Old Sep 16, 2010, 03:12 AM
buzzsaw 46 is offline
Find More Posts by buzzsaw 46
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Mike, On the 18x12 Menz prop I drew 2100watts, 57.88amps, at 36.16v, and 6781rpm. The 16x10 MA Scimitar was pulling ~1500watts.
My big Giles is about 15lbs by my bathroom scale(questionable accuracy) so the 18x12 will fly it but I think I need to go 11-12s to really get the speed and verticle performance I'm looking for.
I've attached my ET graphs for both test runs, didn't have the RPM sensor on for the 16x10 test oopps.
Jason
Added chart of a run on 10s2p. Amps and watts are halved by my parallel setup, so 2411.2watts and 62.58amps. Starting to think I might just be happy with this setup.
Thought I would add, I weighed it piece by piece on a 5lb digital scale and AUW looks to be ~13.4lbs -battery ~10.42lbs
buzzsaw 46 is offline Find More Posts by buzzsaw 46
Old Sep 16, 2010, 06:33 AM
tubamike78 is offline
Find More Posts by tubamike78
tubamike78's Avatar
United States, OH, Monroeville
Joined Dec 2007
2411.2 watts looks about what i would want for the ultimate. around 200 watts/pound for a 12 pound plane. when i get mine going, think i may even try a 19" prop also. will be running it on 2-gforce 5 cell 5000mah 30c in series
http://www.valuehobby.com/product_de...18&item_id=332
with a hobbywing pentium 80a high voltage bec
http://www.valuehobby.com/product_de...=25&item_id=52
tubamike78 is offline Find More Posts by tubamike78
Old Sep 16, 2010, 06:45 AM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
I have the HW platinum 70HV, might upgrade to a Plat. 120HV. The no spark lead on the Platinums is a nice feature. Thinking a 19x12 will be my sweet spot also.
Old Sep 27, 2010, 02:50 AM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
I finally got a chance to fly the 160 yesterday. I flew on the Menz 18x12 and it was excellent. Verticle was unlimited, speed was quite acceptable although I think a touch more voltage or an 18x13 prop would be welcome in my Giles.
Anyway here is a short video of the second flight.
Old Sep 27, 2010, 08:43 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
cool, that looked like it flew bigger than a .50
Buzz, where did you get the Giles and was it designed for Electric?
Melnic is offline Find More Posts by Melnic
Old Sep 27, 2010, 10:52 AM
tubamike78's Avatar
Joined Dec 2007
looks like it flew pretty good. can't wait to get my ultimate ready now. have you tryed changing the timing on the esc to high, that should give you more power.
Old Sep 28, 2010, 02:09 AM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Melnic, I got my kit from AK models also sold at nitro planes. It was not intended for electric power but it was very easy to mount everything. And yes it flies much larger than my .50 size.
Mike, I have the timing turned up some cant recall off hand how far I went, I'll check. Your Ultimate should be alot of fun, good luck with it.
I have a new HD camcorder on the way hope to get some better video this weekend if the weather cooperates.
Old Sep 28, 2010, 04:19 PM
gingerama is offline
Find More Posts by gingerama
Joined Dec 2009
Been flying a 6lb Phoenix Extra 300S conversion all summer on a Monster 60, 5s 3300 pulling 700W on a wood 14X10/6. Great plane at a super price $120 at TH.
gingerama is offline Find More Posts by gingerama
Old Sep 30, 2010, 12:31 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
I flew a SIG Seniorita with a Monster Power 15, and 3S. Driving Miss Daisy, but fun to learn on. Underpowered.
The Monster Power 25 likes at least 4S voltage. Else it doesn't get up into its "aerobic range". With 4S, it will climb a 6 foot electric glider nicely.
The Monster Power 46 with 4S would probably do very nicely on the Seniorita. It is underpowerd for a 48" aeorbatic 5lb plane like the Tango. Ballpark would be:
12x8 prop, 38A continuous, 91oz thrust, 62 mph, 403 watts to the prop, 3 minutes 23 second run time for a 2200mAh battery.
Remember: the Seniorita has full size servos, and they pull the limit that a speed controller can dump to them. You would be wise to get an OPTO speed controller and separate SBEC, and a 1500mAh battery to run the servos and RX that is separate from the motor batteries.
wuest3141 is offline Find More Posts by wuest3141
Old Oct 16, 2010, 09:52 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
they just got some motors in stock
Old Oct 17, 2010, 05:16 AM
buzzsaw 46's Avatar
Spring Valley. MN
Joined Jun 2000
Thanks for the heads up Melnic.
I havent flown in a while, got two puppies a couple weeks ago. Spending a lot of time with them.
Old Oct 27, 2010, 01:50 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Looks like they have More MP motors in stock at [URL="http://bit.ly/9zFxM2"]hobbyparts.This time I'm posting the info AFTER I placed my order. Last time, they ran out of stock before I placed my order, LOL!
Old Oct 27, 2010, 02:10 PM
tubamike78's Avatar
Joined Dec 2007
thanks for the heads up. got my monster power 160 last weak for the ultimate 120, getting a monster power 60 for the seamaster i picked up last weakend.
Old Nov 01, 2010, 03:15 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
Cool, let us know how it goes.
Old Nov 04, 2010, 09:56 PM
HEMICUDA is offline
Find More Posts by HEMICUDA
HEMICUDA's Avatar
Greensboro Pa USA
Joined Apr 2008
well, I finally ordered my Monster 32 from Hobbypartz with a 60A opto ESC for the Sig Seniorita. I will also be using seperate RX battery. Plane in still in the box...one of many winter projects.
Hemicuda
HEMICUDA is offline Find More Posts by HEMICUDA
Discussion Anyone using an Exceed RC Monster Power 160? tlh101 Power Systems 16 Feb 22, 2010 08:13 PM
Question Monster Power outrunner brushless motor flylower Power Systems 10 Oct 25, 2009 08:14 AM
Question Monster Power 1.60 Motor bbmichael25 Power Systems 8 Jun 06, 2009 10:22 PM
