Old Feb 07, 2013, 09:43 AM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Originally Posted by Weed89 View Post
here are the new tires (rubber & Light) and New tailwheel.( old one was way too lite...and made plane hard to steer..+ styro tailwheel was all chewed up due to pavement.
Also, Added my 15 sized motor till I get new shaft.
See you painted the prop. A friend uses paint to balance the prop. Works good!
Rickflaguy is offline Find More Posts by Rickflaguy
Old Feb 07, 2013, 11:35 AM
cracksmeup is offline
Find More Posts by cracksmeup
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
Those wheels are about 65 grams a piece can you tell any differance in the way it flys or does it feel the same ? I might have to dust out the cob webs in my wallet and buy a set. joe
cracksmeup is offline Find More Posts by cracksmeup
Old Feb 07, 2013, 02:42 PM
mustflynow2 is online now
Find More Posts by mustflynow2
The Sequel
mustflynow2's Avatar
Australia, VIC
Joined Sep 2011
Mine still flys great, haven't flown it for ages, infact stole the 1100kv 3s motor from it for another plane. Only had a 750kv to replace so went to 4s 12x6, worked great. Awesome vertical climb and unbelievable vertical landings! What a great plane. Had a nice breeze to work into last night, love see it get sidways on approach.
mustflynow2 is online now Find More Posts by mustflynow2
Old Feb 07, 2013, 02:57 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Originally Posted by zeezee View Post
Weed, where did the L gear come from and are they much better? L gear and wing control rods(dia. too small)on the F Cub are it's only two bad issues. Dave/zeezee
I added the links on the wheel photos for the wheels and tailgear...I made the main gear useing the stock gear and fabricated the rest...somewhere in this thread is a how to pic tutorial.
lo I sometimes do that also...the prop paint is old now and pretty nicked up due to grass landings...I added them because I needed some COLOR on my plane
Well..the tail wheel is 100% better..the main are a tad bit more weight..BUT since i have plenty of power...it really dosent seem to make any flight difference....BUT the pavement likes the rubber MUCH better...these are low bounce wheels...and it actually dampens out the landings...and IS alot quieter...I Like them...but will still keep my foam 1's ...nothing will ever be lighter than they are
The New tires are a keeper for my taste and 64 grams for 4" rubber/alum. hubs...is really not very much...older dubros weigh quite abit more and have plastic hubs...I saw they had 5" 1's of these...but the weight was quite high.
while my .15 sized motor works quite well...will be glad to get my bigfoot .10 back in it...a higher Kv...it's like haveing another gear.
Pat
Weed89 is offline Find More Posts by Weed89
Old Feb 07, 2013, 03:08 PM
cracksmeup's Avatar
Joined Jun 2009
I finaly stoped jacking around and bought the recomended motor in blue writing and 45amp esc here .http://www.headsuprc.com/servlet/the...FUN-CUB/Detail
Old Feb 07, 2013, 06:10 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
They didn't have that motor when I got mine but I got everything else on the list including the ESC, a damn nice one! I used another motor they recommended with 80 KV more and 9 gr.'s heavier. Everything comes down cool to the touch, nice ESC !!! Using a 3S/2200/50C lipo, one of their's, EZ Flite. Mine is actually over powered.. Dave/zeezee
zeezee is offline Find More Posts by zeezee
Old Feb 07, 2013, 08:15 PM
LcJ is offline
LcJ
Find More Posts by LcJ
LcJ
Forever TMWT Pilot #11
LcJ's Avatar
United States, LA, Monroe
Joined Mar 2003
For $5 more and only .1 oz more, went for the 60, just in case I ever decide to go crazy with it. It does seem to be of good quality and they do give great service.
LcJ is offline Find More Posts by LcJ
Latest blog entry: RC Logger's Eye One Xtreme Quad
Old Feb 07, 2013, 08:16 PM
cracksmeup's Avatar
Joined Jun 2009
They must have had them back in stock cause they said they shipped every thing on my list. . Iam trying to save weight where ever i can but its hard to do with big plastic wing tubes ,i should have found carbon fiber ones to replace the plastic main spars but ,OH WELL next time. joe
Old Feb 07, 2013, 08:26 PM
cracksmeup's Avatar
Joined Jun 2009
JDMJim has the same motor and esc and i have seen his almost hover ,plus its still light on its feet and not heavy. I called him yesterday for the imfo .Its the first time for me buying anything from headsup rc and so far so good .I ordered at night and they shipped it first thing in the morning and they are only charging 2 bucks for shipping now. joe
Old Feb 07, 2013, 10:42 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
Joined Jul 2011
The plane will do exactly what it should. I used the fiberglass soars and they are fine. Make it too light and it won't fly well in wind
JDMJim is offline Find More Posts by JDMJim
Old Feb 08, 2013, 12:28 AM
David Hipperson is offline
Find More Posts by David Hipperson
Kilsyth, Victoria, Australia
Joined Oct 2003
cracksmeup,
I know we can all get worried about weight but unless you have a really specialised proposal for the FC weight isn't an issue. As said elsewhere I'm now on my second and in any reasonable breeze it will hover. It can glide tolerably well however weight isn't the issue but drag.
Just as is in still air it is great doing figure eights at head height or lower without any apparent tendency to stall out even at near walking speed. The FC as designed is a really remarkable foamy.
David Hipperson is offline Find More Posts by David Hipperson
Old Feb 08, 2013, 12:44 AM
907Jeff is offline
Find More Posts by 907Jeff
907Jeff's Avatar
United States, AK, Anchorage
Joined Feb 2013
Fuselage reinforcements
I thought maybe I should post what modifications I made to the front of the fuselage. I have flown probably 30 packs through it so far and no vibration problems yet. I used 4 pieces of carbon fiber rod which I pushed through the foam from the nose towards the tail. I then marked the rod and removed. I used my dremel to cut the rod, covered the rod with CA and shoved back into the hole I created. The top two exited right where the hatch opens up and the bottom two followed a longer path and just barely exited which you can see in the photo. After I finished the rods I enlarged the motor area with my dremel cut a path for the motor wires into the cooling channel with a large drill bit. Once I was sure I had more than enough room I layed 1/4 ounce fiberglass inside and outside the cowling using thinned out epoxy. This worked great to strengthen and cover up the grind marks from removing the dummy engine cylinders. Then I put a light coat of classic white forward of the window to cover the yellow epoxy.
907Jeff is offline Find More Posts by 907Jeff
Old Feb 08, 2013, 12:57 AM
907Jeff is offline
907Jeff's Avatar
Joined Feb 2013
Fuselage reinforcements part two
After painting just the nose classic white I put a light coat of flat black on top of the nose to simulate the anti glare paint so common on super cubs up here. On a side note the hobby shop had some super cub stickers from another kit that I used and am pretty happy with the look. I tried to stay as light as possible but I figured a little color would be exceptable.
Old Feb 08, 2013, 01:16 AM
907Jeff is offline
907Jeff's Avatar
Joined Feb 2013
Fuselage reinforcements part three
This definitely isn't in order but I thought it might help some make decisions on what they might use if not using the power pack like me.
Hacker a30-16m
Castle thunderbird 36
Thunder power 2100mah 25c
Spektrum ar600
2 hitec hs82 mg for rudder and elevator
4 hitec hs55's for the wing
13x4 Apc and 11x5.5apc
I have read alot of pages filled up with people disagreeing on what to use and I am only posting this because it is working great for me although I might upgrade the esc meter reads 31 amps full throttle with the 13x4 and less with 11x5.5.
Old Feb 08, 2013, 01:21 AM
907Jeff is offline
907Jeff's Avatar
Joined Feb 2013
Fuselage reinforcements part four
This is the make the foam plane look big photo lol
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
