Old Nov 11, 2012, 08:44 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
@pmpjohn Nice...looks like you added struts and Guidewires too ...wish I had seen theese sooner...I would have poped for a pair....did the axel come with the gear?
Weed89 is offline Find More Posts by Weed89
Old Nov 11, 2012, 08:58 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Originally Posted by pmpjohn View Post
This is the replacment gear for the E Flight Super Cub 25e. All of $17.00 from HH. The three pieces marked with red arrows need to be shortened and redrilled to fit the narrower FC fuse. I embedded two pieces of maple motor mount stock across the fuse to screw the gear to. I also openned the bungee cover and removed one of the "O" rings for better action on the lighter FC.
John
Do you have to cut and weld those pieces?
itsme2 is offline Find More Posts by itsme2
Old Nov 11, 2012, 09:50 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
The axles were shown in the pics on HHs site but were not in the package. I used 4mm bolts for axles.
The three pieces pointed out in the pic needed to be cut shorter and redrilled but no welding was required. A bit tricky cross drilling stainless tube that small in diameter. Even useing a drill press and a "V" block I had to file a small flat to get the hole started in the center.
It's a shame that she was last seen sitting in a tree top at the Triple Tree Aerodrome.
John
pmpjohn is offline Find More Posts by pmpjohn
Old Nov 12, 2012, 01:48 AM
pokiou is offline
Find More Posts by pokiou
Australia, VIC, Coburg
Joined Oct 2007
I'm about to throw out this motor and esc and just buy the power pack.
Pulsing motor still no idea why!!! (0 min 29 sec)
pokiou is offline Find More Posts by pokiou
Old Nov 12, 2012, 04:10 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Have you tried a smaller diam' prop? tried different esc timings ?
if you have then look for a bad connection and sometimes can be internal motor windings shorting out.
olmod is offline Find More Posts by olmod
Old Nov 12, 2012, 04:20 AM
pokiou is offline
Joined Oct 2007
Yea, I've tried all different props.
Old Nov 12, 2012, 04:46 AM
Aus is offline
Aus
Find More Posts by Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Australia, ACT, Amaroo
Joined Jul 2011
http://www.youtube.com/watch?v=1ZZjlmv65jk
Mate, if you feel like a drive down my way this weekend, we can swap components between our FunCubs to isolate your fault. Mine runs great with the power pack motor (HiMax) and a 60A Plush ESC.
Send me a PM if you're interested, Aus.
Aus is offline Find More Posts by Aus
Old Nov 12, 2012, 05:41 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
In that case I would borrow an esc and try that.
Old Nov 12, 2012, 08:28 AM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
John
Nice gear. Can't find it. A link to it? OK Thanks, Don't know why it didn't come up in the search?
And not a bad price. I probably have $12 in Music Wire plus shipping.
And Yes I believe the Foam is a tree magnet.
Flybynight2 is offline Find More Posts by Flybynight2
Old Nov 12, 2012, 09:05 AM
pokiou is offline
Joined Oct 2007
Point cook? That's a fair drive . However i might have to take you up on that offer .
Old Nov 12, 2012, 01:14 PM
Weed89 is offline
Weed89's Avatar
Joined Aug 2012
here is the link
http://www.horizonhobby.com/products...-25e-EFL460016
Old Nov 12, 2012, 03:13 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
I did not see the voltage dropping to 8.x volts as you had mentioned earlier. Or anything at all under 11 volts. Different battery? In any case, if you want to throw out the motor, go ahead. But the problem really is the ESC. Please do throw it out, put in one that works and get on with flying.
Regards,
Gord
Gordks is offline Find More Posts by Gordks
Old Nov 12, 2012, 03:20 PM
Gordks is offline
Joined Mar 2010
John
That looks like the answer to me. Although I am happy with the stock gear I really like the looks of that set up. Do you happen to recall what it weighs? There is no mention of that on the Horizon site.
Regards,
Gord
Old Nov 12, 2012, 04:34 PM
pokiou is offline
Joined Oct 2007
Regards,
Gord
Yea, i'll keep the motors and just throw the ESC out . What esc do you suggest?
How are the Maytech ones?
Old Nov 12, 2012, 05:26 PM
Gordks is offline
Joined Mar 2010
How are the May tech ones?
I am afraid I don't know about Maytech, but one of the first pages I read after searching on them has an interesting statement in red a few lines from the top of the page. Looks like they might be pretty good! http://montorc.com/mt30abec.aspx
For the most part I have only used the Plush series from Hobby King in multiple sizes. No problems with them normally, but they were not compatible with a Hacker motor due to timing problems. Also a Hacker X-40 SB Pro (works great with that Hacker motor), and a few ZTW brand, which might be hard to find, but are good. I will be using them from here on unless I run into some problems. The only one I have had really bad experiences with is the Hobby Wing Pentium 40. One of them could not get any motor turning, even without any prop. They just vibrated and made noise.The other did exactly what your is doing. The really odd thing is that the Plush series from HK, that I have had no trouble with at all, is supposed to be made by Hobby Wing. So maybe Hobby Wing just had a bad series of the Pentium 40. Don't know, but they were the only Hobby Wing brand ESCs I have ever tried and they didn't work. As a result I will not be using any further Hobby Wing.
Regards,
Gord
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
