Espritmodel.com Heli Air
Old Sep 03, 2011, 03:45 PM
Overconfidentii Flyis Caninus
WileCoyote's Avatar
United States, WI
Joined Jun 2007
Decided to give the Tacon motors a try so I bought a Bigfoot 25 and a 32.
They arrived a couple of days ago and seem to be decent motors. I test ran them both (holding them in my fingers without props) for the first time this morning to be sure there were no major issues. They both ran smoothly and transitioned up and down the throttle range nicely.
What I did notice and initially made me shake my head in disgust was the tapped holes for mounting the bolt on prop adaptor for the Bigfoot 32. The 4 tapped holes don't lie on a circle that is concentric with the 'nose' or center of the barrel housing See the attached photos.
I decided to see if I could install the prop adaptor and if so observe how bad would it wobble when running. Fortunately the c'bored screw holes in the adaptor are large enough that I was able to get all 4 socket head cap screws installed without issue. When I powered it up it ran true! The fit between the nose and the pocket on the backside of the adaptor is tight enough that it centered OK. Whew! I was planning on having to contact HobbyPartz and go thru the hassle of returning it for another motor or a refund....
Has anybody else with the Tacon Bigfoot motors also have non-concentric tapped holes for mounting the prop adaptor?
At this time I have no prop testing and related performance numbers to share for either of these motors.
WileCoyote is online now Find More Posts by WileCoyote
Old Sep 03, 2011, 04:50 PM
No Hangar Queens!
Maryland
Joined May 2009
My bigfoot definitely did not have that issue. Good thing to check though especially for mountings where centering is critical.
Willsonman is offline Find More Posts by Willsonman
Old Sep 03, 2011, 07:03 PM
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
I have a Tacon 15 up and running nicely in a E-flite Champ 15 and I also have a Tacon 110 destined for a Seagull Percival Mew Gull later this fall.
Did not notice any issues installing the bolt on prop adapters on either one and both turn smoothly.
Thomas B is offline Find More Posts by Thomas B
Old Sep 05, 2011, 06:57 PM
Joined Jun 2004
Exceed Coupon??
Melnic: Hi Where IS the coupon code??
Write down the coupon codes before you click."Where did you see the code?"
Then enter it at checkout. There is a box towards the bottom when you are entering your address. "I know where the box is.."
I'm not sure which one, but I think the gens ace coupon may be expired. That may include exceed. Not sure. Exceed expires on 9/9
DBono99 is offline Find More Posts by DBono99
Old Sep 05, 2011, 08:19 PM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I linked to this page in my post on the previous page of posts.
http://www.mycoolheli.com/coupons/ho...tzcoupons.html
I link to that web page because that web page gets more updated than this thread.
The Tacon and exceed should work. Yes, the Gens Ace appears to be expired.
Melnic is offline Find More Posts by Melnic
Old Sep 05, 2011, 10:25 PM
Xanadu's Avatar
Canada, MB, Winnipeg
Joined Nov 2006
There is NO COUPONS...........when I click on your link, it takes me to a page that only has links that take you to the home page of HP.
Where is the coupon code? Can you do a screen shot of what we are to see?
Attached is a screenshot of what we see when we click on your link. When you click on the links, there is no coupons, just takes you to HP page.
Xanadu is offline Find More Posts by Xanadu
Old Sep 06, 2011, 05:18 AM
AMA 84248 since 1964
Joined Jan 2011
Delighted with the Monster bigfoot 32. Put it in my Rhapsody 25 and it pulls the 5lb plane along perfectly... no mounting issues with the motor, did need thicker stand-offs so that the prop cleared the cowl, but that was easy.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Sep 06, 2011, 05:36 AM
No Hangar Queens!
Maryland
Joined May 2009
I believe the words Prior to the parentheses are the code. Write that down and click the link that will take you directly to the page. I don't think that is rocket science.
Old Sep 06, 2011, 06:45 AM
Joined Jun 2004
Exceed coupons
Hi I get the same reaction to clicking on the link that Xanadu.
" I don't think that is rocket science. Willsonman? Did you try it.
I've tried amost everything the past 2 days and NOITHING seems to work.
Give IT a try Willsonman, then WE can both build a rocket ship together..LOL
THanks Dan
Old Sep 06, 2011, 07:39 AM
Xanadu's Avatar
Joined Nov 2006
Oh crap, now I get it...............doh! Not very clear cut though, but simple enough. Somewhat deceiving about "click to use" so that is why it made it hard to understand at first.
Type in "Tacon10" at the checkout coupon box to get 10% off all Tacon motors.
Type in "Exceed10" to get 10% off Exceed
Type in "FPV5" for 5% off FPV camera's
etc., etc........
Now that an example is given, should solve any questions.
Xanadu's Avatar
Joined Nov 2006
double post, sorry
Old Sep 06, 2011, 06:20 PM
Joined Jun 2004
"Exceed10"
Xanadu NO matter what I do the coupon DOSEN 'T work..I tried but copying and pasting your "Exceed10" and nothing happen..
I think HP doesn't like me..LOL
I'm about ready to give on HP and go else where..
I still have 3 days to get the coupon to work..LOL
THen it's by/by HP hello Heads up
HELP!!!!!! Dan
PS I';m trying to place an order for $110.00.
the $110.00 never changes, no matter what I do, so the coupon code is NOT working..
Old Sep 06, 2011, 06:38 PM
Xanadu's Avatar
Joined Nov 2006
I just did it and it works.
Use all CAP letters, no spaces, etc. when you type it in the coupon box.
TACON10
EXCEED10
ETC, ETC....
Old Sep 06, 2011, 09:13 PM
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
HELP!!!!!! Dan
When you type in the coupon and hit apply , a message should appear at the top of the refreshed web page telling you if the coupon worked or not.
Old Sep 07, 2011, 06:12 AM
Joined Jun 2004
Coupon
Hi All
Well I finally got the coupon to work, but this is what I got.
"Coupon code exceed10 only applies to certain store items. None of these items are in your shopping basket."
I was ordering ESC's and UBEC's, guess they DON'T count..
I just went back and checked the EXceed10 coupon, IT should include the ESC's.Here it is
EXCEED10 (click to use,enter at checkout) (Expires 9/9/2011)
10% off of purchase of Exceed brand parts (motors, speed controllers, heli parts etc)
Many Thanks Dan to ALL!!!
Discussion Anyone using an Exceed RC Monster Power 160? tlh101 Power Systems 16 Feb 22, 2010 08:13 PM
Question Monster Power outrunner brushless motor flylower Power Systems 10 Oct 25, 2009 08:14 AM
Question Monster Power 1.60 Motor bbmichael25 Power Systems 8 Jun 06, 2009 10:22 PM
