Old Oct 23, 2012, 06:04 AM
marksp is offline
Find More Posts by marksp
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
Originally Posted by pokiou View Post
i just need a quick fix for my funcub so i can run on 3s's lol. I'll be ordering a multiplex power kit and i guess you can never have to many esc and motors laying about :P, Plus i might just throw one in a ARTF kit till i decide what it needs.
It seems this kit is actually a rebranded Hobbyking esc and Turnigy motor. So i think thats pretty good.. I mean for 50 bucks im getting the Tuning car motor and 60a esc right.
If you're referring to the Fun Cub Multiplex Power Pack MPU993243, it includes a Himax motor and a Castle Thunderbird 36a ESC, plus APC prop & misc. hardware.
marksp is offline Find More Posts by marksp
Old Oct 23, 2012, 07:28 AM
pokiou is offline
Find More Posts by pokiou
Australia, VIC, Coburg
Joined Oct 2007
I was talking about the the Aeolian 3536 KV1000 - Evolution 60A with progaming card. But what do you think is causing the pulsing in the video i posted?
pokiou is offline Find More Posts by pokiou
Old Oct 23, 2012, 08:36 AM
Fviking is offline
Find More Posts by Fviking
Fly Seaplanes
Fviking's Avatar
Sandy Hook, CT.
Joined Jun 2009
The speed control can't handle the Amp load and is cutting out.
Try a 30A ESC or even a 40A you will be fine.
My FunCub flies much better with a 12X6 than a 11X5.5. I have a 35X36 1150Kv motor.
Good luck
Fviking is offline Find More Posts by Fviking
Old Oct 23, 2012, 09:17 AM
pokiou is offline
Joined Oct 2007
the ESC i have is 40A...
Old Oct 23, 2012, 12:11 PM
Weed89 is offline
Find More Posts by Weed89
Weed89's Avatar
United States, CA, Thousand Oaks
Joined Aug 2012
Ok it's still doing it on a smaller
This time i made a video
you really need to use a watt meter on it...to make sure it isnt useing more amps than the esc and motor are rated for...(it will also give you Very useful info on your setup/prop selection etc) .... Also, How hot did the motor & Esc get ?? I didnt see you report that info...and in that short test, Did the lipo get warm? all this info can add up to a place to look at first.
But with that said I Might guess...your lipo is 20c(did it get warm..or even hot?)...perhaps that is the weak part of your system...the motor is trying to pull MORE than your 20C lipo can supply...therfore cutting out....(it is a big motor/prop...and sounds like it is drawing amps like crazy..Perhaps more than your 20C lipo can handle)
If you know anyone with a higher rated lipo See if they will let you test it.( that would be a FREE test )..dont run out and buy 1 just yet because it might not be your Solution....Get a watt meter
Good luck, and keep us posted with what you find out
Pat
I promised my self to Never buy lipos under 40C from now on...and preferably all 65C....banana sell 65C lipos a are crazy good cost...but they are always out of the 1's I want ...I just bought 2 3s1p (65 c) 2800 packs for $35.00 each...I feel that is resonable and these suckers should work nice in my FunCub once I get all my parts to build it <going the power pack sold for this plane> but if it ever poops out I will replace it with the motor Jeff @ Headsup RC sells for this plane..it would have saved me $$$ I also would have a larger ESC than the thunderbirs 36A...ohh well...I like the way their power setup flys..a coulpe folks out here have them.
Weed89 is offline Find More Posts by Weed89
Old Oct 23, 2012, 12:57 PM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
HeadsupRC is a fantastic source for motors and their response to email questions
is top notch. This is one of those companies that is on my good guys list.
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Oct 23, 2012, 12:58 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
http://www.youtube.com/watch?v=YFCmz_rqdJY&hd=1
I will say this only one more time and then keep my mouth shut until you figure it out for yourself. You have a defective ESC. That is exactly the way mine acted. It was fine for a week then began to sound exactly like yours, getting worse as time went on. Exactly the same ESC. BTW, that is exactly the same battery that I have been using in my Funcub and it is plenty strong to fly this plane. Never overheats. That battery should be good for 44 amps continuous with 66 amp peaks. Your ESC would be smoking if you were pulling that much current, so unless that battery has been in use for a very long time it is more than sufficient. Even if the battery were tired it would not result in a sound like that. I have tried to help. Hope you get it fixed.
Gord
Gordks is offline Find More Posts by Gordks
Old Oct 23, 2012, 01:58 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
last weekend.
"That's a Funcub?! those wheels are huge!!"
As my plane goes lumbering over the grass to takeoff.....this plane never ceases to amaze. even did some formation hovering with a brushed Twinstar.
JDMJim is offline Find More Posts by JDMJim
Old Oct 23, 2012, 02:05 PM
knifeedge63 is offline
Find More Posts by knifeedge63
There is Victory in the Lord!
knifeedge63's Avatar
United States, GA, Locust Grove
Joined Feb 2011
a hovering BRUSHED twinstar???
knifeedge63 is offline Find More Posts by knifeedge63
Old Oct 23, 2012, 02:13 PM
ddruck is online now
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
How many amps are you pulling? My glider did the same, the battery could not keep up, my ESC was fine, after I went to higher C rating battery, or a new one, it never did it again. But if that is not it, then ESC can be defective, either way the motor is not getting enough 'juice', as they say.
ddruck is online now Find More Posts by ddruck
Old Oct 23, 2012, 02:16 PM
Raften is offline
Find More Posts by Raften
NorCal
Joined Dec 2009
Blu
I just put my first order in to them as per the good reports such as yours.
Raften is offline Find More Posts by Raften
Old Oct 23, 2012, 02:30 PM
Rescuejim is offline
Find More Posts by Rescuejim
I can crash anything
United States, TX, Fort Worth
Joined May 2012
Blu
+1
Great guys!
Rescuejim is offline Find More Posts by Rescuejim
Old Oct 23, 2012, 02:46 PM
Weed89 is offline
Weed89's Avatar
Joined Aug 2012
HeadsupRC = The best service around...great prices...$2.00 shipping ...I actually Like the quality of his products too....only had motors wearer from Long useage...you will get your stuff in 3days or less
Old Oct 23, 2012, 03:56 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Had an esc that wouldn't work and got a replacement right away. They told me to keep it.
Immediate customer service answers until late at night.
Good quality products.
Cheap shipping
OR
Buy from overseas and pay a little les with none of the above.
Overseas meaning China. I have yet to buy from our neighbors over the Atlantic but try to get an answer from over there and forget warantee!
Rickflaguy is offline Find More Posts by Rickflaguy
Old Oct 23, 2012, 05:07 PM
pokiou is offline
Joined Oct 2007
Gord
Hey Guys,
Ok, im just trying to rule everything out. The ESC works fine with a 2s 30c battery. I will try another esc and motor and see if that resolves the issue. Atm i cant test with a watt meter as i dont have one .
I will have to invest in one as it seems like a tool to have .
Thanks everyone.
I forgot to add that the ESC remains very cool and so does the motor and battery. There is no sign of heat up. I guess ill just wait for the new ESC and motor combo. ATM she flies amazingly smooth on 2s batteries. Just cant do vertical climbs :P and very very quick accelerations of things go tits up.
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
