The airplane now has a reduced stall speed, and will stall at a higher AOA (angle of attack) and now lacks the crazy wing rock you would normally get at high AOA's with the stock funcub. It takes off shorter with less power now. it takes off just as short at half throttle now with them, as it did at full power without them. I also mainly noticed a high increase in aileron effectiveness. These are the main effects that iv noticed with the VG's. I tested by flying the plane without them and noted the characteristic at stall, slow speed, take-off distcance, etc.. then i immeditately went on installed the VG's, waited for them to dry (that took like 5 minutes) then went and flew again doing the same tests. And then i began noticing the effects.
You just eyeball it. lol. Spacing is not so crucial as much as the angle they are relative to eachother which should be about 45 degrees (roughly).
You row the VG's up at the 1/3 mark between the tallest part of the airfoil and the Leading edge of the wing. That is also crucial. |
United States, FL, West Melbourne
Joined May 2011
Here is a little inspiration for you guys. Don't try this at home.
http://www.vid4fun.com/video_player/index.php?vid=103 Dr John |
R n
| Thread Tools | |
| Discussion Fun Cub | sinowace | Hitec/Multiplex USA | 14 | Oct 09, 2011 04:43 PM |
| Discussion Multiplex Fun Jet at the lake | bah7566 | Video Piloting (FPV/RPV) | 31 | Jan 03, 2010 09:19 AM |
| For Sale Multiplex Fun Jet -- PRICE DROP | Toby W | Aircraft - Electric - Airplanes (FS/W) | 2 | Dec 28, 2009 09:51 AM |
| Video Multiplex Fun Jet FPV set up test | bah7566 | Electric Plane Talk | 0 | Dec 25, 2009 10:05 PM |
| Wanted multiplex fun-jet or trade! | heli123 | Aircraft - Electric - Jets (FS/W) | 0 | Nov 14, 2009 11:02 AM |
