Old Aug 31, 2012, 02:52 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Originally Posted by annarelli View Post
Hobby People have the Fun Cub on sale for $90 for the next few days.
Grampa Tony
Well, now they're out of stock.
zmonster97 is offline Find More Posts by zmonster97
Old Aug 31, 2012, 05:44 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
first time on the water
shadow102 is offline Find More Posts by shadow102
Old Aug 31, 2012, 06:02 PM
pootman is offline
Find More Posts by pootman
pootman's Avatar
Goleta, CA
Joined Mar 2006
Here's a onboard gopro vid of us flying at the bluffs near my house yesterday. It was during sunset and I was worried that the gopro vid wouldn't turn out due to the low light. To my surprise it wasn't bad.
Funcub Sunset Flight Ellwood Bluffs Aug 30, 2012 (7 min 22 sec)
pootman
pootman is offline Find More Posts by pootman
Old Aug 31, 2012, 09:20 PM
aldalo is offline
Find More Posts by aldalo
It Flys Me
aldalo's Avatar
United States, PA, Washington
Joined Jun 2012
Flaps
I'm trying to setup flaps on a funcub using a y harness but the servos aren't in sync.
Anyone no how to fix this ?
Thanks Alan
aldalo is offline Find More Posts by aldalo
Old Aug 31, 2012, 09:55 PM
Ramblin is offline
Find More Posts by Ramblin
Canada, ON, Carleton Place
Joined Jun 2011
Thanks Alan
What do you mean by "in sync"? If you mean they move in opposite directions, there have been several recent posts on the topic.
In summary there are several solutions.
1. Buy a reversing Y harness.
2. Connect one servo to another channel and mix the flap channel to it.
3. Flip one servo over - requires cutting foam.
Ramblin is offline Find More Posts by Ramblin
knifeedge63 is offline
Find More Posts by knifeedge63
There is Victory in the Lord!
knifeedge63's Avatar
United States, GA, Locust Grove
Joined Feb 2011
Thanks Alan
Common problem. Either do a two servo setup with your radio, or cut extra space out on one servo slot so you can rotate the servo around 180 degrees so that the face of the servo points the other way.
knifeedge63 is offline Find More Posts by knifeedge63
Old Aug 31, 2012, 10:09 PM
aldalo is offline
It Flys Me
aldalo's Avatar
Joined Jun 2012
Old Sep 01, 2012, 07:36 AM
Phaedra is online now
Find More Posts by Phaedra
An unexpected error occurred
Phaedra's Avatar
Belgium, Flemish Region, Duffel
Joined Apr 2012
When I got my pilot's license many years ago we were taught that at low speeds ailerons become ineffective. Use rudder instead. I assume the same applies for models.
Grampa Tony
It's not just that they become ineffective, you get a high risk of tip stall and even worse, a spin.
That's how I learned it, and it gets even more pronounced when you do power-on, full flaps stalls : that wing drops so fast, you really don't want that to happen at low altitude.
And of course, models are subject to the same aerodynamics, with a scale effect to it (reynolds numbers and stuff).
Conclusion remains : use rudder, no ailerons, at low speed and hi alpha.
Phaedra is online now Find More Posts by Phaedra
Old Sep 01, 2012, 07:49 AM
shadow102's Avatar
Joined Mar 2011
only thing you use the ailerons for in low speed high alpha is for flat turns you feed in some opposite aileron so you dont dip and stall the inside wing.
Old Sep 01, 2012, 08:15 AM
ilium007 is offline
Find More Posts by ilium007
ilium007's Avatar
Australia, QLD, Brisbane
Joined Jan 2009
OMG - 833 pages !!!! Where does one even begin to find motor prop combos !!
ilium007 is offline Find More Posts by ilium007
Old Sep 01, 2012, 08:17 AM
shadow102's Avatar
Joined Mar 2011
whatever you can fit? seems to be the general idea.
Old Sep 01, 2012, 08:19 AM
ilium007 is offline
ilium007's Avatar
Joined Jan 2009
Hahahaah - I just remembered that I bought a smallpartscnc mount for this plane in anticipation of buying one. I remember they have compatible motors listed on their website. I'll start there !
Old Sep 01, 2012, 12:21 PM
Taildragger55 is offline
Find More Posts by Taildragger55
Taildragger55's Avatar
Anchorage, Alaska
Joined Nov 2008
Shoot for 100 to 125 watts per lb. 300+ watts is about right.
Taildragger55 is offline Find More Posts by Taildragger55
Old Sep 01, 2012, 09:54 PM
cubcrafter60 is offline
Find More Posts by cubcrafter60
Wada ya mean, over engineered?
cubcrafter60's Avatar
United States, NV, Fallon
Joined Jul 2011
Originally Posted by dome78 View Post
I have now about 15 flights on the FC with the slats. It seems they actually do reduce the stall speed a bit. She will come in at more of an angle making a tail wheel first landing possible. However the ailerons barely work at those speeds and I am yanking the sticks to keep her level fighting dropping wings left and right - most times she will wobble about somewhat inelegantly. Probably it would have been better to move the slats to the outer section of the wing.
I am wondering if some may have experimented in making the FC even slower? My slat design yielded mixed results but I feel like using my aging FC as a testbed for servo operated spoilers/Kruger flaps/droops or speed brakes on the fuse. Anybody can share their experience?
P.s. Robin, the slats are sheets of balsa molded on the wing profile and then reinforced with "cross" ribs. I have pictures in my blog.
Dome78 - Nice job, and I enjoyed the conclusion of your RC video techniques post also! Andy Lennon who designed several aerodynamically advanced models wrote a book titled "Basics of RC Model aircraft design" there’s an entire chapter (chap. 20) devoted to High Lift Devices & weight reduction, anyone who may be considering playing with HLD's might find it useful, It may still be available through Model Airplane News.
I imagine with the way things are going its just a matter of time before we see Vortex Generators on a FunCub! ~ Robin
PS - The Air Age Publishing store is out of stock on the book but I found used copies on Amazon http://www.amazon.com/Basics-Model-A...ircraft+design You may want to search a bit you may find a better deal.
cubcrafter60 is offline Find More Posts by cubcrafter60
Old Sep 02, 2012, 04:23 AM
mixer421 is offline
Find More Posts by mixer421
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
This is a good place to look.
http://www.peakeff.com/beta/Default.aspx
mixer421 is offline Find More Posts by mixer421
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
