Old Mar 15, 2010, 07:29 PM
1Radioflyer is offline
Find More Posts by 1Radioflyer
Luvin' Life
1Radioflyer's Avatar
United States, MI, Portage
Joined Apr 2007
Originally Posted by BARRRICK View Post
I don't have that much LIFE left to find it on my own.
RICK
You need a bit more optimism than that my friend
We'll see what we can do
God Bless Ya Rick,
Jay
1Radioflyer is offline Find More Posts by 1Radioflyer
Old Mar 15, 2010, 07:33 PM
Oracus is offline
Find More Posts by Oracus
I meant to do that!
Oracus's Avatar
United States, IN, West Terre Haute
Joined Apr 2007
While being stuck indoors today I went over the THR/PIT curves for the Vision after installing he new paddles. The only thing so far about the paddles I really don't care for is that they cut the threads on install with no locking screw(I could use glue) but that caused me to thread them on more than the stock ones which shortened up the flybar by almost 80mm total.
Heres some specs : Stock paddles 16g each
KBDD 30/50 paddles 12g each
Oracus is offline Find More Posts by Oracus
Old Mar 15, 2010, 07:35 PM
choppersrule is offline
Find More Posts by choppersrule
Got Helis
choppersrule's Avatar
United States, IN, Greenwood
Joined Mar 2010
DX-7 programming for Blade SR
lissen up EVERYBODY !
RICK (soon to be the "dearly departed")
Rick,
Your thinking like an OLD PHART again.. STOP IT, or I'll have to come out there and kick you "Behind" for sure. Remember, I'm the Ghetto boy. Lol!
We WILL find some setting for ya. Barrrick Bar None! Be patient my friend.
Dave
choppersrule is offline Find More Posts by choppersrule
Old Mar 15, 2010, 07:47 PM
Got Helis
Joined Mar 2010
KBDD paddles
Kyle,
I've been stuck indoors for sometime now, and don't have a job. LOL!
YIKES! 80mm shorter, that's like 3 inches.....or there abouts.
As you know, with a shorter flybar, you'll have alot more cyclic response.
If that is a concern to you, you have a few options. See if there is a longer flybar rod available. Add flybar weights. Last but not least, make your own flybar.
You can use Piano Wire from the LHS, just measure the O.D. and either have it threaded or thread it yourself. Dies are available, but for a one time shot, a little pricey. Just food for thought.
Dave
Old Mar 15, 2010, 07:51 PM
Oracus is offline
I meant to do that!
Oracus's Avatar
Joined Apr 2007
Im not worried bout it plus making a flybar is not easily done ElyQ uses a floating flybar design very neat stuff
Old Mar 15, 2010, 07:52 PM
metalbenderusn is offline
Find More Posts by metalbenderusn
My dog is PERFECT in my eyes
Joined Mar 2010
GENERAL QUARTERS ::::::::
I am MOBILIZING each one of you : TO FIND, FOR ME, the "complete" programming guide to set up my DX-7 to operate the BLADE SR
I am already looking in a THREAD specialized in this, but the search is long. I don't have that much LIFE left to find it on my own.
Dave's the man...he can dig the most obscure information up like I've never seen.
How old is your mom? Dude...yer gonna hang around till yer 117yo. You might FEEL "soon to be dearly departed"....but you aint going no place jack....
metalbenderusn is offline Find More Posts by metalbenderusn
Old Mar 15, 2010, 07:54 PM
Luvin' Life
Joined Apr 2007
Kyle,
I can't tell ya anything about what you have going on.... but might I say,
She sure looks good.
Pardon my French but I just looked at your picture again and said out loud, mind you no one else is home,
"That is so Bad A$$"
Last edited by 1Radioflyer; Mar 15, 2010 at 07:59 PM. Reason: A picture worth a few dirty words;-)
Old Mar 15, 2010, 08:06 PM
Got Helis
Joined Mar 2010
Kyle,
I never noticed the ElyQ floating flybar. (Duh) It's been around for sometime and works wonders.
Dave
Old Mar 15, 2010, 08:13 PM
9sec240 is offline
Find More Posts by 9sec240
Advanced Heli Collector
9sec240's Avatar
USA, IL, Carol Stream
Joined Jan 2009
A repost from the BSR thread....
After binding to my DX7, I decided to raise the swash to get the pitch to zero at mid stick. It took three turns out on the three swash linkage rods and a turn in on the blade pitch links and I got zero pitch. Due to the design of the head, the closest I could get to equal pos and neg pitch was +10 and -9. This is good enough for me. I set cyclic pitch to 7 degrees. My settings are:
Swash mix
AILE -68
ELEV -68
PIT -25
AILE and RUDD are reversed.
The ESC turns out to be non programmable from what I can tell. I tried to set throttle range but just got warning beeps from the ESC and no programming tones. This is just like the Blade 400 ESC. I set throttle up to 0-80-90 for F0, 100-90-100 for F1 and 100 flat for F2. There was no difference in RPMs in any flight mode. I also found this to be the same on the Blade 400. On the B400 I ended up adjusting down the high throttle channel end point till it decreased head speed to set throttle range. I will have to do that tomorrow.
I decided to remove the flybar weights and see how it felt. Collective pitch still seemed a bit weak so I turned up the pitch swash mix from -25 to -30 and that gave it a bit more pop. Tomorrow I will get it out in a bigger area where I can actually fly and feel it out.
I got a chance to measure the added pitch which ended up at +11 -10
I tweaked it in some more after I got a chance to fly it. I ended up with raising the AIL and ELE swash mix to -80.
9sec240 is offline Find More Posts by 9sec240
Old Mar 15, 2010, 08:17 PM
46u is offline
46u
Find More Posts by 46u
46u
46u's Avatar
Macon, GA USA
Joined Mar 2010
I got a replay from Horizon Hobbies about the E-flite batteries for the MCX and MSR.
Andrew at HH hobby said the battery could last 20 flights or 100 flights and there is not a set life expectancy. I do not care if the ones on eBay give you a minute less flying time I will never buy another E-flite battery!!!!!!!!! I wish I had saved the email, as it was not very professional. I have bought 7 E-flite helicopters and many spares in the past 2 months and I sure as heck will not buy another.
46u is offline Find More Posts by 46u
Old Mar 15, 2010, 08:30 PM
Luvin' Life
Joined Apr 2007
Jeff,
I'm sending a PM
Look for the alert on the upper right on the screen.
Old Mar 15, 2010, 10:08 PM
BARRRICK is offline
Find More Posts by BARRRICK
BARRRICK's Avatar
USA, TX, Houston
Joined May 2002
t'was just a wee bit of funereal levity
to lighten up the evening.
yes, indeed, my sense of humour is
startlingly different.
even IF I had a programming list
in my sweaty palm
I would not know how to apply it
but YOU KNEW that.
pay no attention :-P
BARRRICK is offline Find More Posts by BARRRICK
Old Mar 16, 2010, 02:16 AM
lookyj is offline
Find More Posts by lookyj
Los Angeles
Joined Dec 2006
I'll follow the BOB's just about anywhere....
lookyj is offline Find More Posts by lookyj
Old Mar 16, 2010, 05:42 AM
Oracus is offline
I meant to do that!
Oracus's Avatar
Joined Apr 2007
Sorry about your HH troubles, looks like your on Vic's bandwagon now
Old Mar 16, 2010, 06:48 AM
Wnuk is offline
Find More Posts by Wnuk
That looks about right!
Wnuk's Avatar
Hunlock Creek, PA
Joined Jan 2010
Jeremy made it!!! Did you and JPEE get together yet this week?
Jeff- HH is usualy excelent with their customer service. I'd maybe call again and hope for a different rep.
Kyle-Are you going to be doing the maiden soon?
Super weather is forecast the next 5 days here. I WILL find a few minutes to relax and enjoy so air time.
Wnuk is offline Find More Posts by Wnuk
Discussion our soaring brothers got2soar Hand Launch 19 Aug 17, 2010 08:58 AM
Sold Futaba Low Band R127DF Receiver! flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 0 Feb 27, 2010 09:48 AM
Sold Band of Brothers DVD set Tin Collectors Edition ($45 Shipped, great conditon!) CGReload Non R/C Items (FS/W) 2 Aug 17, 2008 07:11 PM
Band of Brothers - the real-life heroes leccyflyer Life, The Universe, and Politics 5 Dec 08, 2001 09:52 PM
Band of Brothers, anyone else watching? Fitz Walker Life, The Universe, and Politics 23 Oct 05, 2001 07:22 PM
