Old Mar 14, 2010, 10:17 PM
rp181 is offline
Find More Posts by rp181
Joined Mar 2010
Question
Need help for quadrocopter setup for autonomous flight
Hello,
I am planning on making a tricopter to use in experiments for flight control. I am new to these kind of things, my past experience is in high power electronics (http://rp181.fortscribe.com). I am looking for some help.
The design needs to be able to support payloads, weight is undetermined. It will probably carry 2 webcams, a 3" square PC board, some servos, laser rangefinders and a inertial measurement unit.
I want to do this in a compact footprint, so spacing between blades will be minimal (what are negative effects of this? balance?).
3 of these motors looks good:
http://www.hobbyking.com/hobbyking/s...0_750Kv_/_600W
Is this a good motor in terms of power,speed, etc..? What props should I use? ESC's?
The frame will be self built, aluminum or carbon fiber, or nylon.
rp181 is offline Find More Posts by rp181
Old Mar 15, 2010, 01:20 AM
capt is offline
Find More Posts by capt
capt's Avatar
Nevada, USA
Joined Sep 2007
It is hard to guess without a weight estimate but that motor seems way to big, here is a good Tri thread that is very active.
http://www.rcgroups.com/forums/showthread.php?t=1142429
capt is offline Find More Posts by capt
Old Mar 15, 2010, 07:13 AM
rp181 is offline
Joined Mar 2010
Is their a problem using larger motors/ESC/batteries? Weight is not a problem.
Does a 14x6 prop mean a 14" diameter prop?
Old Mar 15, 2010, 09:30 AM
capt is offline
capt's Avatar
Nevada, USA
Joined Sep 2007
14" is the diameter of the prop.
I think that size of a Tri is uncharted waters around here, should work fine in theory.
Old Mar 15, 2010, 08:48 PM
rp181 is offline
Joined Mar 2010
I have a new list:
4x http://www.hobbycity.com/hobbycity/s...idProduct=5686 ($12.74)
1x http://www.hobbycity.com/hobbycity/s...ack__(5pcs/bag) ($2.99)
4x http://www.hobbycity.com/hobbycity/s...idProduct=4312 ($11.90)
1x http://www.hobbycity.com/hobbycity/s...idProduct=2169 ($6.95)
Will these work together? What battery should I use for ~30 min. of flight? How about gyros? controller will be self built.
Old Mar 16, 2010, 04:07 PM
rp181 is offline
Joined Mar 2010
How close can the rotors be spaced?
Old Mar 17, 2010, 09:38 PM
Gwarden-98 is offline
Find More Posts by Gwarden-98
Gwarden-98's Avatar
New Mexico, USA
Joined Mar 2010
I'm in the same spot as you (just starting into my first tricopter build) so I'll forgo any advice beyond seconding what the Capt said-
study this thread
Gwarden-98 is offline Find More Posts by Gwarden-98
Discussion CC Ice 75A and HK-3026-1600kV need help for setup Radomer Castle Creations 6 Aug 07, 2011 02:43 AM
Discussion Real Flight G5 Exponential setup Help ! splitpilot Simulators 9 Dec 31, 2009 11:21 PM
Discussion My new Axe 400, I love it! Need help with transmiter setup. airbagit13 Electric Heli Talk 0 Dec 26, 2009 07:22 PM
Discussion Looking for info on autonomous flight Canada Goose Aerial Photography 6 Mar 19, 2009 04:49 PM
Discussion First flight and lost my batt - need help for new setup Gameness Flying Wings 2 Dec 25, 2005 12:02 PM
