Old Sep 19, 2010, 08:23 AM
Oracus is offline
Find More Posts by Oracus
I meant to do that!
Oracus's Avatar
United States, IN, West Terre Haute
Joined Apr 2007
Originally Posted by metalbenderusn View Post
CENTRAL AIR CONDITIONER PROBLEMS....that was a thing I had happen 3 days ago. I heard the furnace making a weird noise, I checked the vents...no air comming out, so I shut it down and killed the breaker. Disaster I'm thinking and I just spent $350 getting it fixed not long ago (a hole in the freon return line). Pulled the lower panel of the furnace, the "A" coil was a brick of ICE...that explains no air comming from vents. The system was new in 1999, so it's got some time on it. It took 12hrs to thaw it to room temp. Since we all know NO filter can completely stop dust and given the systems age, I see there's a blanket of fur on the A coil. It took two hours to clean that coil with a wire brush, but I got it clean and put the lower panels back on with new filters. It got hot in here, I had to fire up the A/C cause I couldn't stand it. Apparently, the blocked A-coil was the prob...works as advertised now. Two things will cause an A-coil to freeze up. First is low freon charge, second is dirty A-coil (these being MOST common). Other things will cause it too, but check the coil first and freon charge second. ANother thing that can happen is the capacitor in the A/C unit can go bad. The AC wont work, but you'll hear a hum from the unit. I had a mouse touch BOTH terminals of the capacitor, and it fried the mouse and the capacitor....a $60 part (not the mouse). SO....I have central air again. WHen I dont need it, I'll kill the breaker to it to prevent the mouse episode again. This was an easy fix, but preventitive maintenance would have made it easier and quicker. Vaccume your A-coil once every year or two and always replace filters to your furnace every 6 months.
AC problems can be tuff to figure out, but If you know your system pressure get a cheap set of guages to check your charge with.
Oracus is offline Find More Posts by Oracus
Old Sep 19, 2010, 11:45 AM
BARRRICK is offline
Find More Posts by BARRRICK
BARRRICK's Avatar
USA, TX, Houston
Joined May 2002
Way too many
TOO MANY TOYS
NOT ENOUGH GOOD SENSE
other addictions I "could" have (but I don't) ! :
alcohol,tobacco,broads,weed,drugs,beer,gambling,wo rk?
so I lie to 'self and keep on going, kidding 'self that am doing good ....
BARRRICK is offline Find More Posts by BARRRICK
Old Sep 19, 2010, 01:32 PM
Stamp is offline
Find More Posts by Stamp
Visit My Blog
Stamp's Avatar
Outskirts of Chicago
Joined Nov 2008
You are being a very good boy .
Addictions come in many forms.
Jim
Stamp is offline Find More Posts by Stamp
Old Sep 19, 2010, 01:36 PM
9sec240 is offline
Find More Posts by 9sec240
Advanced Heli Collector
9sec240's Avatar
USA, IL, Carol Stream
Joined Jan 2009
Rick, how do you like the Micro T-28?
9sec240 is offline Find More Posts by 9sec240
Old Sep 19, 2010, 04:29 PM
metalbenderusn is offline
Find More Posts by metalbenderusn
My dog is PERFECT in my eyes
Joined Mar 2010
Kyle....Had it froze up again after cleaning the A-coil, I would have called the guy who fixed it last time...he knows his stuff. When he fixed the hole in the line, he added filters to the freon lines and corrected a bunch of problems the original installers screwed up. Up to now, it's been flawless since he worked on it. The dirty coil was my fault I will next spring have him come out and do a 100% PM on it, it will have been two years since he touched it.
LOL....Rick....I see you're partial to the T-28, aint NOTHING wrong with that. A guy I flew with in the Navy had a .60 sized T-28, it was GREAT and I loved it. Back then.....I couldn't afford much more than a trainer to fly, and it's all I was capable of flying.
Jay...I added another 230gr bullet to the tail, it's BETTER than last time and close to flying upright or inverted with no stick input other than to roll it over...one more ought to do it. The fuel system...yep...I gotta dig into it, there is a leak and I'm gonna find it today.
My helicopter is on administrative leave (unpaid) till further notice. If it comes down to it.....I'll FIRE it.
metalbenderusn is offline Find More Posts by metalbenderusn
Old Sep 19, 2010, 05:58 PM
BARRRICK is offline
BARRRICK's Avatar
USA, TX, Houston
Joined May 2002
As if by magic
to: 9SEC240 :
wouldn't KNOW how the T-28 flies !
I have the MAGIC ability to turn ALL flying models into STATIC DISPLAYS
18 helicopters, four planes and one big glider attest to that and have become fancy complicated book ends. [ you can ask VIC ! ]
i curse myself daily FOR THIS REASON.....who can go fly when the HEAT is 100F every day ?
vomit vomit
Old Sep 19, 2010, 06:03 PM
1Radioflyer is offline
Find More Posts by 1Radioflyer
Luvin' Life
1Radioflyer's Avatar
United States, MI, Portage
Joined Apr 2007
You and me both
Blessings!
1Radioflyer is offline Find More Posts by 1Radioflyer
Old Sep 19, 2010, 06:57 PM
Joined Mar 2010
Originally Posted by 1Radioflyer View Post
You and me both
Blessings!
LOL....I got a NICE Bell206 holding down a shelf in the basement. Right now, I'm really thinking about dumping helicopters and concentrate of real NICE planks and EDF jets. Heli's are fun and are cool BUT I've got to decide if the cost justifys the means. I fly the Uproar flight after flight. If the engine quits, I land (hasent happened with this .46 though). If a helicopter quits, it splatters it's self in an instant, sometimes you can auto-rotate, but that's a 50/50 proposition. If you're in a 15 ft high hover and it quits, not much time to auto rotate because the air across the main blades isn't enough and aint gonna save it. I'm really thinking about this:
http://www3.towerhobbies.com/cgi-bin...&I=LXVZB0&P=ML
using a 4 stroke engine and the optional detailed cockpit
Old Sep 20, 2010, 06:52 PM
Joined Mar 2010
Added one more bullet, got what I was after. I prop'ed it to a 11-6, I don't like it...back to the 12-6. Tomorrow will be windy/stormy/hot (for me) at 80deg....I won't be doing MUCH tomorrow. Flew the Uproar 3x today even in the wind...not a lot of problems except I need to manage the flaps a little better by NOT putting them all the way down, that don't work too well when landing....the plane slows down to slow if you don't manage the throttle at the same time...flaps are sort'a new to me, never used 'em before this year...ever, so it's a LEARNING thing.
Old Sep 20, 2010, 06:56 PM
Oracus is offline
I meant to do that!
Oracus's Avatar
Joined Apr 2007
Sounds like a good time with the uproar. Some times you just need a break(Heli's), fix it up put it on the shelf youll come back when your ready.
Old Sep 20, 2010, 07:37 PM
Luvin' Life
Joined Apr 2007
Vic,
When I get a minute I'm going to send you out an APC 12.75x3.26 prop. I absolutely loved the 46 and this prop. It is a bit slower to "spool up" but the power is unbelievable.
Kyle,
I think I'm on the back side of my heli benching. I'm going to get Hughes 500 fuse for the 450 soon and do it up with lights I'm starting to get that itch back even though we're on the end on the season.
Blessings,
Jay
Old Sep 20, 2010, 07:39 PM
Oracus is offline
I meant to do that!
Oracus's Avatar
Joined Apr 2007
Jay
After my last little break I improved alot once I started flying again.
Old Sep 20, 2010, 07:47 PM
Luvin' Life
Joined Apr 2007
There is as lot to be said with that. I felt like I hit a wall and was going any where. I guess I feel the same way with planes now. I think it's time for me to take helis in a scale direction.
Blessings
Old Sep 20, 2010, 09:05 PM
Joined Mar 2010
Blessings
An amazing amount of wisdom in the last 4 posts. I think I need to give helicopters a powder for a while. Along with the Cessna 182 Gold edition, I looked at the Cessna 310 (.46 twin), it's awsome for sure. I checked out retracts for it, Robarts are almost $400 THEMSELVES. The Cessna 310 to build with retracts (I couldn't live with fixed gears on it), I'll guess about $1000 to flight ready and that thing is HUGE, my wifes "taco bell" dog would easily fit in it with comfort, and the plane would fly good with the dog on board. I could not feel good about putting the little dog in it and flying it (unless I put in an ejection seat and parachute for her). The Uproar is a GOOD beater that performs well. A REALLY NICE scaler would be good for a change, and WINTER is ALMOST here. Moving snow isn't an enjoyable hobby....it's WORK.
If these two dogs can get along, ANYBODY can. The little one acts like the big one is her mother....LOL.
Old Sep 21, 2010, 02:34 PM
BARRRICK is offline
BARRRICK's Avatar
USA, TX, Houston
Joined May 2002
a GIFT from me to y'all :
http://www.tubewatcher.tv/182
Discussion our soaring brothers got2soar Hand Launch 19 Aug 17, 2010 08:58 AM
Sold Futaba Low Band R127DF Receiver! flyinjrc74 Aircraft - General - Radio Equipment (FS/W) 0 Feb 27, 2010 09:48 AM
Sold Band of Brothers DVD set Tin Collectors Edition ($45 Shipped, great conditon!) CGReload Non R/C Items (FS/W) 2 Aug 17, 2008 07:11 PM
Band of Brothers - the real-life heroes leccyflyer Life, The Universe, and Politics 5 Dec 08, 2001 09:52 PM
Band of Brothers, anyone else watching? Fitz Walker Life, The Universe, and Politics 23 Oct 05, 2001 07:22 PM
