Espritmodel.com Heli Air
Old Mar 13, 2010, 02:50 AM
alberta canada
Joined Nov 2009
mxc motor swap
Had some motors from the sh 6020 toy heli 7mm x 17.5, 2.5 grams the stock, 6mm x15mm 1.7 grams,looks identical to the 7mm motors used in the nine eagles bravo3.Have seen this done to a mxc on some other form,but he used a 240 battery can't find the post again.The wire colors are the same black&white,red&blue So I filed out the motor holders to fit the 7mms everything fit good, gear mesh, ect,start up, motors spun reverse,180 the motor plugs,spins the right way ,lift.The motors have more power,(lots more) but have to start slow if you go full will just stop,die.have to use at least 1/3 up, gas or will just stop (fall out of the air once flying)tried flying of and on for about 5min but was getting worse. No doubt I am frying my board,anyways anybody know if these motors are 0 timed (motors are glued in place) I have some options left, switch motor a to b, b to a seeing how I had to reverse the motor plugs to begin with,but before I start trying again any heads-up ?
chbronco is offline Find More Posts by chbronco
Old Mar 13, 2010, 12:50 PM
alberta canada
Joined Nov 2009
omit
Question Blade mXC c5eng Beginner Training Area (Heli-Electric) 1 Jan 05, 2010 10:09 AM
Discussion new canopy for mxc ? Chooby Coaxial Helicopters 8 Aug 28, 2009 10:12 AM
Build Log MXC from RNR tbroeski Sailplane Talk 75 Mar 13, 2008 10:40 AM
FS: Team Novak 410 MXc (20-140 amp ESC), unused don_craig Cars - Cars and Parts (FS/W) 1 Apr 11, 2005 02:36 PM
