Old Aug 19, 2011, 09:48 PM
FERNDALE AIR FOR is offline
Find More Posts by FERNDALE AIR FOR
ferndale air force
FERNDALE AIR FOR's Avatar
Joined Jul 2006
Thanks for the feedback. Am I wrong in thinking that I can bump up, or down, pitch and throttle with the provided switches? The wind is blowing, so no real tests today.
Tim
Throttle hold is how I figured out how to fly this bird. That is the genesis of why I switched my TX grip. .
FERNDALE AIR FOR is offline Find More Posts by FERNDALE AIR FOR
Old Aug 19, 2011, 10:15 PM
choppersrule is offline
Find More Posts by choppersrule
Got Helis
choppersrule's Avatar
United States, IN, Greenwood
Joined Mar 2010
Tim,
The switch positions, IE: Normal mode, Stunt 1, and some radios have Stunt 2.
Each switch position must be programmed in the Transmitter. If you bump up or down any settings, it has to be done in the TX, associated with the switch position (normal, stunt 1 or stunt 2)... Clear as mud, right...
Dave
choppersrule is offline Find More Posts by choppersrule
Old Aug 19, 2011, 10:18 PM
Wnuk is online now
Find More Posts by Wnuk
That looks about right!
Wnuk's Avatar
Hunlock Creek, PA
Joined Jan 2010
Look at it this way:
Your throttle stick increases or decreases the motor RPM when you are in normal flight mode. At the same time, it increases or decreases the pitch of the blades. When you hit the throttle hold switch you are essentially cutting off power to the motor but you still have pitch control using the throttle stick. No switch controls the pitch of the blades, just the throttle stick.
Hope that muddied the water for ya a bit more
Wnuk is online now Find More Posts by Wnuk
Old Aug 19, 2011, 11:21 PM
metalbenderusn is offline
Find More Posts by metalbenderusn
My dog is PERFECT in my eyes
Joined Mar 2010
What is TRULY amazing about the MCPx is the fact that it's a FLYBARLESS system AND is amazingly TOUGH. I dont even think about it being flybarless while flying it. I am seriously awestruck by the engineering that turned out right with it.
LMAO if I know I'm gonna crash and I got time, I hit the ole switch, the motor stops and the blades go straight to neutral....I got it set up that way on purpose. When it hits, not much impact at all.
metalbenderusn is offline Find More Posts by metalbenderusn
Old Aug 20, 2011, 10:48 AM
BARRRICK is offline
Find More Posts by BARRRICK
BARRRICK's Avatar
USA, TX, Houston
Joined May 2002
a question about flight duration for the MCPX
been using 25 C [ 1S 3.7V 200mAh] and timing myself to 3:30 min. per flight . This is advise that Dave passed on, mostly to keep the consumption of the battery at 80%
I upgraded to 35C [1S 3.7V 300 mAh]
I don't know but I suspect that it would be OK to increase the flight duration but I really don't know how to measure that.
somebody that knows, please compute this for me ?
Incidentally, I am getting fantastic flights out of this heli. I have to fly in the backyard a bit after 6:00 am to avoid the HEAT and the BREEZES but the flights are truly great, just tremendously RESTRICTED DUE TO SMALL AREA in this backyard.
RICK
BARRRICK is offline Find More Posts by BARRRICK
Old Aug 20, 2011, 11:53 AM
Wnuk is online now
Wnuk's Avatar
Hunlock Creek, PA
Joined Jan 2010
Rick- if you are in normal flight mode I'd think you'd be ok with about 4:30 per flight. If using idle up, stick to 4:00. I have 3 nano tech 300mah batteries on the way and plan on tryin 4:00 minutes in idle up to start. Stock battery in idle up I'm sticking to 3:30.
Keep enjoying it. You KNOW it must be a keeper if VIC is happy with it!
Old Aug 20, 2011, 12:51 PM
Joined Mar 2010
"You KNOW it must be a keeper if VIC is happy with it!"
Rub it in......JERK....LMAO
Old Aug 20, 2011, 01:04 PM
CopterKid77 is offline
Find More Posts by CopterKid77
"To Hover is Divine"
CopterKid77's Avatar
United States, MO, Howell
Joined May 2010
LOL......that's too funny......LOL
CopterKid77 is offline Find More Posts by CopterKid77
Old Aug 20, 2011, 01:48 PM
BARRRICK is offline
BARRRICK's Avatar
USA, TX, Houston
Joined May 2002
WOW ( in a POSITIVE way ! )
Mr. VIC in St.Louis Michigan
is now our
ULTIMATE AND SUPREME FILTER !
appointed by JW and approved by RFB
kinda glad he came back to liking EFlite stuff !
Old Aug 20, 2011, 03:39 PM
Joined Mar 2010
is now our
Rick...I know JUNK when I see it, I learned it at "getting your butt kicked university".
Old Aug 20, 2011, 03:43 PM
Wnuk is online now
Wnuk's Avatar
Hunlock Creek, PA
Joined Jan 2010
Know when to hold 'em and know when to fold 'em. The mcp X is a royal straight flush
Just remembered our buddy Jeremy used to hang out here. The one who flew his 450 off a 19 story building. Think Dave still has the pictures. Anyone hear from him at all?
Old Aug 20, 2011, 04:46 PM
BARRRICK is offline
BARRRICK's Avatar
USA, TX, Houston
Joined May 2002
Jeremy
YES JIM W
we remember old JER
he is a close neighbor of Mr. JPEE
who discovered a while back that
JER was having a bunch of setbacks
with work, income, etc and felt as
if he was forced out of the hobby.
Then his adopted puppy died and I
believe from that point on he surrendered
to discouragement.
He kept ahead of the crowd I remember
with flying.
sad
good 'ole LOOKYJ who dropped a 450 on the pavement from 20 stories high, and actually FOUND the parts !!!!
Old Aug 20, 2011, 04:52 PM
ferndale air force
Joined Jul 2006
Flight report, the T-Rex part is what I thought you might have an interest in.
So here is how it went. mCPX both batteries no issues. Chatted with my buddy's mom, and the kids showed up.
Next up was the T-Rex to try and get it off the ground I have to hold the rudder full right and it is still not steady. I have to hold the right stick to the left with the trimmer buried to the left and a touch of up elevator. I skittered it around the infield and then shut it down.
Next up was my homade SU-26 profile. It flew pretty well, shocking me. It did not get a second flight as I found an elevator issue. During this flight I picked up a family of five, with the oldest boy about 3. The dad did not have gray hair, yet. I flew each plane for them with a bit of patter.
They left and I decided to shoot an Extra video. And then I flew the Yak with the camera in a different spot.
I am charging up batteries, hoping the wind chills out some.
Tim
Old Aug 20, 2011, 04:59 PM
9sec240 is offline
Find More Posts by 9sec240
Advanced Heli Collector
9sec240's Avatar
USA, IL, Carol Stream
Joined Jan 2009
Best video I have seen that shows what IRCHA is about... You might recognize somebody at 3:48. LOL
IRCHA 2011 Jamboree | Mikado (6 min 47 sec)
9sec240 is offline Find More Posts by 9sec240
Old Aug 20, 2011, 05:12 PM
Joined May 2010
LOL......oh yeah....I recognize somebody.........LOL.....thanks for the vid Ivan.
Discussion our soaring brothers got2soar Hand Launch 19 Aug 17, 2010 09:58 AM
Sold Futaba Low Band R127DF Receiver! flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 0 Feb 27, 2010 10:48 AM
Sold Band of Brothers DVD set Tin Collectors Edition ($45 Shipped, great conditon!) CGReload Non R/C Items (FS/W) 2 Aug 17, 2008 08:11 PM
Band of Brothers - the real-life heroes leccyflyer Life, The Universe, and Politics 5 Dec 08, 2001 10:52 PM
Band of Brothers, anyone else watching? Fitz Walker Life, The Universe, and Politics 23 Oct 05, 2001 08:22 PM
