Old Jul 26, 2010, 02:57 AM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
No , mine met with a fence at Camperdown and I have not had a chance to fix it
steve wenban is online now Find More Posts by steve wenban
Old Jul 26, 2010, 03:48 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Bad Luck! How do you like it? It seems like a nice plane, and it fly's very well in Gonzalo's video. And good price too.
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Jul 26, 2010, 05:00 AM
Joined Dec 2003
Fly fast dont try to float it and its good slow it down to much and its a tip stalling fool
SteveW
Old Jul 26, 2010, 10:45 AM
gonzalo contrera is offline
Find More Posts by gonzalo contrera
gonzalo contreras
gonzalo contrera's Avatar
caracas
Joined Feb 2007
the secret..
Hi
Steve, how are you. sorry for the crash of your salto.. The secret of the flyfly salto, is more weight in the nose, The cg is wrong, are not in 6.1, it´s in the 4.5 cms of the leading edge when you fly with more weight in the nose, the stall of the tips, aren´t present in any circunstances.
Regards.
Gonzalo
gonzalo contrera is offline Find More Posts by gonzalo contrera
Old Aug 12, 2010, 12:55 PM
monamart is offline
Find More Posts by monamart
United States, TX, Spring
Joined Jun 2007
Hola Gonzalo..
Acabo de enterarme que hay una pagina de Venezuela aqui.. y lamento lo de tu planeador.. añoro los fines de semana volando en las Aguilas, definitivamente el mejor lugar en el mundo y con los mejores compañeros... ahora vuelo termico aqui en Texas,
Un abrazo por alla.. y estoy a la orden..
Mario Monaco.
monamart is offline Find More Posts by monamart
Old Aug 15, 2010, 07:35 PM
gonzalo contreras
caracas
Joined Feb 2007
No esel mio
Hola Mario
No, no es el mio, el que se estrelló fue el avión de Steve.. el mio esta sanito y volando. Saludos
Gonzalo
Old Aug 16, 2010, 10:51 AM
Chalo is offline
Find More Posts by Chalo
Chalo's Avatar
Santiago de Chile
Joined Dec 2005
Tocayo te envie un MP
Gonzalo Muñoz
Chalo is offline Find More Posts by Chalo
Old Aug 17, 2010, 02:39 AM
lassebetong is offline
Find More Posts by lassebetong
Joined Nov 2008
Hello.
I also have a flyfly Salto which I shall soon get into the air.
Have tried a couple of times before without much success.
I have mounted a towing hook on it and will use it for towing.
Was unfortunately no manual to my and therefore I know nothing about CG or recommending rudder.
Sincerely Lasse
lassebetong is offline Find More Posts by lassebetong
Old Aug 19, 2010, 05:11 PM
gonzalo contreras
caracas
Joined Feb 2007
the cg..
Hi Lasse
If you see the C.G. of the salto in the plans, it are WRONG, the correct C.G. of the flyfly salto is on 4,5 cms. from the L.Edge.
I recomend the use of two servos ( i use two futaba 3003 ) for the use of the elevator and ruder. If you aren´t shure about the movement of the elevator and/or ruder, use the switch of your radio ( D/R at 60 percent.)
Gonzalo
Old Aug 20, 2010, 07:55 PM
Joined Dec 2003
Unfortunaley I the CG has very little to do with the tip stall nature of this Model moving the CG forward will reduce the effect of elevator response Have you tried the dive test Gonzalo? also nose heavy in this model will cause it to flick rather badly at the top of the loop this is cause by the increased amount of elevator throw required to over come the weightand stalls out the tail very quickly , from memory my CG was set around 59 /60 mm mark Elevator response was excellent and it didnt have to move 25mm in each direction to achieve control . the throw where set at 15 mm in each direction and the rudder was as much as I could get I also had rudder mixewd at 60% to aileron with a trailing edge thickness of reflex set on the ailerons ,this helped to off set the tip stall on this model. Mine flew in this setup for 3 years before January of this year loosing an aileron servo on base turn put it sideways knife edge into a 5 strand barbed wire fence .
SteveW
Old Aug 25, 2010, 10:33 AM
Joined Nov 2008
Thx.
I se that you have different opinions about the CG.
My first and second try i had the cg set ~6cm so il think i go for 4.5 this time.
I recorded the first towing atempt, if you would like to se it.
Bogsering (3 min 19 sec)
Old Aug 25, 2010, 07:19 PM
Joined Dec 2003
My salto set at 5.7cm later changed to 6.0cm cause it felt nose heavy
http://www.rcgroups.com/forums/showp...07&postcount=1
SteveW
P.S But I do think you should go with what ever setting you feel comfortable with
Old Sep 01, 2010, 07:29 PM
gonzalo contreras
caracas
Joined Feb 2007
Hi Steve
Hi my friend. sorry for the delayed response
( in spanish ). El motivo por el cual yo adelanté el C.G. es para obligar a la punta del avión a que se mantenga baja en relación a la cola, al hacer esto, evito que el avión al girar haga el stall de punta de ala.
En lo personal, esta solución me ha servido y se puede apreciar incluso en algunas maniobras que el avión hace donde hubiese en condiciones de C.G. según los planos hacer el stall de punta de ala.
Saludos Steve.
Gonzalo
Old May 13, 2011, 04:58 PM
jason128 is offline
Find More Posts by jason128
New Zealand
Joined Jul 2009
Salto strengthening
gonzalo - Nice work in the strengthening.
I am about to do the same to my salto- using carbon fibre 200gm matt.
How much did your plane end up weighing once finished?
I want to know, so i can judge how much strengthening I should do to mine.
Jason
jason128 is offline Find More Posts by jason128
Old May 23, 2011, 12:41 AM
gonzalo contreras
caracas
Joined Feb 2007
with confidence
Hi
You can rebuild the hardware and use the carbon fiber to reinforce the structure... i use a light isocianate to mantain the tail structure and keep the wires of elev-rudder in ¨no movement¨.
Shure, you can send to me question about the bird, i can help to you. Is important the move of the CG to 4,5 cms. ( the plans have a mistake, is not 6 cms. )
Good Luck
Gonzalo
Discussion Salto H101 4m lighthorse Scale Sailplanes 2 Aug 11, 2006 09:29 AM
Help! Salto H101 Vietto Scale Sailplanes 3 Jun 01, 2006 06:51 AM
4.2m SALTO H101 by glasfluegal sprice50 Scale Sailplanes 0 Oct 13, 2003 09:09 PM
