Old Sep 07, 2012, 11:49 AM
oneniner is offline
Find More Posts by oneniner
Riley Winglow
oneniner's Avatar
Belt, Montana
Joined Feb 2007
The intent of Vortex Generators is not to slow down airflow, it is to generate vortices....... A sheet of small vortices across the top of a wing. This is supposed to help keep the airflow attached to the wing at higher angles of attack.
oneniner is offline Find More Posts by oneniner
Old Sep 07, 2012, 11:51 AM
jhark37 is online now
Find More Posts by jhark37
Flyr John in Floyd VA
United States, VA, Floyd
Joined Nov 2007
VG's
Can't remember the exact source, but one said they should be angled 18 degrees from the airflow. FWIW
John
jhark37 is online now Find More Posts by jhark37
Turner2 is offline
Find More Posts by Turner2
Tallahassee, FL
Joined Sep 2009
Originally Posted by Gordks View Post
Does anyone know why in some graphics the VGs are shown in line with the airflow, but in most they are at a considerable angle?
Some more information here:
http://www.flyfbi.com/Black_Max_Air_...anual-Rev1.pdf
Turner2 is offline Find More Posts by Turner2
Old Sep 07, 2012, 12:13 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by GLM View Post
Like I don't have enough projects...
But all this is very interesting! I started thinking of how to make these for our beloved Cub.
Let talk size...
I took the size of a full scale Cub (35.3 feet) divided by 7.7 and got 55" our FC wingspan.
Very cursory research yields 10 percent of wing chord back from the leading edge of the wing for placement. The FC wing has a chord of 9" - 10% of that is .9" This dimension puts the VG line just ahead of the undulations in the FC wing - very convenient...
The size of the full scale VG's appears to be roughly 1" x 3/8" to 1/2" for effective area from Prof100's picture. Good work BTW!
Scaling down is the right thing to do but my short stumpies cramp up when I think about handling that many small little pieces let alone gluing them precisely on my beautiful wing.
Without getting into Reynolds number scaling...
I'm going to scale them to 1/4" long to 1/8" high at 5 degrees off line of travel 1/2" apart and make a mold of that - or at least that's what I'll shoot for.
Any input at this stage would be welcome.
I'll do a drawing of what I propose later today.
Everything I've read (at this point very little) suggests easier flight characteristics all around and greater take off weights. For me this means handling of bigger motors gets easier.
Too much power - nonsense!
VSTOL Baby VSTOL
Gary
Gary,
Don't forget air molecules don't get smaller with our RC planes. Therefore, scalling down to appropriate size to match the RC scale size may not work well at all.
You could always use the TLR method.
Bill
Prof100 is online now Find More Posts by Prof100
Old Sep 07, 2012, 12:50 PM
GLM is offline
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Originally Posted by Prof100 View Post
Gary,
Bill
I haven't - the calculated scale was .064 of a square inch or something so 1/4"x 1/8" is huge scale wise but easier to work with.
TLR?
This is what I have so far.
GLM is offline Find More Posts by GLM
Old Sep 07, 2012, 12:58 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
TLR?
That
Looks
Right
Sammy70 is offline Find More Posts by Sammy70
Old Sep 07, 2012, 03:43 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
I think they just used a thin wire running parallel and near to the leading edge, held off the surface with spacers in the old Free Flight days and on gliders, seemed to work well and is an easier method to try out rather than gluing a load of bits to your wing.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Sep 07, 2012, 03:46 PM
Gordks is offline
Find More Posts by Gordks
Chilliwack, BC Canada
Joined Mar 2010
Originally Posted by Turner2 View Post
Thanks! Good reading. Well, this is looking like so much fun I may just be doing this myself soon. Anything slower and more controlled than a standard FunCub is going to be very hard to believe.
Gord
Gordks is offline Find More Posts by Gordks
Old Sep 07, 2012, 04:06 PM
GLM is offline
GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
The mold needs some work - needs to be a little more robust...
I was able to make a couple of parts before the glue let go of a few fins.
As far as TLR goes - what do you guys think?
Might need to be a bit bigger?
When the design settles I'll produce these.
Cheers!
Gary
Old Sep 07, 2012, 05:43 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
I have often wanted to try this pattern wich is a combination wing cap made from ABS sheet, would be simple for you to try,easy to attach for trials with double sided tape.
olmod is offline Find More Posts by olmod
Old Sep 07, 2012, 06:06 PM
Prof100's Avatar
Joined Jul 2007
Cheers!
Gary
Gary,
I say it passes the TLR test although I would make them a bit more pointy on the front. That said, if those are molded in plastic right now I would glue them on your plane and test fly it to see how they help with slow flight. You could be done with the design. I like the strip which probably needs a self adhesive tape like carpet tape or equivalent.
Well done Gary.
Bill
Old Sep 07, 2012, 06:11 PM
GLM is offline
GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Thanks Bill,
I'll tape or canopy glue them on this weekend and give it a go. I can make them a little more pointy on the next rev. - I need a bigger base so it's more easily cut out from the rough stock.
Carpet tape - good idea!
Gary
Old Sep 07, 2012, 06:18 PM
marksp is offline
Find More Posts by marksp
build, fly, crash...repeat
marksp's Avatar
United States, WA, Redmond
Joined Apr 2011
Hi Beamen,
The optional motor mount for the Floor/Stiffener kit gives you a firewall to install a cross mount on - this is different than the stock mount. In this install the bell or can of the motor is in front of the firewall not behind.
Check out my website for pictures of the installation.
Thanks for the interest!
Cheers!
Gary
Any recommended cross mounts that work with the Morgan motor mount? The HK cross doesn't appear to work. Also, any pictures of motors mounted using the Morgan setup?
marksp is offline Find More Posts by marksp
Old Sep 07, 2012, 10:21 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
okay, this conversation just went beyond my comprehension. But man it's interesting
JDMJim is offline Find More Posts by JDMJim
Old Sep 07, 2012, 10:34 PM
GLM is offline
GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Mark,
Here is a drawing of a Eflight Power 10/15/25 cross mount in green - it fits my motor mount just barely but will fit. Do you have some dimensions for the HK Mount?
I'm working on an additional firewall to attach to the optional motor mount for the larger cross mounts however some foam will have to be removed to accommodate it - it's the larger outside one.
Is it that you don't have enough room for the cross mount?
Gary
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
