Old Oct 13, 2012, 02:54 AM
Donut1 is offline
Find More Posts by Donut1
USA, MI, Coloma
Joined Aug 2010
Softer same size wheels
Hi I'm new to the funcub. Is or has someone ever changed the big hard foam wheels to a softer same size wheel that is a soft foam wheel so it will absorb the hard surface and not bounce so bad on hard surfaces and handle better.
Thanks;
Doug
Donut1 is offline Find More Posts by Donut1
Old Oct 13, 2012, 03:29 AM
Boreel is offline
Find More Posts by Boreel
The Netherlands, UT, Amersfoort
Joined Oct 2012
Thanks;
Doug
Hi Doug,
well I've been thinking about that one too but haven't succeeded in finding a pair here (Netherlands). Guess the issue will be the weight...don't know.
Would be great though if it is possible, just change the wheels and done, (whenever road landing is needed).
Greeting and enjoy your FC
Boreel is offline Find More Posts by Boreel
Old Oct 13, 2012, 06:35 AM
A Rdnek is online now
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
Originally Posted by Boreel View Post
Hi Doug,
Trexler makes very good wheels and tires for the FC. They are lite and very soft and work great, but they are very heavy on your wallet.
http://www.trexlerballoonwheel.com/
Rn
A Rdnek is online now Find More Posts by A Rdnek
Old Oct 13, 2012, 07:23 AM
RGose is offline
Find More Posts by RGose
RGose's Avatar
United States, TN, Knoxville
Joined Dec 2003
Rn
Ouch! Trexlers used to be reasonable. I sold a Speedy Bee kit a while back and threw in the Trexler's I had for it as a bonus, not knowing they were gold.
The Speedy Bee was kind of a bush plane itself and I recall Andy Clancy offering some extra heavy duty Trexlers which i bought. The Speedy Bee also used an inflatable tailwheel and some folks even added RC buggy shocks to the landing gear.
RGose is offline Find More Posts by RGose
Old Oct 13, 2012, 09:27 AM
wjjones is offline
Find More Posts by wjjones
wjjones's Avatar
Joined Jun 2001
Thanks;
Doug
A few months back someone posted a link to some Hobby King tires that fit the FC. I bought some, but I decided to leave the stock ones on because the HK tires are a little narrower, and the hole in the wheel is a mm or two bigger than the stock wheel. I didn't feel like shimming the the HK wheel to make it fit.
FWIW, I have come to appreciate the stock tundra tires. They are intended for rough surfaces and they handle them well. I also bought material to modify the landing gear, but while procrastinating, I just flew the crap out of the FC and now I don't see the need. After a while I just learned to takeoff and land with a minimum of ground loops and bouncing.
wjjones is offline Find More Posts by wjjones
Old Oct 13, 2012, 01:17 PM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
My Fun Cub has an eflite power 15. The builder says the way he eliminated the vibrations is by "glassing" inside the cowl with fiberglass cloth and thin CA.
I want to downgrade the power set. What would be an acceptable motor for the Fun Cub. If I want fast I can go to the Stryker. Looking for thrust and lighter weigh. Something I can drive with a lighter 1300 batt.
Let me know if I am heading in the wrong direction bur it just seems way too heavy with a 15 and 3300 batts.
Rickflaguy is offline Find More Posts by Rickflaguy
Old Oct 13, 2012, 02:35 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Have a look at the Fun Cub floor stiffener kit here if you want to easily reinforce your firewall & engine mount: http://morganmill.com/RC/FunCub_Parts.html
itsme2 is offline Find More Posts by itsme2
Old Oct 13, 2012, 05:58 PM
Banhas is offline
Find More Posts by Banhas
Joined Oct 2011
Another video of tonight´s flight in the dark. It´s fantastic.
FunCub Leds 2 (3 min 54 sec)
Banhas is offline Find More Posts by Banhas
Old Oct 13, 2012, 06:44 PM
bubbleman is offline
Find More Posts by bubbleman
bubbleman's Avatar
United States, TN, Cornersville
Joined Jan 2007
The stock motor is:
Brushless Out Runner
KV:840
Watts:200
Size D x L:28 x 33 mm
Weight:79 g
This is with a 13x4 prop requires 30 amps on 3 cell
A good 1500 should pull it, or prop down to 12x4 for less draw. Thia is a lower cost alt.
http://www.headsuprc.com/servlet/the....8oz%2C/Detail
bubbleman is offline Find More Posts by bubbleman
Old Oct 13, 2012, 06:59 PM
Joined May 2011
Originally Posted by bubbleman View Post
The stock motor is:
KV:840
Watts:200
Weight:79 g
What about one of HURCs 480s?
Old Oct 13, 2012, 07:45 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Ok, I don't know what the stock motor weighs. Some people say 79g, some people say 134g. Which one is it?
zmonster97 is offline Find More Posts by zmonster97
Old Oct 13, 2012, 08:46 PM
LcJ is offline
LcJ
Find More Posts by LcJ
LcJ
Forever TMWT Pilot #11
LcJ's Avatar
United States, LA, Monroe
Joined Mar 2003
Well if you are talking about the one that comes in the Multiplex Power Kit which I would call stock it is the 134 g. from what I've read. I was curious about that myself.
LcJ is offline Find More Posts by LcJ
Latest blog entry: RC Logger's Eye One Xtreme Quad
Old Oct 13, 2012, 08:56 PM
zmonster97's Avatar
Joined May 2011
Yeah, because I thought I saw 79g somewhere.
Old Oct 13, 2012, 10:48 PM
knifeedge63 is offline
Find More Posts by knifeedge63
There is Victory in the Lord!
knifeedge63's Avatar
United States, GA, Locust Grove
Joined Feb 2011
it is for sure 134g's. I looked up the manufacture specs.
knifeedge63 is offline Find More Posts by knifeedge63
Old Oct 13, 2012, 10:57 PM
pokiou is offline
Find More Posts by pokiou
Australia, VIC, Coburg
Joined Oct 2007
Hey guys,
I was curious can i run a 2s 1550mah 25c battery on my funcub? Other then low flight times what else should i look out for ?
pokiou is offline Find More Posts by pokiou
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
