Old Mar 14, 2010, 03:56 PM
wolfflyer is offline
Find More Posts by wolfflyer
WOODLAND WA.
Joined Mar 2010
exceed fs-ct6 set up for arf sky trainer
Hey guys new to plane flying , I am setting up sky trainer 182,from nitro planes with the exceed fs-ct6a reciever and radio..I finnally got driver downloaded on the laptop that has windows seven, radio opererates totally backwards 180 from what it should be for plane,computer does not talk to radio so I can reverse it???? I need to get com 4 on serial setting but it only gives me com 3 option, can anyone help with this??????
wolfflyer is offline Find More Posts by wolfflyer
Old Mar 14, 2010, 04:30 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
you should be able to fix the "computer does not talk to the radio" problem. I assume you are using windows - what version are you using? You probably don't have the USB driver. Go into the control panel and find the system/hardware/dev manager section and look for com ports. There should be a com to USB bridge (make sure you turn on the radio and plug in the programming cable). If you don't set it, look for the silicon labs 210x driver on your CD or find it on the web. Install it.
More detail? It's discussed here http://www.rcgroups.com/forums/showthread.php?t=967207 (the exceed radio is made by the same outfit, 4 & 6 channel devices use the same SW). It's a big thread but the info is all there.
philba is offline Find More Posts by philba
Old Mar 15, 2010, 06:46 PM
WOODLAND WA.
Joined Mar 2010
thanks much........... wf
Old Mar 21, 2010, 08:53 AM
WOODLAND WA.
Joined Mar 2010
Got that computer program figured out, would not work on pc with vista !!?? Even with the downloaded files that were supposed to make it work ! But was able to get it to work on windows 7 on my laptop with the same files...?.. Thats even better, I can take it when I fly to make adjustments if I have too.....
Old Sep 04, 2010, 12:16 AM
serv is offline
Find More Posts by serv
Joined Sep 2010
all step by step setup for a newbie :P
i saw this which is gud for a newbie :
http://ow.ly/2zqNR
serv is offline Find More Posts by serv
Old Sep 09, 2010, 02:14 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Exceed info page:
http://www.mycoolheli.com/t6config.html
Melnic is offline Find More Posts by Melnic
Question how would this work for a set up for a really heavy fomie swim93 Foamies (Scratchbuilt) 6 Mar 01, 2010 01:31 PM
Discussion fly sky ct6 problem helimayham Beginner Training Area (Aircraft-Electric) 2 Jan 30, 2010 03:02 PM
For Sale 70 mm EDF jet set-up from Exceed F-18 latinlax01 Aircraft - Electric - Jets (FS/W) 6 Aug 18, 2009 01:41 AM
Help! Exceed FA-18 PNP set-up for Rx skylane42 Foamy EDFs 1 Jun 17, 2009 11:21 AM
Sold TRAINER SET UP, ARF, .46, Futaba system, $230 shipped krosypal Aircraft - Fuel - Airplanes (FS/W) 0 Mar 20, 2008 12:30 PM
