Old Jan 16, 2013, 12:55 PM
mw757 is offline
Find More Posts by mw757
Canada, BC, Nanaimo
Joined Feb 2012
Originally Posted by Kimber View Post
Just flip the servo, off set the rod and make a new track for the wire!
Why make it so complex?
I hadn't seen you on this forum for a while...I just wanted to thank you for the elegant solution to enable Y cabling the flaps.
mw757 is offline Find More Posts by mw757
Old Jan 16, 2013, 12:58 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Originally Posted by mjdee14 View Post
Finished my FC tonight, . was surprised it takes the battery almost all the way up front to balance on the spar.
Using the Tacon Big 10 motor. Looking forward to having some fun with this...."thanks" to all on this forum for some great ideas.
Looks Good...You will not be sorry you did the tailwheel mod !
Supprised your battery is so forward...but it must be due to the Tailwheel mod.
you will LOVE the preformance with the BigFoot 10 I am useing a 11.5 X4 APC....it works great for my taste ( it came from a tip broken 13x4Apc..that I measured Cut Balanced....) it runs very smoothe...and I have a handfull of new props both larger/smaller/different pitch etc. But Love this 1 so much..I have not changed it.
I Also have a 3s1p 2800 (65c) & 3000 (50c) packs...both work perfect and I get aprox 8.2 min. mixed flying.
Let us know how your maiden goes & remember Flaps-R-UR-Friend
Weed89 is offline Find More Posts by Weed89
Old Jan 16, 2013, 01:30 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
You are very welcome.
We have been working on a couple other projects, weather
and family situation limit flying time these days,
Kimber is offline Find More Posts by Kimber
Old Jan 16, 2013, 01:36 PM
Roel_Netherlands is offline
Find More Posts by Roel_Netherlands
Netherlands
Joined Sep 2010
Flying with hobbyking snow ski's
Multiplex funcub: snow ski's (1 min 28 sec)
Note to myself, use a smaller prop when i fly with the ski's
Roel_Netherlands is offline Find More Posts by Roel_Netherlands
Old Jan 16, 2013, 02:38 PM
mjdee14 is offline
Find More Posts by mjdee14
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
Not sure why the battery is so far forward, maybe all the paint and wbp on the aft fuse and tail compensated for the up front weight. My tail wheel mod is pretty light. I made a double floor for the lipo to sit on, couldn't cram the ESC in there on the side to my liking, also did a quick LG mod.....no soldering required. Nylon thread from walmart and thin CA, believe me it won't break but it can be cut if you want to remove it. tried a few lipos......12 x 6 3s 2200 gave about 44 amps at 475 watts. tried a 4s but it went to 64 amps. Will get a 12 x 4 should be in the sweet spot of amps to power.
mjdee14 is offline Find More Posts by mjdee14
Old Jan 16, 2013, 04:15 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
Yea, ibwillvhave to step down to a 10x? For snow flying. But until it ever snows, my skis are hung up....
JDMJim is offline Find More Posts by JDMJim
Old Jan 16, 2013, 05:41 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
I have reposted this idea at least 2 times recently. It is a simple solution and free. was this your idea?
Rickflaguy is offline Find More Posts by Rickflaguy
Old Jan 16, 2013, 06:19 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
http://www.youtube.com/watch?v=9Ibb78G-qQk
Nice. Just want to say, good job on the vid. Most people would have posted a takeoff, bunch of lame flying around, then a landing. I like how you show just a couple takeoffs then a couple landings, without any unneccisary fluff in between.... touches like that are rare these days... Well done.
Also, I have never seen the transmitter cover thing you are using, where did you get it? I would like to fly in the winter but my hands get so COLD!
dacaur is offline Find More Posts by dacaur
Old Jan 16, 2013, 06:50 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Brad, my husband worked this out. he is cheap and likes
to find simple ways to do things when ever possible.
Old Jan 16, 2013, 08:20 PM
Joined May 2011
Cheap is an honorable trait and I wear it proudly but you do your husband a diservice in this situation. My scout troop is loaded with engineers from a major electronics firm (Harris corp).
Engineers have an expression for his modification. The term is elegant. Below is a definition. I assume number 2 applies to Brad and will leave it to you to judge number 1.
el·e·gant
/ˈeligənt/
Adjective
1. Pleasingly graceful and stylish in appearance or manner.
2. (of a scientific theory or solution to a problem) Pleasingly ingenious and simple
I use this opportunity to be somewhat pedantic both to praise your husbands elegance solution and to praise so many on this thread and so many others for their elegance.
Me, I plagiarize and I admire the elegance of those I copy. Here's to you boys and girls!
Old Jan 16, 2013, 09:08 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
I think you'll be just fine with that 12x6 as it will unload a bit in the air. Once the lipo drops voltage a bit you'll be well under 40a.
Don't think you'll care for a 12x4 on a plane like this...
Sammy70 is offline Find More Posts by Sammy70
Old Jan 16, 2013, 09:29 PM
Watts cooking is offline
Find More Posts by Watts cooking
Watts cooking's Avatar
United States, CA, Corona
Joined Oct 2012
Have you ever tried reversing the servo by re-soldering the internal wires of servo and keeping original mounting spot and linkage. By just swapping around a few wires the servo is reversed and you can use the Y-harness and everything works perfect. It's really easy to do if you haven't done it I'm sure there are some threads about it or I can post pictures and instructions.
Watts cooking is offline Find More Posts by Watts cooking
Old Jan 16, 2013, 09:41 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
@ dacaur
That's a Turnigy Transmitter Muff. Hobbyking sells them but they're almost always out of stock.
http://www.hobbyking.com/hobbyking/s...uff_Black.html
There's a guy here on RCG named Reacher10 that makes his own version. They're more expensive but the quality is great and you get to choose your favorite colors!
http://www.rcgroups.com/forums/showthread.php?t=1143460
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old Jan 16, 2013, 11:53 PM
mjdee14 is offline
mjdee14's Avatar
Nashville TN, USA
Joined Jun 2004
It's really pretty easy if you have a "small tip" soldering iron, would be tough with a big Weller or Sears soldering gun.....took about 10 mins after watching the video. Sometimes we do things in this hobby just for the pleasure of doing it. But it's always great to have an option especially for those that are not adventurists. It also never ceases to amaze me the inginuity that Rc'ers bring to the table.
Old Jan 16, 2013, 11:59 PM
Joined Oct 2012
Agreed if you have the tools and know how it easy and you're right it's pretty cool how creative we can get in this hobby to make things work.
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
