United States, TN
Joined Mar 2011
Ariticulated Landing Gear Add-On - Worth It?
Has anyone tried the articulated landing gear from: http://www.cublandinggear.com/
If so how do you like it, would you do it again? Does it bring any adverse problems to the FC? Thanks! |
itsme - I had them on my FunCub and I really liked them! Once you dial them in (I used O-rings) they behaved quite well. I replaced the stock hardware with stainless steel screws and locknuts. It is probably the heaviest gear option out there though - so if your looking at maintaining a low flying weight you may be better off modifing the stock gear. However, my FunCub flying with the stock recommended power package handled the additional gear weight without hesitation! I kinda trashed my poor Cub but the gear survived and they will be on my next FunCub!
![]() If you do a 'search this thread' search at the top of the page for - cublandinggear.com - there are several posts on this gear (including mine) that have additional information (weights, photos, etc.) ~ Robin PS - If you do go with them - Do try to resist doing excessively long touch and go's just to watch the gear 'work'! The gear handles it no problem but on our crushed rock runway my tires were beginning to show some signs of wear!
Joined Nov 2012
I am so glad the thread seems to be back on track. The gear you two are discussing are exactly the gear I have been looking into. Talked to the guy. I wouldn't mind a bit more weight and I know mine will handle it. Though the gear seem strong the foams not. What did you do to mount the gear? They must be very well made as they are hand crafted by Luddites who take great care in hand work and detail. As far as the thread going off course, it happens in all threads, but we need to get back on track quickly as to not ruin the credibility of it's purpose. Reading this thread got me to get myself a Fun Cub. Had it have been all over the place I would have never gotten interested in the plane. There is a place for everything in this forum. Thank's, Dave/zeezee...Tell me more of the HD Luddite gear.....
Latest blog entry: My wind killer
zeezee - Yes, my got rocks mod (see my blog) had the 'vee' sanded out of the bottom of the fuselage and was sheeted except where the gear mounted which was 1/8' ply. On my next install I'd install a plate on the inside as well and find a way to tie the two together! I've got to run, but if you have more questions I'll be back on this evening!
The gear are definitely made to order (hand made) and are of good quality, but dont expect a miniature set of Robart gear! ~ Robin
Been a while since I checked in on this thread. Shame there is so much off topic crap.
Had a FunCub for a few years. Good fun on land and water although after last outing I will be making the landing gear and floats a bit more solid.
For those who haven't seen this clip....Inspiring... http://www.vid4fun.com/video_player/index.php?vid=103 |
I like that look much better than the stock rubber bands. |
Itc - Early on I had a four springs on it but never flew with it that way. I used a total of six -223 O-rings. I started out with eight but she was a bit 'bouncy"!
My FunCub was a bit on the heavy side so you'll have to experiment a bit and find the right combo for your flying weight (I'd rather have too much than not enough in this case). If you picked up 6 ea. of the following sizes I'm sure you'd be covered for just about any weight configuration! One thing I didn't even start looking into is that these sizes are available in a variety of materials (silicone, Buna N, etc.) but I’d start with hardware store rubber O-rings and go to the more exotic compounds only if I had to! The last thing is that you've now added an inspection item - they will tear on occasion but more likely they will crack & deteriorate so you’ll need to add that to your list of things to check out before take-off! All three of these are 1 5/8" ID O-rings: -030 O-ring is 1/16" (.062") thick -130 O-ring is 3/32" (.093") thick -223 O-ring is 1/8" (.125") thick Good Luck! Hope this helps. ~ Robin |
Latest blog entry: For motor builders
| Thread Tools | |
| Discussion Fun Cub | sinowace | Hitec/Multiplex USA | 14 | Oct 09, 2011 04:43 PM |
| Discussion Multiplex Fun Jet at the lake | bah7566 | Video Piloting (FPV/RPV) | 31 | Jan 03, 2010 09:19 AM |
| For Sale Multiplex Fun Jet -- PRICE DROP | Toby W | Aircraft - Electric - Airplanes (FS/W) | 2 | Dec 28, 2009 09:51 AM |
| Video Multiplex Fun Jet FPV set up test | bah7566 | Electric Plane Talk | 0 | Dec 25, 2009 10:05 PM |
| Wanted multiplex fun-jet or trade! | heli123 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 14, 2009 11:02 AM |
