Old Jan 21, 2013, 12:19 PM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Originally Posted by zeezee View Post
I like the way you explained the way you setup your flap servo at Mid. for center. Seems like that will solve all problems and allow for max travel. Thank's, zeezee
Thanks....every once in a while I make it easy....hopefully.
I just got back from my second day flying the cub.....8-10 mph winds.....was fun landing in the grass with full flaps and almost coming down verticle. this plane handles wind real well compared to others I fly. I have been running a Dynam 13 x 6 cut down to 12.... but I think I need to try the 11 x 6 or maybe a 12 x 4. I really lilke the 4s but want to fly with 3 s also.....so need to get a smaller prop to help.
Flaps work great at settings I have above. Also the airleron diferential they recommend works nice also.....really axial rolls with no tail drift. I have to say Multiplex has done their homework in the flight stats on this plane.
What a difference landing on grass.....no bounce just nice landings. For those of you flying off grass....you have a winner in this plane. I have some big foam wheels coming to tame down the asphalt landings......as they say "it wasn't MY fault, it was the Asphalt" !!
mjdee14 is offline Find More Posts by mjdee14
Old Jan 21, 2013, 12:30 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Originally Posted by mjdee14 View Post
Where are you in TN? I find that flap settings are never the same from airplane to airplane in my radio. Make sure your flaps are ALL the way up,, no binding, then go midway and add till you get some down flap then go full and add more.
Right now my settings show
Norm 97% Elev 0%
Mid 0% 14%
land -80% 23%
think of it as Mid is really the center of the servo so it's at 0...then you go either way to either up/norm or land. It took 97% to get my flaps to be full up...that may change on yours depending on how tight you adjusted your flap rod to begin with.
I'm in the Maryville area. Thanks for the info!
itsme2 is offline Find More Posts by itsme2
Old Jan 21, 2013, 12:58 PM
zeezee is offline
Find More Posts by zeezee
Yea, I fly dusty planes..
zeezee's Avatar
United States, LA, Angie
Joined Apr 2009
Glad to know the aileron differential setup works well. This will be my 1st plane flying like that. After hearing a lot about it when I got the F Cub I understood why it is important. As far as flaps go if your plane is setup right as is (was) my big P-51, full drop flap deployment didn't cause any flight disturbances. Same with my H9 Pawnee. I do think that having all my planes flaps go down slowly does the trick. I have all my planes built now and ready to fly but until I can get someone to go out with me to my front 40 to fly, I'm grounded. I have a damaged fuel pump and air intake. I hate that damned camel , he lied!! I like building and tinkering though so all's well. ...Dave/zeezee....would differential help, work with my P-51 or all, any plane?
zeezee is offline Find More Posts by zeezee
Old Jan 21, 2013, 02:51 PM
bicyclemonkey is offline
Find More Posts by bicyclemonkey
bicyclemonkey's Avatar
Fayetteville, AR
Joined Jan 2010
OK, I'm new to the fun cub scene. Mine has been delivered but I'm still waiting on the electronics. What is the differential needed for in the fun cub? does the tail drag during banked turns?
bicyclemonkey is offline Find More Posts by bicyclemonkey
Old Jan 21, 2013, 04:27 PM
MayDay is offline
Find More Posts by MayDay
Egistered Ruser
MayDay's Avatar
Charlotte, NC
Joined May 2002
I’m thinking of ordering this plane, but before I do I’m trying to see if some parts I already have will work. I know it would be WAY overpowered but would the AXI 2826/12 be in the realm of possibility? Its 6.4oz… has the same diameter as the 2814/10 and is about 10g heaver than the Tacon 15… Any thoughts?
MayDay is offline Find More Posts by MayDay
Old Jan 21, 2013, 04:37 PM
Watts cooking is offline
Find More Posts by Watts cooking
Watts cooking's Avatar
United States, CA, Corona
Joined Oct 2012
The motor I'm using is 6.8 oz and It works great no need for any added tail weight or anything. I would go ahead and use the motor you have.
Watts cooking is offline Find More Posts by Watts cooking
Old Jan 21, 2013, 04:54 PM
MayDay is offline
Egistered Ruser
MayDay's Avatar
Charlotte, NC
Joined May 2002
Thanks Cooking! Feel much better about placing my order.
Old Jan 21, 2013, 05:02 PM
mjdee14 is offline
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
The aileron going down causes more drag than the one going up and can actually cause the a/c to vear in the opposite direction. When flying directly away from you do a roll if the tail looks more like a barrel roll diferential will help.. Limit travel on the down aileron and re-check until rolls are more axial. Not all a/c need differential.
Old Jan 21, 2013, 06:21 PM
Joined Oct 2012
No problem, and don't worry about a little extra weight the fun cub handles it well and the extra power is nice when towing gliders, aerobatics and any other things you want to do and it helps when the wind picks up. Welcome to the fun cub family you're gonna love this plane.
Old Jan 21, 2013, 07:27 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
You will be Just fine..and GLAD you have reserve Power.....my motor weighs 4.9oz...and I still slide my 2800 & 3000 mAh lipos forward a bit. So you MIght be just fine. < hmm + 1.5 oz should work just fine ) get your CG at the front Spar.
If you can keep the prop Under 13"...you will be happier..as 13" Flys great..But sometimes gets bumped On landing..& There goes about 1/2 inch of prop. 12x? & 11.5x? work very well with the landing gear..and only BAD landings will touch the prop.
Enjoy & Axi Motors are Very nice ( I have a bunch of them) But quite expensive..So Enjoy...you will love this Plane once you trim it out...DO TAILWHEEL upgrade if your still building tho'...Stll kick myself for NOT doing that 1.
Pat
Weed89 is offline Find More Posts by Weed89
Old Jan 21, 2013, 07:50 PM
MayDay is offline
Egistered Ruser
MayDay's Avatar
Charlotte, NC
Joined May 2002
Pat,
Thanks for the input on the motor... Definitely going with the tail wheel mod as well as mods to the main gear. Lots of good info here!!!
Old Jan 22, 2013, 10:53 AM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
almost done rebuilding my funcub, this time with the same 35-36 motor and 60 amp esc as before, but now with hxt900 servos all round, except for an hs85mg on the rudder. also using 2 2200mah 3s batteries instead of 1, and here's the part i'm excited about: fpv! i'm using a 250mw 5.8ghz fpv system and fatsharks, with homemade cloverleaf antennas. gonna do some fpv stol stuff... maybe find a scale river with a scale gravel bar to land on?
baconflyer is offline Find More Posts by baconflyer
Old Jan 22, 2013, 12:53 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
When the aileron goes down it creates more lift on that wing half. Lift causes drag. When the aileron rises it "spoils" lift reducing drag.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Jan 22, 2013, 04:41 PM
mjdee14 is offline
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
I would odinarily agree with you, but we are talking about why we need differential. As you say the aileron going down creates more lift acting like a "Flap", forcing the wing UP, the one going down acts like "Spoiler" and reduces lift forcing that wing down. So if we want to make a Right Turn, Right Ail UP, Left Ail DOWN and we feed in some Elevator and make a nice Smooth right Turn.
Now on some ships the aileron that goes down not only creates lift but also creates more DRAG actually making the nose of the airplane veer to the LEFT when we are trying to make a right durn......like a two engine airplane with one engine out.
So to fix this we limit the DOWN ail travel and it creates less drag, the one going up still forces that wing down and we make our turn. As I said before, not all airplanes need differential, this is actually the first one I have ever seen that has it in the set up specs
http://www.pongo-air.com/flightguide.html try this ling it gives you all the info you ever wanted to know about flight trimming
And after looking at it again, I realize there may be times when you increase differentail because the UP aileron is creating too much drag.
Old Jan 22, 2013, 04:50 PM
zeezee is offline
zeezee's Avatar
Joined Apr 2009
1st one for me also, which caused a need in me to learn what it was and why. O.K., how do you tell if your plane needs it? My P-51 for instance, it does have some dihedral...Dave
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
