Old Oct 11, 2012, 10:26 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
I would like to use waterproof aileron & flaps servos in my FC with floats, can someone tell me whether or not this Traxxas waterproof servo appears to be adequate: http://www.servodatabase.com/servo/traxxas/2065
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Oct 11, 2012, 11:04 PM
knifeedge63 is offline
Find More Posts by knifeedge63
There is Victory in the Lord!
knifeedge63's Avatar
United States, GA, Locust Grove
Joined Feb 2011
Thank you!
hmmm might work.. the thing is, they are on the heavy side for a servo of that size. plus they are kinda slow servos... (thats a personal opinion... i like fast servos.) but really it is a slow servo comparably to say, an hs-55 or HXT-900. plus why do you want water proof servos? you dont need them at all. I just covered over the servos with some tape. that works, and keeps em from too much harm.
knifeedge63 is offline Find More Posts by knifeedge63
Old Oct 11, 2012, 11:21 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
Thank you!
Should work. I agree its a little on the slow side, but the fun cub isnt exactly a quick reflexes plane anyway, right? The price makes will cringe though... IMO , its easy enough to waterproof a standard servo with some silicon and grease....
dacaur is offline Find More Posts by dacaur
Old Oct 11, 2012, 11:32 PM
Joined Feb 2011
+1
But in all seriousness, dont worry at all about waterproofing the servos. they dont care. its not like they are getting dunked and held under water. they are just getting water spray.. they will be fine. but if the insurance of water proof servos makes you feel better. just get some silicon caulk and run it around the servo after its glued in (making sure not to get it near the control arm! ). then just slap some packing tape over the servos and BAM you got your self some extremely water resistant servos. dont go and spend all that extra money on those traxxas servos. just do it your self on some HS-55's or HXT-900's or whatever you plan on using.
Good luck!!
-Colin
Old Oct 12, 2012, 07:06 AM
Rickflaguy is offline
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
With a cg slightly forward or equal to 70 mm I "feel" like it is a little too nose heavy. Can some of you chip in your experiences with moving back some and how much?
Rickflaguy is offline Find More Posts by Rickflaguy
Old Oct 12, 2012, 07:10 AM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Hitec offered some waterproof servos (2 different ones) ... Actually work while completely immersed
http://www.robotshop.com/blog/waterp...h-rejoice-1001
Ace also offers one
http://www3.towerhobbies.com/cgi-bin...&I=LXBZBX&P=FR
As does Turnigy
http://compare.ebay.com/like/1407810...Types&var=sbar
However, I would suggest purchasing a set of Gary's servo covers for the Fun Cub, combined with some conventional (HS-55 or equiv) servos, perhaps with some silicone applied to the case seams if you feel it is necessary.
http://morganmill.com/RC/FunCub_Parts.html
ltc is online now Find More Posts by ltc
Old Oct 12, 2012, 08:13 AM
GLM is online now
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Ace also offers one
As does Turnigy
Thanks for the link Itc,
Every little bit helps. The appreciation however - is huge!
Cheers!
Gary
GLM is online now Find More Posts by GLM
Old Oct 12, 2012, 08:26 AM
itsme2 is offline
Joined Mar 2011
I'm fairly new to assembling foam models. I'm putting a FC together with floats. What is the best method to mount the servos in the wing, double sided tape (which brand), silicone or?
Thank you!
Old Oct 12, 2012, 08:33 AM
LcJ is offline
LcJ
Find More Posts by LcJ
LcJ
Forever TMWT Pilot #11
LcJ's Avatar
United States, LA, Monroe
Joined Mar 2003
What is the lightest motor/prop that will offer decent performance?
Thanks for any suggestions.
LcJ is offline Find More Posts by LcJ
Latest blog entry: RC Logger's Eye One Xtreme Quad
Old Oct 12, 2012, 08:40 AM
GLM is online now
GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Thank you!
Hi Itsme,
You are on the right track - tape around the servo and then hot glue it in the wing. Alcohol will debond the hot glue if you ever need to remove and replace it. Tape removes from the servo.
Cheers!
Gary
Old Oct 12, 2012, 08:49 AM
itsme2 is offline
Joined Mar 2011
Originally Posted by GLM View Post
Hi Itsme,
Cheers!
Gary
Gary,
Sorry but I don't understand what you mean by "tape around the servo", please explain?
Thank you!
Old Oct 12, 2012, 08:52 AM
Joined Feb 2011
Gary,
Thank you!
wrap the servo in tape, then put the glue on the tape, which is on the servo, then just stick the servo in.
Old Oct 12, 2012, 08:58 AM
ltc is online now
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
Speaking of hot melt glue, I have always been conservative and used low temp hot melt glue (I know, low temp hot melt...it's like jumbo shrimp; doesn't sound right) on Elapor (and Depron)
Is high tempo/standard hot melt OK for Elapor ?
Also, for those who use CA to mount servos, use caution. You would be surprised where too much (thin) CA can go ... I've heard of servo cases being glued together and glue getting into gears and servo bearings/bushings....
Old Oct 12, 2012, 09:00 AM
itsme2 is offline
Joined Mar 2011
Wow, thanks for the clear explanation! Is the tape you use packing tape?
Old Oct 12, 2012, 09:01 AM
Joined Feb 2011
Nope just some good sticky painters tape will do. and make sure to wrap around the servos a few times.
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
