Old Nov 18, 2012, 08:20 AM
Fviking is offline
Find More Posts by Fviking
Fly Seaplanes
Fviking's Avatar
Sandy Hook, CT.
Joined Jun 2009
Hi;
Drilling Stainless Steel is quite easy, as steel goes SS is quite soft.
Give it a try.
Fviking is offline Find More Posts by Fviking
Old Nov 18, 2012, 08:38 AM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Originally Posted by Fviking View Post
Hi;
Give it a try.
It is not so much that drilling SS is hard but it is a bit tricky to cross drill small diameter tubing without the proper tools. I was not at my home shop when I did this and only had a "V" block and drill press. A standard drill bit would contact the top of the round surface and start to walk off to one side. A center drill to get started would have cured that problem. I ended up fileing a small flat on the tube to give the drill someplace to start straight.
John
pmpjohn is offline Find More Posts by pmpjohn
Old Nov 18, 2012, 12:50 PM
SpeedsterDEN is online now
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Funcup
Funcup at work.
Funcup towing 4 meter Simprop Solution. (1 min 27 sec)
Not easy to get started due to heigh and soft grass.
S
SpeedsterDEN is online now Find More Posts by SpeedsterDEN
Old Nov 19, 2012, 08:01 AM
pokiou is online now
Find More Posts by pokiou
Australia, VIC, Coburg
Joined Oct 2007
Broke prop shaft today.. Are all prop shafts compatible with each other it has to be 4mm shaft for a 3536 motor damn got the landing wrong something i never do .
pokiou is online now Find More Posts by pokiou
Old Nov 19, 2012, 10:58 AM
LcJ is offline
LcJ
Find More Posts by LcJ
LcJ
Forever TMWT Pilot #11
LcJ's Avatar
United States, LA, Monroe
Joined Mar 2003
Probably just a weak or flawed shaft.
But on the positive side, it might have been like a shear pin and saved even worse damage. Always a positive side.
LcJ is offline Find More Posts by LcJ
Latest blog entry: RC Logger's Eye One Xtreme Quad
Old Nov 19, 2012, 11:34 AM
electrich is online now
Find More Posts by electrich
65 Buick =make my own thermals
electrich's Avatar
United States, GA, Atlanta
Joined Feb 2011
Originally Posted by lcj View Post
probably just a weak or flawed shaft.:d
but on the positive side, it might have been like a shear pin and saved even worse damage. Always a positive side.
+1.
electrich is online now Find More Posts by electrich
Old Nov 19, 2012, 12:14 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Some crossover but often they are specific for your motor.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Nov 19, 2012, 12:26 PM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Got some GREAT flying in this weekend with my FunCub at our cabin on Lake Margrethe in Grayling, MI. What a great airframe, I have the recommended power system and was actually getting 30min flights with my my nano-tech 3300mah packs! My original APC 13x4 prop broke when the tip caught a rock on shore.....so I switched to an APC 13x6.5, I couldn't notice any difference, but I was only doing slow lazy flying all weekend. Here's a couple pics my girlfriend took with her phone, I thought they turned out pretty cool. Ill try to post the videos shortly.
JGuilty13 is offline Find More Posts by JGuilty13
Old Nov 19, 2012, 12:32 PM
35Mhz is offline
Find More Posts by 35Mhz
Complete the Illusion!
35Mhz's Avatar
UK South Coast
Joined Oct 2003
plenty 3536 shafts from herehttp://www.rctimer.com/index.php?gOo...7&productname=
35Mhz is offline Find More Posts by 35Mhz
Old Nov 19, 2012, 02:16 PM
funclub is offline
Find More Posts by funclub
Germany, BW, Gosheim
Joined Nov 2012
FunCub Battery Rack
Hey I would like to introduce You my Battery Rack for the fun cub. When i made the first flights i was so surprised about the fantastic flying behavior of that plane.
The only thing which made me crazy was the handling of the battery exchange.
Thats´s why I developed the battery rack, which makes the battery exchange so easy and so fast.
Have a look here on Youtube:
FunCub Multiplex easy Battery Change within seconds (0 min 54 sec)
The video shows the exchange. Changing the battery with one hand and filming with the other.
And By the way I would like to show you my flying around in winter at my home place with skis on the fun cub. It is so cool:
Fun Cub MPX Snow Ski (3 min 21 sec)
The funcub is so amazing and so easy flying....
Nice Greetings from Germany (awaiting the next snow, and Your comments)
funclub is offline Find More Posts by funclub
Old Nov 19, 2012, 02:41 PM
Joined May 2010
How not to give start help, when the glider is stuck in the high grass
RC glider towing, start help. (0 min 24 sec)
Due to heigh grass and soft ground + the small wheel at the 4 meter glider, the Funcup needed a little start help.
Imagine him walking into the hospital with a 4 meter glider stuck where the sun dont shine.
Normal procedure is that the helper runs to the side, but when he saw the camera he got the stupid idea to throw himself to the ground.
Fortunately, the glider took off at the last second.
And he promised never to do that again.
S
Old Nov 19, 2012, 03:55 PM
35Mhz is offline
35Mhz's Avatar
UK South Coast
Joined Oct 2003
Funclub,
Are you marketing your Battery racks?
Old Nov 19, 2012, 05:26 PM
Joined May 2011
Originally Posted by funclub View Post
FunCub Battery Rack
Have a look here on Youtube: http://www.youtube.com/watch?v=p6Dtl0vCXEA
http://www.youtube.com/watch?v=q-U7fs01Gu8
You have plans?
Old Nov 19, 2012, 05:52 PM
prairie boy is offline
Find More Posts by prairie boy
Joined Nov 2004
Funcub Painting
When you paint the Funcub, is it necessary to mask any parts to be glued with the CA, or will the CA penitrate the Krylon Short Cut paint well enough to get a good solid joint?
prairie boy is offline Find More Posts by prairie boy
Old Nov 19, 2012, 07:25 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
I masked areas to be glued just a precautionary measure
greedyg76 is offline Find More Posts by greedyg76
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 05:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 10:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 10:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 11:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 12:02 PM
