Old Nov 05, 2012, 04:09 AM
grand14 is offline
Find More Posts by grand14
Joined Oct 2012
Im gething this one http://www.hobbyking.com/hobbyking/s...ner_Motor.html is it ok to use on the fun cub? Not to heavy or somthing like that?
grand14 is offline Find More Posts by grand14
Old Nov 05, 2012, 06:32 AM
electrich is offline
Find More Posts by electrich
65 Buick =make my own thermals
electrich's Avatar
United States, GA, Atlanta
Joined Feb 2011
Will be fine.
electrich is offline Find More Posts by electrich
Old Nov 05, 2012, 10:04 AM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Is this articulated landing gear add-on overkill and/or too heavy for the Fun Cub: http://cublandinggear.com/
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Nov 05, 2012, 11:10 AM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
NOW I KNOW!
Flew with the original owner. The reason it is so hard to balance is he added tungsten weights to the tail under the tail gear. Glued in. I wand them out so i guess it's careful dremel time.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Nov 05, 2012, 06:38 PM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
Why a Dremel? Won't an X-acto do it? Cut out the foam around the weights, remove the weights and glue the foam back in.
Ron Williams is offline Find More Posts by Ron Williams
Old Nov 05, 2012, 07:01 PM
Watts cooking is offline
Find More Posts by Watts cooking
Watts cooking's Avatar
United States, CA, Corona
Joined Oct 2012
Originally Posted by Flybynight2 View Post
Thanks for all the ideas. Will try them when I get a chance.
No, didn't look at RX it is buried.
Yes, went wild. rocked right and left, and nose down. I didn't have any control.
I ranged checked another plane and flew it as far as I could see today.
I was wondering about the ESC, But a separate UBEC powers the servos, that is why I checked it. I was thinking maybe it is going out and gets warm and fails.
Again Thanks.
Range checking on another plane and trying to compare to another isn't the best. Depending on placement of rx and where it's situated inside the plane can make a difference in range. You said you were flying 5-7 minutes which depending on battery size might be hitting low voltage cutoff and cutting out on you like previous posters eluded too. The longer flying time might also be over heating it like you said. Range check on the plane your having problems with and all the voltage tests like others had said and you should be able to find the problem.
Watts cooking is offline Find More Posts by Watts cooking
Old Nov 05, 2012, 07:16 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Thank you!
Beautiful looking and functioning gear !!! BUT $$$$ 50.00 + on a set of landing gear for a $119.00 Plane is not somthing I can afford to do... I would have loved them..perhaps overkill..and a tad heavy? but SURE do look nice
Would love a giant set of trexler tires tooo but again too $$$$$
Weed89 is offline Find More Posts by Weed89
Old Nov 05, 2012, 07:43 PM
electrich's Avatar
Joined Feb 2011
+1. Overkill for sure and way too expensive for a foam cub. It flies slow enough to settle in easy for landing and gear can be reinforced with a 99 cent piece of music wire if you desire.
Old Nov 05, 2012, 07:56 PM
Joined May 2011
Did just that. I dug 4 tungsten fishing weights out. My old scal measures them between .4 and .5 ounces. Should balance nicely now.
Going to fill the holes with some bass wood dowels so I can screw on the plate for the tail wheel. I am goping to close up two of the holes with a PVC thin pipe so I can add weight in the future. (just in case)
I love the way she flies with a minimal engine and a smaller battery. The Power 15 was cool but the slow flight prop and a 960 KV plastic 480 with a 2200 is a joy. to fly. I'm going to try it with a 1300 next!
Old Nov 06, 2012, 07:39 AM
SLCPilot is offline
Find More Posts by SLCPilot
Stillwater, Oklahoma
Joined May 2004
I was proud of this boom for holding the GoPro. Has this been done before? My next step will be to put it on a rotating boom to get the perspective from all directions!
Multiplex Fun Cub Midair Collision! (2 min 44 sec)
Cheers!
SLCPilot
SLCPilot is offline Find More Posts by SLCPilot
Old Nov 06, 2012, 09:29 AM
ddruck is offline
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
Cool video, 'nice' friends you got there.
Yes it has been done with the extension pole, Crazy Horst has been doing these type of videos with go pro in many positions, including looking back on a stick, his stuff is incredible, excellent editing, plus he is excellent flier to boot, very entertaining.
https://vimeo.com/user6527917
http://www.youtube.com/watch?v=fdhlK...ature=youtu.be
Cheers!
SLCPilot
ddruck is offline Find More Posts by ddruck
Old Nov 06, 2012, 10:21 AM
mavlo77 is offline
Find More Posts by mavlo77
mavlo77's Avatar
The Netherlands
Joined Oct 2008
+1 too... After 1.5 years my funcub still has the stock gear. Even the tail wheel is OK. And I fly with it nearly every weekend, and not always in the best conditions...
But I think it has been discussed earlier that the quality of the wires vary. Must be, because I can't understand how some LG's bend so easily.
mavlo77 is offline Find More Posts by mavlo77
Old Nov 06, 2012, 10:22 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Cheers!
SLCPilot
Wow, at 1:30.... Creative landing procedure... ...
Old Nov 06, 2012, 10:43 AM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
Same here. the only problem i've had with the lg on the funcub is that even when I glue it into the plastic mount with lots and lots of epoxy (and of course the mount is securely glued to the fuse) the wire landing gear just pops out of it's holder every couple flights (i'm flying on 4" dry grass with lots of rocks, though)
baconflyer is offline Find More Posts by baconflyer
Old Nov 06, 2012, 12:04 PM
Flybynight2 is offline
Find More Posts by Flybynight2
Will it ever Fly?
Flybynight2's Avatar
United States, AZ, Beaver Dam
Joined Nov 2011
Same field here, never had it pop out.
But got tired of rebending it back.
Made new.
Flybynight2 is offline Find More Posts by Flybynight2
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
