Old Oct 02, 2012, 07:24 PM
GLM is offline
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Ha!
GLM is offline Find More Posts by GLM
Old Oct 02, 2012, 08:50 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by JoeR View Post
Anyone ever try getting the plastic bits off the foam? If so any success with anything besides ripping them off? Will CA debonder work without harming the foam? I purchased a second hand FunCub and the flap horns are on backwards. I'd like to fix it.
What plastic bits are you talking about?
Prof100 is offline Find More Posts by Prof100
Old Oct 02, 2012, 08:59 PM
Vince53 is offline
Find More Posts by Vince53
Potage, MI
Joined Dec 2003
Gary,
What are the inside dimensions of the Battery Cartridge please, I'll be ordering batteries before I get the cartridge.
Vince
Vince53 is offline Find More Posts by Vince53
Old Oct 02, 2012, 09:15 PM
GLM is offline
GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Originally Posted by Vince53 View Post
Gary,
Vince
Hi Vince,
A good question! One I should have answered before it was asked.
I'm using a sky lipo 2200mah 4cell and it's a tight fit but it works - I have also fit a Blue lipo 3300mah 3 cell and it fits with a little room to spare.
These are tight inside dimensions of the FunCub Battery Cartridge:
Width = 1.340"
length = 5.600"
Thanks for the interest!
Gary
Old Oct 03, 2012, 01:28 AM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Originally Posted by Bluhammer View Post
I think you guys are nuts flying a beautiful plane in the dark
Actually it is one of the most enjoyable flight experiences out in the bush / fields with a big open sky and your light ship gently floating by ... it is almost surreal and very relaxing.
you can COLOUR me nuts too!!
mutha is offline Find More Posts by mutha
Old Oct 03, 2012, 06:33 AM
SpeedsterDEN is offline
Find More Posts by SpeedsterDEN
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Gary,
Vince
Normaly I use a 4000 mha 4 cell batt, and sometimes I use a 5000 mha 4 cell
The 5000 mha Is filling it up.
Regards
S
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Oct 03, 2012, 07:08 AM
LannyT2 is offline
Find More Posts by LannyT2
LannyT2's Avatar
Braselton Ga
Joined Apr 2009
It looks just as beautiful in the dark and flying at night is awesome.
LannyT2 is offline Find More Posts by LannyT2
Old Oct 03, 2012, 08:12 AM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
I was just having fun. Depending on how dark it was, I might put up something I wouldn't mind dorking in, like my wing but not my still pristine FC
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Oct 03, 2012, 08:18 AM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
The FC has really been beefed up to "bush plane status" with all the nice parts we are getting from Gary! He has made this plane SOOOO much better!
It would be cool if Gary could make a gear reinforcement kit of some kind. I already have one installed (that my dad and I made), but I think it would be easy enough for Gary to make a nice product there.
Some vortex generators would be cool. If they work. Gary, did you ever test them properly?
beamen is offline Find More Posts by beamen
Old Oct 03, 2012, 09:41 AM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
This is a plane I would like to try and light from the inside. Mine keeps the red/white color scheme with white lights in it....
JDMJim is offline Find More Posts by JDMJim
Old Oct 03, 2012, 10:29 AM
GLM is offline
GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Thanks Beamen!
I have made my own landing gear mod - took some music wire and set of cool wire bending pliers I found and doubled up the stock wire with some slightly different angles. I think I should have used slightly thinner wire as it made them a little stiff. A little bit of wallow is good - especially in a breeze.
If I could do it consistently (like CNC bending) I would do it - just need to build the jig - and there in lies rub... I'll think about it
On the Vortex Generators - they are installed on my plane - whether they are doing anything or not is hard to measure.
I will say this - on final approach over water with floats it was absolutely smooth. Might have been the conditions or a lack of coffee making it so - I don't know but silky it was.
I believe they are supposed to improve climb and increase performance at higher angles of attack by keeping air flow closer to to the wing - making your control surfaces more effective. (in a nut shell...) So if they are doing anything - it's by degrees and not an obvious vast improvement. Drat...
They do make a good conversation piece however.
Here are a couple of pics.
Cheers!
Gary
Old Oct 03, 2012, 03:58 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
My funcub was delivered today! It didn't come with an aluminum motor mount.
zmonster97 is offline Find More Posts by zmonster97
Old Oct 03, 2012, 04:18 PM
zmonster97's Avatar
Joined May 2011
Where do you guys get your metal motor mount?
Old Oct 03, 2012, 04:28 PM
Rescuejim is offline
Find More Posts by Rescuejim
I can crash anything
United States, TX, Fort Worth
Joined May 2012
I got mine from smallpartscnc.com. Love it
Rescuejim is offline Find More Posts by Rescuejim
Old Oct 03, 2012, 04:42 PM
robbthepilot is offline
Find More Posts by robbthepilot
Victoria B.C. Canada
Joined Aug 2007
The metal mounts are not a needed part. The plastic ones work just fine unless you put crazy power on the plane. The FC is not designed to be a fast plane, leave that for the Dogfighter. All the after market parts are great but not necesary to the flight of the plane. Do not get lost in all the mods that can be done. Build it, fly it and then decide if it needs to be modded. I am going to build a second one over the winter using many of the ideas on this thread.
robbthepilot is offline Find More Posts by robbthepilot
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
