Old May 16, 2012, 05:50 AM
jw357_23043 is offline
Find More Posts by jw357_23043
Shut up and Fly!!!
jw357_23043's Avatar
United States, VA, Hartfield
Joined Aug 2011
Originally Posted by Melnic View Post
use eflite 160
I found you can get a much more accurate reading if you manually input the motor data. Don't use the eflite 160. There is a difference in the no load current not to mention a 3amp difference. I input the data manually and got a bigger prop to work so I'm guessing in the theory that the MP has better potential. Just wanted to let you know for future reference.
jw357_23043 is offline Find More Posts by jw357_23043
Old May 16, 2012, 08:26 AM
Melnic is offline
Find More Posts by Melnic
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
so you have tried the MP160, what do you mean more accurate? What are you comparing. Don't believe too many specs you see from that motor. Even the Kv for the motor your delivered can be off from the spec by 5-10%.
the just about any calc is a ball park figure. +/- 20% accuracy I"ve found.
Melnic is offline Find More Posts by Melnic
Old May 16, 2012, 09:32 AM
Shut up and Fly!!!
Joined Aug 2011
Oh I know Mel, Just wanted to let you know what I did is all. I just changed the plane the mp 160 is going on. Now it will be on a Lanier Pitts Special. Full weight I'm guessing will be around 13 to 15 lbs.
Old May 16, 2012, 09:51 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
Guys..
I have no idea what you are talking about, but Doc993 seemed to indicate a source for Monster Tacon motors. I have one and love it would like to purchase more, and I don't care if the case is green or red... Doc 993 please post the link you reference.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old May 16, 2012, 10:00 AM
Bonified Wingnut is offline
Find More Posts by Bonified Wingnut
United States, MI, Frankenmuth
Joined Jul 2007
http://www.headsuprc.com/servlet/the...h-06%29/Detail
Is the Heads up RC Link
This is where I find a lot of motors:
http://www.ebay.com/sch/i.html?_saca...ushless&_sop=1
Shhhh...it's a secret....lol
Bonified Wingnut is offline Find More Posts by Bonified Wingnut
Old May 16, 2012, 10:03 AM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
If I can't get tacon, I sometimes get stuff from Headsuprc.com never had an issue. Mostly smaller motors but they have been selling more larger motors too now. Definitly better than going eflite,. They get out os stock on stuff too though.
Old May 31, 2012, 07:35 AM
tubamike78 is online now
Find More Posts by tubamike78
tubamike78's Avatar
United States, OH, Monroeville
Joined Dec 2007
i had a magnet come loose on my monster power 160 last night. Is epoxy ok to use for re-glueing it or should i use something else?
tubamike78 is online now Find More Posts by tubamike78
Old May 31, 2012, 02:44 PM
Melnic is offline
Team Wack-a-Mole
Melnic's Avatar
Maryland
Joined Oct 2008
I'd use JB Weld if no one has any other suggestion. It does better with metals and does not tend to run.
Old May 31, 2012, 02:53 PM
RMS is offline
RMS
Find More Posts by RMS
RMS
RMS's Avatar
Westport, MA
I have used both JB weld and thin CA to repair lose magnets on other brand motors. I haven't had to do this on the MP motors yet.
If you use thin CA (which I DON'T suggest), make sure you let the motor bell sit with the hollow side down on something disposable for a day to make sure the excess CA drips out and has totally cured before re-assembling. Believe me, sloshing around thin CA in a large brushless motor bell is a real eye irritant and for me causes breathing issues since I have become somewhat allergic to it. Use it as a last resort.
RMS is offline Find More Posts by RMS
Old May 31, 2012, 03:09 PM
RedLine19k is offline
Find More Posts by RedLine19k
United States, OH, Youngstown
Joined Nov 2004
Haven't used it but Loctite 410 gets recommended
The small bottles seem tough to find tho
RedLine19k is offline Find More Posts by RedLine19k
Old Jun 03, 2012, 06:55 PM
wuest3141 is offline
Find More Posts by wuest3141
Tucson
Joined Nov 2009
Go with the watts of the motor, not the "size".
There are "Power 46" motors from leadershobby that will put out 1200 continuous watts (8 lbs of thrust) and will spike up to 2200 watts (14 lbs of thrust). These have more power than the Monster Power 60. The Monster Power motors tend to be low watt, and low kv ratings. I gave up using them for leadershobby Power 46 with a big 4S battery.
wuest3141 is offline Find More Posts by wuest3141
Old Jun 11, 2012, 06:35 PM
Shut up and Fly!!!
Joined Aug 2011
Great thread!
Old Jun 28, 2012, 11:11 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
After endless delays, the Tacon Bigfoot motors are back in stock at Hobbypartz.
Wish I had noticed this yesterday when they had the 10% off one day sale...
Prices are a little higher than before, though.
Thomas B is offline Find More Posts by Thomas B
Old Nov 25, 2012, 08:14 PM
Alex Schauer is offline
Find More Posts by Alex Schauer
Alex Schauer's Avatar
United States, MN, North Mankato
Joined Feb 2011
Yes, Yes, Old thread I know
Just putting a Bigfoot 32 in a 70" CMP Beaver. Want to run a 2 blade and 3 blade.
I have a 50A ESC. I will be easy on the throttle. Also running a separate BEC.
Just need some prop sizes. I've seen a lot of different things on this thread, and when I plug stuff into eCalc I'm not getting the same real-life results as I have seen posted here.
What is your personal reccommendation? I am going to try a 14x7 APC and a 13x8 3 blade Master Airscrew.
4S 4000 25C
Thoughts?
Recommendations?
Alex
Alex Schauer is offline Find More Posts by Alex Schauer
Old Nov 25, 2012, 08:50 PM
Xanadu is offline
Find More Posts by Xanadu
Xanadu's Avatar
Canada, MB, Winnipeg
Joined Nov 2006
With the combo you list, be best to to use a APC e, 12x7 2 blade. Or if you want a 3 blade, go with a 11x7. Either will give you over 3000 grams of thrust, compared to your 2600 gram airframe. Is also equlaivent of 612 watts power with 80% efficiency.
All done courtesy of ecalc.
Xanadu is offline Find More Posts by Xanadu
Discussion Anyone using an Exceed RC Monster Power 160? tlh101 Power Systems 16 Feb 22, 2010 08:13 PM
Question Monster Power outrunner brushless motor flylower Power Systems 10 Oct 25, 2009 08:14 AM
Question Monster Power 1.60 Motor bbmichael25 Power Systems 8 Jun 06, 2009 10:22 PM
