Old Feb 12, 2013, 04:38 PM
FunPilot is online now
Find More Posts by FunPilot
All Thumbs
FunPilot's Avatar
Japan, Miyagi Prefecture
Joined Aug 2012
Nice!
Watch out for those trees though. Some of 'em will jump out and try and grab your plane!
Don't ask me how I know ...
FunPilot is online now Find More Posts by FunPilot
Old Feb 12, 2013, 04:40 PM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Originally Posted by zeezee View Post
Just a few pics of my maiden flight. Ordered me a set of E-flite Cub 25 wing struts today, still figuring a better gear setup that's still simple. I think the hair band is OK, but need a back brace. Dave/zeezee
Ok the airplane looks great but your realy rubbing it in flying with just a t shirt on when iam here in the chicago area freezing my ars off. joe
cracksmeup is offline Find More Posts by cracksmeup
Old Feb 12, 2013, 05:24 PM
robbthepilot is offline
Find More Posts by robbthepilot
Victoria B.C. Canada
Joined Aug 2007
R2 hobbies has a greta set of gear got under 4$. I have ordered 3 sets for the guys I fly with. One guy has them and they look great. Check them out.
robbthepilot is offline Find More Posts by robbthepilot
Old Feb 12, 2013, 07:32 PM
RMS is offline
RMS
Find More Posts by RMS
RMS
RMS's Avatar
Westport, MA
I was looking at the Champ 15e struts since they come with the jury struts......has anyone tried those?
RMS is offline Find More Posts by RMS
Old Feb 12, 2013, 08:31 PM
Phantom5.0 is offline
Find More Posts by Phantom5.0
Holy ___ there's 2 of 'em
Spokane
Joined Aug 2005
I've done some digging- but I decided it'd be easier to just ask. I am trying to decide between the Himax 3516-0840 that's recommended, or try out an E-Flite power 10.
Here's my stipulation- I am considering propping down to 11 or 12 inches to increase ground clearance, and increase the pitch to make up for it. I do not want to necessarily increase speed, I'd like to have plenty of torque available for short field and float work.
Thoughts?? Thanks guys.
Phantom5.0 is offline Find More Posts by Phantom5.0
Old Feb 12, 2013, 08:54 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Phanntom- get a Tacon Bigfoot 10 for $18.00 you will Never look back...
http://www.hobbypartz.com/96m601-big...20-1100kv.html
I have the Himax 3516-0840 ....way over priced...and I wanted a little more Ummph
The E-Flite is nice too But way over priced ( and Mind you...Most of my motors are the gold Axi's )
Keep your plane light enough and you can get off the ground in about a foot and a half is that SHORT field enough?
The big foot is JUST right !! @ for 18.00 if you dont like it..get somthing else...BUT I Promiss you will love it !! 12x6 prop & Order or buy a 5mm collet style prop adapter. I use a 60amp ESC. because I wanted too...also the big foot CAN fly on a 4s1p lipo too...but on the fun cub..Absolutly no reason for that.
I like mine soo much I bought a back up one too !! putting my $$ where my mouth is
Pat
Weed89 is offline Find More Posts by Weed89
Old Feb 12, 2013, 09:15 PM
cubcrafter60 is offline
Find More Posts by cubcrafter60
Wada ya mean, over engineered?
cubcrafter60's Avatar
United States, NV, Fallon
Joined Jul 2011
Weed89 - Just curious, Is your motor firewall mounted or intsalled like the stock installation? Also what would you consider the minimum size ESC for it? ~ Robin
cubcrafter60 is offline Find More Posts by cubcrafter60
Old Feb 12, 2013, 09:18 PM
jhark37 is offline
Find More Posts by jhark37
Flyr John in Floyd VA
United States, VA, Floyd
Joined Nov 2007
Do you have a direct link, please? Just on their website and couldn't find.
Thanks, John
jhark37 is offline Find More Posts by jhark37
Old Feb 12, 2013, 09:41 PM
Weed89 is offline
Weed89's Avatar
Joined Aug 2012
It is mounted Just like the original setup...BUT I did buy a Metal Motor Plate..
http://www.headsuprc.com/servlet/the...for-Fun/Detail
There is a cheaper 1 he carries..but I liked this 1..even tho' a bit expensive
the website's info on this motor is a bit confusing..They say 51a continuious...but I bet that is not correct...I would have to throw my watt meter on it..to tell you what it is pulling.
But like I said I used a 60A & it comes home luke warm to cool...
http://www.headsuprc.com/servlet/the...-60-Amp/Detail
Old Feb 12, 2013, 09:52 PM
Spokane
Joined Aug 2005
I'll check out the Tacon motors. They sound pretty good. Is the trade (kv for prop size) worth it overall? Sounds like it has no problems pulling off the ground in no time!
Old Feb 12, 2013, 10:00 PM
Weed89 is offline
Weed89's Avatar
Joined Aug 2012
Yes a smaller prop = much few prop strikes...the 13" prop would/Did break a few inches any time it struck the ground....so..good gear & smaller prop = better
PLUS- as these behind firwall setups make you put your prop adapter ON the Motor SHAFT....so, even with a 5mm shaft..too many prop strikes = BEND your motor shaft...I had to buy a arbor press to FIX/replace my shaft ...but thats a whole other story
and with a slightly higher KV motor 1100KV...there is about Nothing you cant do....from taking off Straight up....to flying as slow as a Slo-Stick...
Old Feb 12, 2013, 10:31 PM
Joined Jul 2011
Weed89 - Sounds pretty good, and for $18.85 hard not to at least give it a test fly! Got one on order - Thanks! ~ Robin
Latest blog entry: ParkZone Sport Cub S2
Old Feb 13, 2013, 05:23 AM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Two feet max with a Parkzone 480 and a 13" slowfly prop. Never have dinged the prop but then it had so much less weight forward.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Feb 13, 2013, 05:59 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Has anyone here seen a source for the stock FC landing gear wire, just the wire, nothing else?
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Feb 13, 2013, 06:22 AM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Thanks, John
Was listed back on post 8535
http://www.rcgroups.com/forums/showt...i#post20441105
But is now an error 404. Perhaps it has been discontinued or moved?
ltc is offline Find More Posts by ltc
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
