2.5A should be plenty. This appears to be just a switch so you'll need to figure out your power supply. It will not be drawing power from the BEC on the receiver (beyond what is needed to operate the 'switch'). So figure on maxing out at 6v, but most LED's are in the 3v range so you should be good there.
I'd just hook it to a standard AA battery pack and run with it.
The switch appears to work on stick position but I don't know if that mid off, down on 1, up on 1 or bottom off, mid on 1, top on 1 & 2 or just on 2. It's not very specific on that.
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Mar 15, 2010, 02:52 PM
more coffee is offline
Find More Posts by more coffee
Cheif Bottlewasher
more coffee's Avatar
Canada, NS, Sydney Mines
Joined Sep 2005
I bought two of these ..still waiting for them to arrive ..but i like it because i can use my source batteries to power my lights or pumps..pumps are 12volt so ..the reciever is usless and this is cheaper than a switch and a servo .. the price was right ..
http://www.hobbycity.com/hobbycity/s...idProduct=8833
more coffee is offline Find More Posts by more coffee
Old Mar 15, 2010, 05:53 PM
Joined Dec 2008
Shaun, thanks for the tip - i had assumed/hoped it got power through the BEC.
More Coffee, thanks for the link - that looks like exactly what i need (and what i thought the other one was ) unless i hear more feedback from others i will probably be ordering two of them for myself as well.
Old Mar 15, 2010, 11:55 PM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Its perfect for what you need,
Tx Stick Position
Switch 1 Switch 2
0% - 25% < 1.3ms OFF OFF
25% - 50% 1.3ms – 1.5ms ON OFF
50% - 75% 1.5ms – 1.7ms OFF ON
75% - 100% > 1.7ms ON ON
you can run the load direct off the receiver battery or use a external supply from 0-16 volts
Nick
nick_75au is offline Find More Posts by nick_75au
Old Mar 16, 2010, 03:55 PM
steamboatmodel is offline
Find More Posts by steamboatmodel
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
Both of these look to be only on when the stick is in a specific location, nether toggle on/off. MCD had a two switch unit (Add a Switch) that you could set to toggle on/off with stick position.
Regards,
Gerald.
steamboatmodel is offline Find More Posts by steamboatmodel
Old Mar 16, 2010, 05:08 PM
Cheif Bottlewasher
Joined Sep 2005
Using my Hitec Aggressor ..the brake channel simply throes a servo over and it dosent return untill you hit the button again ..
Im kinda hoping this switch will re-act in the same manner ..It will be running the pump so a second tap to shut it down isnt a big deal ..
But for lights a simple tap and on ..with a second tap being off would also do for the lights ..minus a pump..
Old Mar 27, 2010, 07:00 PM
Joined Dec 2008
thanks for the help guys, i have ordered 2 of these "Dual 2.5A RC Switches" as they are not too expensive ($14.49 US) - see how i go - will let you know
Old Mar 27, 2010, 07:05 PM
Cheif Bottlewasher
Joined Sep 2005
I got 2 comming also ..should be here next week ..I'll give you a heads up
Old Mar 28, 2010, 07:00 AM
Joined Dec 2008
Hey More Coffee, that's great - I'm looking forward to some close up photos of your set up with them so i know what the ?? to do once i get mine
Old Mar 28, 2010, 10:57 PM
Pensacola Tug is offline
Find More Posts by Pensacola Tug
Joined Mar 2010
Would it not be simple or to take a servile with a control arm and that is a mechanism from two ballpoint pens. Set them up so that the full travel one-way would push one pen mechanism poll travel the other way would activate the other pen mechanism. Then by putting microstructure's at the end of the mechanism you have your switches. Click on click off.
Pensacola Tug is offline Find More Posts by Pensacola Tug
Old Mar 29, 2010, 07:18 AM
Cheif Bottlewasher
Joined Sep 2005
Yes ..that could be done ..but ..its not as cheap ,compact, or simple,not to mention time to fabricate ..The switch is just one piece ..and under 10 bucks..
Old Mar 29, 2010, 08:23 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
This is a system I have used in 70-100 models.
Servo with a switch mounted on it. lately I have been using cheap micro servos and just gluing micro switches to them. I just made a systen for a customers tug. Using 4 channels I gave him 8 controls.
Total cost per unit is $ 11.00, $ 8.00 servo 2x 1.49 micro switch.
I have this in 64 of my 103 boats.
www.jsgill.net
GILL RC is offline Find More Posts by GILL RC
Old Mar 29, 2010, 04:06 PM
Cheif Bottlewasher
Joined Sep 2005
Thats way cool ..well thought out ..
You ought to post that in the "wiring diagram's" sticky ..
I cant get servo's and micro switches shipped to me for that price ....
I was better off just getting the two switches..
Old Apr 07, 2010, 10:20 PM
Joined Dec 2008
so my switches arrived today - took a while, i was starting to wonder if i should call the shop.
here is a link to photos and what i am planning on using them for:
http://www.rcgroups.com/forums/attac...mentid=3169796
i contacted tsenecal earlier as well for more info as i had noticed in my searches on LEDs here that he is using the same switches in one of his setups.
Discussion XP9303 Dual Rate on 3 Position Switch norstaroption Radios 1 Jan 27, 2010 06:18 PM
Discussion 6xa Dual Rate Switch rawkdw Radios 2 Sep 08, 2009 04:05 PM
Discussion Creating a Better and more reliable Power Switch for our RC receiver switch. lazy-b DIY Electronics 15 Aug 12, 2008 02:06 AM
Discussion How to build a cheap RC switch from junkbox parts Pete K DIY Electronics 0 Feb 04, 2006 11:07 AM
4 channel power RC-SWITCH from one transimiter channel prikupets DIY Electronics 1 Nov 02, 2005 08:47 AM
