Old Sep 15, 2012, 03:38 PM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Just starting my Fun Cub build ... Took a bit longer than expected to finish and maiden the XB-70 and YF-23.
Ordered the Fun Cub accessory kit and floor stiffner kit from MorganMill RC.
http://morganmill.com/RC/FunCub_Parts.html
Ordered online on Sept 13, parts arrived cross country today Sept 15th ! Couldn't ask for better than that. Very impressed with the product and service.
Already have landing gear from cublandinggear.com.
Curious how different Zacki CA is from Zap medium CA, so I bought a bottle with my last Multiplex radio gear order. Will give it a try and see.
Used some of my bride's 50% off coupons from Michael's and AC Moore, so I think I have the paint all set ... Still working on a scheme and what to paint before assembly rather than after.
Still not sure if I will install my Multiplex lighting kit on the Cub (shown on box). Trying to work out running wire up to top of rudder without routing it on the outside. Might try drilling up thru rudder for wire....
Hoping to have this one built before the flying season ends.....
ltc is online now Find More Posts by ltc
Old Sep 15, 2012, 11:54 PM
Slope P is online now
Find More Posts by Slope P
Slope P's Avatar
Santa Fe NM
Joined Jul 2009
Is it a good idea over time to replace the plastic motor mount to an aluminum by Multiplex?
Slope P is online now Find More Posts by Slope P
Old Sep 16, 2012, 12:15 AM
mckolit is offline
Find More Posts by mckolit
mckolit's Avatar
Southern California
Joined Apr 2007
Originally Posted by Bluhammer View Post
Has anyone seen or used on a FunCub, the U shaped metal, plastic, or CF type landing gear found on many planes? Seems like an obvious thing to try. I just dont want to be the first
Blu
Check the first 500 posts or so. Someone used one and posted a picture of it. Sorry to be so vague but yes, someone has.
Here it is
mckolit is offline Find More Posts by mckolit
Old Sep 16, 2012, 03:52 PM
cubcrafter60 is online now
Find More Posts by cubcrafter60
Wada ya mean, over engineered?
cubcrafter60's Avatar
United States, NV, Fallon
Joined Jul 2011
[QUOTE=ltc;22742227]Just starting my Fun Cub build ... Took a bit longer than expected to finish and maiden the XB-70 and YF-23.QUOTE]
Itc - Believe me, I understand taking a bit longer than expected!
It sounds as if your off to a good start! Relax, enjoy the build, and if you get stuck, this is the best place to ask questions!
As far as the lighting - Start the 'tunnel' down the vertical fin with a drill (make sure it's straight), then take a length of brass or aluminum tubing the same size as your drill and file some teeth in one end, you can then hand twist it into the foam using your drilled hole as a guide to complete the tunnel! - Best of luck on your build! ~ Robin
cubcrafter60 is online now Find More Posts by cubcrafter60
Old Sep 16, 2012, 11:05 PM
ltc is online now
ltc
ltc
AMA 97737
ltc's Avatar
Joined Mar 2010
Thanks.
I am planning on using the Fun Cub as a test bed for some new Multiplex 2.4GHz telemetry sensors (battery voltage, current and capacity in real time) in addition to their AntiSpark module and magnetic / LED professional safety switch.
And of course to be a fun plane to just fly, maybe off skis.
Amazing how things have changed in RC since the 70's. My wife laughed the first time she saw me working on a "foamie" rather than a traditional construction plane!
Also going to try a 3 blade prop to see if it helps with the reported resonance/ vibration. Purchased Multiplex power kit.
Old Sep 16, 2012, 11:23 PM
knifeedge63 is offline
Find More Posts by knifeedge63
There is Victory in the Lord!
knifeedge63's Avatar
United States, GA, Locust Grove
Joined Feb 2011
Iv tried that already... doesnt do a thing.
knifeedge63 is offline Find More Posts by knifeedge63
Old Sep 17, 2012, 06:50 AM
aerotony is offline
Find More Posts by aerotony
Australia, NSW, Harrington Park
Joined Apr 2008
Slope P,
Search previous posts on this thread and YouTube clips for the Fun Cub.
It is generally recognised as an ideal upgrade.
I bought a Fun Cub recently and it had a metal mount not a plastic mount.
If you are planning on buying a kit check what mount comes with it.
If you already have a kit with a plastic motor mount and want to fit a metal mount send me a PM. I may be able to help you out.
Tony
aerotony is offline Find More Posts by aerotony
Old Sep 17, 2012, 08:04 AM
marksp is offline
Find More Posts by marksp
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
When I recently pulled my Himax HC3516, I noticed the wire insulation had interfered with the spinning can. I'm replacing with the EMax GT2812/10 which is also a 35mm diameter motor.
Any motor wire routing tips/pictures to make certain of no interference?
marksp is offline Find More Posts by marksp
Old Sep 17, 2012, 08:37 AM
Slope P's Avatar
Santa Fe NM
Joined Jul 2009
motor mount
Aerotony,
Thank you for the reply.
Do they come with either metal or plastic mounts?
My Cub should be here in a few days. Will let you know if I need one when it gets here.
LP
Old Sep 17, 2012, 08:38 AM
Woody_99 is online now
Find More Posts by Woody_99
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
I put some heat shrink around the wire bundle, which tends to make it want to go straight out. When installed, that tendency causes the bundle to be pushed up against the wall of the airframe. No problem since then on a 37 mm motor.
Woody_99 is online now Find More Posts by Woody_99
Old Sep 17, 2012, 09:05 AM
A Rdnek is online now
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
Aerotony,
LP
Newer produced kits will have the metal mount.
If yours comes with plastic, it was produced before the change over.
Ron
A Rdnek is online now Find More Posts by A Rdnek
Old Sep 17, 2012, 10:04 AM
marksp is offline
marksp's Avatar
Joined Apr 2011
Super, thanks! I'll give that a try.
Old Sep 17, 2012, 10:05 AM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
I cut a hole below the motor down into the air scoop area and feed the motor wires down through and back to my ESC.
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Sep 17, 2012, 10:06 AM
marksp is offline
marksp's Avatar
Joined Apr 2011
Ron
FWIW, I just purchased FC #2, which was ordered through local Hobbytown USA. Still included plastic mount. Of course, I have no idea from which distributor they order and how long it has been in the channel.
Old Sep 17, 2012, 10:07 AM
marksp is offline
marksp's Avatar
Joined Apr 2011
Blu
Did you do this before or after joining the fuselage? Thanks
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
