Old Jan 22, 2013, 05:03 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Originally Posted by mjdee14 View Post
And after looking at it again, I realize there may be times when you increase differentail because the UP aileron is creating too much drag.
So how can you be sure the rudder is not causing this?...Never have figured out...when trimming a new plane...and it wants to turn left..I ADJUST more right aileron..until straight and level....BUT why would I not add RIGHT rudder instead?
now when doing a loop... its all messed up..... trim is easy Until areobatics are introduced.
Weed89 is offline Find More Posts by Weed89
Old Jan 22, 2013, 06:01 PM
Phoenex is offline
Find More Posts by Phoenex
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
I always start out with the control surfaces perfectly neutral before trimming. Before adjusting your aileron, you need to try doing loops straight into the wind adjusting the rudder until your loops are straight going up and coming out of the loop. Afterwards adjust the aileron. Planes like these with the big high wing typically need some rudder in the turn to help coordinate the turn. I start with 15% aileron to rudder mix working my way up or down until I am satisfied with the way the plane goes around the corners in varying wind conditions. Sorry if this has been covered before, I know this is a big thread.
Phoenex is offline Find More Posts by Phoenex
Old Jan 22, 2013, 06:47 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
I use a y-cable and no differential. Everything manual....need that skill...
JDMJim is offline Find More Posts by JDMJim
Old Jan 22, 2013, 07:31 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Hey guys, I ripped the gear off my Fun Cub and ripped the white mounting plate in half. I couldn't find any sign of replacement parts for the landing gear on the HH website.
Any suggestions?
IT's a clean break from the foam, the rest of the plane is in prefect condition
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 22, 2013, 07:42 PM
Watts cooking is offline
Find More Posts by Watts cooking
Watts cooking's Avatar
United States, CA, Corona
Joined Oct 2012
Any suggestions?
If you want to go back to factory it's really hard to find that part in stock anywhere. You could glue in a small square of 1/8 plywood and use landing gear straps to hold it down, peice of plastic screws down on either side of landing wire to hold it in place.
Watts cooking is offline Find More Posts by Watts cooking
Old Jan 22, 2013, 07:47 PM
You down with EPP?
Houston, Tx
Joined May 2009
So you are saying they sell that piece? IWOuld you happen to have a part number?
I love the stock setup, I flew it for about a year with no problems. But I hit a big rock, flying too low and knocked it right off.
UPDATE: I found the undercarriage set. Tower has it in stock.
Old Jan 22, 2013, 07:55 PM
Weed89 is offline
Weed89's Avatar
Joined Aug 2012
Any suggestions?
If you think the Plate will go back On ( puzzle like) Use White Gorilla glue...and keep it firmly inplace while drying ( you do not need to add any water either...Just use the glue very sparingly..as It foams as it dries.) And after about 3 hours or so..you can cut/scrape/pick..the foamed up parts off pretty easy..a day later..not so easy.
Or if the plastic is beyond re-use...Do Like watt said...embed some 1/8 ply...into the belly about the same size as the plastic peice was....but not triangular...try more rectangle....and then use Old fashioned gear mounting straps....oblong teflon/plastic/metal strips with a scre hole on either end..and it stradles the wire gear.
Fairly simple fix either way...and should not cause you futer issues
Pat
Old Jan 22, 2013, 07:58 PM
Joined Oct 2012
Glad you found it in stock they are hard to find.
Old Jan 22, 2013, 11:21 PM
marksp is offline
Find More Posts by marksp
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
Anybody happen to have the "wing spreader" (plastic female part that secures wing to fuse) for sale? I stripped the threads on mine and hate to spend $25 for the small parts bag just for a couple of plastic parts! Thx!
marksp is offline Find More Posts by marksp
Old Jan 22, 2013, 11:27 PM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
You could try filling hole with epoxy and thread in screw coated with some grease or oil . Work it when curing starts and you might get lucky. Can't remember what i did this on in the past but it worked.
gewiens is offline Find More Posts by gewiens
Old Jan 22, 2013, 11:52 PM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Originally Posted by zeezee View Post
1st one for me also, which caused a need in me to learn what it was and why. O.K., how do you tell if your plane needs it? My P-51 for instance, it does have some dihedral...Dave
http://www.pongo-air.com/flightguide.html print out the trim guide and go through the steps.
Most ail a/c adjusting the ail will adjust wings level, and if there is no built in elev it should track straight. using rudder will throw it off when going verticle. Of course on a 3 channel R/E only....you have no choice but adj the rudder. ideally all surfaces should be neautral and plane should fly upside down with little to no fwd stick needed, although most of fly a little on the nose heavy side for better control. What kills us is when there is a warp built in like a wing or tail....or the mfgr does a crummy job of setting up the incidence of the wing and/or stab....then no matter what you do your chasing gremlins. Motor thrust also has a lot to do with how it flys. This is the FIRST time I have ever had a motor mount I could easily change thrust angles. On my first outing I needed a lot more down thrust and a lot less right. Will still have to play with it on a windless day.
It's nice when a mfgr engineers the kit correctly and it flies nicely outof the box.
Rudder should be always in the center/neutral position....then go thru the trim guide http://www.pongo-air.com/flightguide.html and follow guidelines
mjdee14 is offline Find More Posts by mjdee14
Old Jan 22, 2013, 11:56 PM
mjdee14 is offline
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
If your talking about the part the nylon screw goes in to....get a "blind nut" of the correct size and glue to the bottom of the existing plastic, or get one with a new nylon screw that has the same threads and do the above.
Old Jan 23, 2013, 03:43 AM
aesmith is offline
Find More Posts by aesmith
Joined Apr 2010
That "adverse yaw" as it's called will always apply, equal aileron travel will cause yaw in the wrong direction. Whether it's a problem depends on other factors, for example long wings like a sailplane alway need some rudder to overcome it. as does the Rans S6 microlight for example even though it has about 2:1 differential.
The interaction with dihedral is subtle. Dihedral causes a yaw-to-roll coupling, which is how rudder elevator models steer. So let's say you apply Right Roll via ailerons, this causes Left Yaw, and the left yaw then induces Left Roll - directly opposing the aileron control.
aesmith is offline Find More Posts by aesmith
Old Jan 23, 2013, 05:27 AM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Left turn can be caused by the motor and prop too. Most models have a little down and right angle to compensate. If my ailerons are true, I initially use rudder trim. Never tried the loop but I will. As you slow and add power for a climb you should add a littler right rudder as you would use the rudder pedal if you were inside.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Jan 23, 2013, 09:05 AM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
I got a piece of thick plastic and ran a tap for threads, (Ace Hardware had one)
Then cut it and glued it in below the old one. I even thought of using wood.
And as was mentioned, getting a nut and securing it is a good idea.
Flybynight2 is offline Find More Posts by Flybynight2
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
