Old Feb 03, 2013, 11:03 PM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Thanks for the recommendations . I now have the monster 32 on order. Will also check out your links alexjschauer .
Pay no attention to my 2 year long stalker above..same ol' same ol with that Lady.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Feb 05, 2013, 03:22 PM
mickydee is offline
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi,
Where did you find the Monster Power motor in stock?
Thanks!
Mickydee
mickydee is offline Find More Posts by mickydee
Old Feb 07, 2013, 04:04 PM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
On the hobbyparts website, click the Motors on the left, then giant motors.
but Tacon big foot is better than Monster power anyway.
I don't see Monster power listed. They must have cleaned the old links up.
Hobbypartz 5% coupon code
Melnic is offline Find More Posts by Melnic
Old Feb 07, 2013, 04:54 PM
Lardog is offline
Find More Posts by Lardog
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
I believe the Monster Power line has been discontinued.
Lardog is offline Find More Posts by Lardog
Old Mar 02, 2014, 04:53 PM
bradbxyz is online now
Find More Posts by bradbxyz
bradbxyz's Avatar
United States, CA, El Cajon
Joined Jun 2004
Can anyone tell me if the Bigfoot 160 x-mount is the same as the e-flite 160? I ordered Tuesday and have a bigfoot on the way for a plane I am finishing, and would like to drill the firewall today if possible.
Brad
bradbxyz is online now Find More Posts by bradbxyz
Old Mar 12, 2014, 09:42 PM
marksp is online now
Find More Posts by marksp
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
Brad
Did you ever get an answer or sort this out? I have the Bigfoot 160 and am also curious if the mounting pattern is the same as e-flite.
Cheers
marksp is online now Find More Posts by marksp
Old Mar 13, 2014, 12:14 AM
bradbxyz's Avatar
Joined Jun 2004
The X mount has the same outer bolt pattern as the e-flite 160. the screws that hold the motor to the x-mount are in a smaller pattern.
I ended up buying a power 160 anyways to get the plane in the air since hobbypartz packaged the motor and lost it prior to shipping. It arrived yesterday from an order that was placed on 25 Feb
Old Mar 13, 2014, 05:52 AM
marksp's Avatar
Joined Apr 2011
Right on, thx!
Old May 08, 2014, 09:55 AM
Willsonman is online now
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
Anybody know if the Tacon bolt-on prop adapter will fit the (now unobtanium) ExceedRC equivalent motors? I have an ExceedRC .46 and am in need of a prop adapter. too many nose-overs I do not want to chance reversing the shaft and getting a collet-type adapter. Too many bad experiences reversing shafts.
Willsonman is online now Find More Posts by Willsonman
Old May 14, 2014, 10:45 AM
No Hangar Queens!
Maryland
Joined May 2009
Well, after discovering that the Tacon .46 has a 6mm shaft and my ExceedRC .46 has an 8mm shaft I decided to just bite the bullet and reverse the shaft. No issues. I did have to grind a flat spot for the grub screw on the bell. I also noticed that there are two sets of bearings on each end of the motor. Interesting. I've ordered a prop adapter for my 8mm shaft.
Old Dec 14, 2014, 03:07 PM
MikeMcChiken is offline
Find More Posts by MikeMcChiken
Fly'em like you Stole'em
MikeMcChiken's Avatar
The Gehto,Ca.
Joined Jun 2008
I was wondering if anyone had calipers to measure the counterbore diameter an depth and the bolt circle for mounting on the Tacon 32 and 46 prop adaptors . Id like a place to buy adaptors and Tacon has a good selection . From all the searching I have done there seems to be some standardization with them . I have seen 6 and 8mm shafts for 32 size motors though . The only other difference is a 4 or 3 bolt pattern . I have looked for specs but cant even find a website for Tacon so it must be a rebranded china motor used by Nitro and HobbyPartz .
MikeMcChiken is offline Find More Posts by MikeMcChiken
Old Dec 14, 2014, 05:45 PM
blvdbuzzard is offline
Find More Posts by blvdbuzzard
The high desert of Southern California
Joined Jul 2002
I have used the one for the 46, 60, 15 and they have fit my Monster power and Tacon motors. Might work for you?
http://www.valuehobby.com/accessorie...rop-shaft.html
Buzz.
blvdbuzzard is offline Find More Posts by blvdbuzzard
Old Jun 20, 2015, 06:44 PM
mnavarro is online now
Find More Posts by mnavarro
United States, CA, SF
Joined Oct 2010
Motor went out on me ... lost power probably not sure if it was because magnet broke loose and caused it too lock or my ESC went into thermal protection. I'm running 20x10 VV rc electric prop on 4500 10s. Not sure that this is the kind of power that would do this to the motor. Could a prop strike do something like this. I ordered another one and have to do minor repairs on my bird.
mnavarro is online now Find More Posts by mnavarro
Old May 09, 2016, 07:02 PM
Ldm is offline
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
Anyone know if the Tacon 160 can take 2x 6 cell packs at 5000c size on a 20/10 two balde ?
It says is a 245 KV , my buddy a very experienced RC warbird guy is flying this exact set up on ESM 18 thru 20lb warbirds and says it's a proven format with 8 or so mins of flying.
Yet everything I read on this and the 160 eflight all show 2x 5 cell packs ?
Ldm is offline Find More Posts by Ldm
Old May 09, 2016, 07:28 PM
Bonified Wingnut is offline
Find More Posts by Bonified Wingnut
United States, MI, Frankenmuth
Joined Jul 2007
I run a Bigfoot 160 with a 16 x 8 3 blade on 12 cells and it runs over 3000 watts. I don't recommend a 20 x 10 2 blade on 12 cells. I am thinking you would get everything real hot.
Bonified Wingnut is offline Find More Posts by Bonified Wingnut
Discussion Anyone using an Exceed RC Monster Power 160? tlh101 Power Systems 16 Feb 22, 2010 08:13 PM
Question Monster Power outrunner brushless motor flylower Power Systems 10 Oct 25, 2009 08:14 AM
Question Monster Power 1.60 Motor bbmichael25 Power Systems 8 Jun 06, 2009 10:22 PM
