Old Aug 30, 2010, 11:00 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by htsmd View Post
Hopefully, I will add something a bit more meaningful and new next time.
You have already done so in your post: Those who still have a suitable old Top Flite Nylon prop can swap some efficiency against survivability.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Aug 30, 2010, 04:57 PM
guyst is offline
Find More Posts by guyst
guyst's Avatar
Joined Feb 2010
Originally Posted by spllouder View Post
is this a decent power set up ?
TR35-30C-1100 - TR 35-30C 1100kv Brushless Outrunner
MY30ABEC - Mystery 30A esc
(hobbyking) Slow Wait
or
Alpha 480 (910kv) Outrunner Brushless Motor
30A Brushless ESC Speed Controller [Volcano Series]
(Hobbypatrz) no wait hardly
My setup exactly, very happy with it!
guyst is offline Find More Posts by guyst
Old Aug 30, 2010, 05:19 PM
ekotil is offline
Find More Posts by ekotil
ekotil's Avatar
Athens, Texas, United States
Joined Jul 2004
Originally Posted by coinworker View Post
Thank for the tip i was eyeing the 10 but wasn't sure. what kinda amp draw and watt draw are you reading with this set up?
With a Turnigy 2.2 3 cell turning a Turnigy 11x7 light electric wood prop with a 12.4 pack - drawdown is to 11.1 volts at 55 amps and watts are 604. It doesn't lack for power and all components come down warm not hot to the touch because full power is rarely used! This plane absolutely rocks!
ekotil is offline Find More Posts by ekotil
Old Aug 30, 2010, 05:44 PM
coinworker is offline
Find More Posts by coinworker
What's tomorrows forecast?
coinworker's Avatar
United States, IN, Goshen
Joined Jun 2009
so this may show my ignorance and let on that i've only bought rtf planes and only built one foamy (with all parts recommended) but...
what is a 12.4 pack? and from all the reading i've done i feel like the amps and watt reading is too high and may eventually burn up the esc or motor. am i wrong here?
Also were you able to mount the motor per directions or was it necessary to modify the mount?
Thanks for all the info and help!
coinworker is offline Find More Posts by coinworker
Old Aug 30, 2010, 07:38 PM
gasser1933 is offline
Find More Posts by gasser1933
Albuquerque, NM
Joined Sep 2007
Does the wing kit (M224113) come with the plastic joiner/mount and the tube spars? I already have the
Easy Cub and have wanted to add flaps and aelerons but didn't see an easy way to remove the dihedral.
gasser1933 is offline Find More Posts by gasser1933
Old Aug 30, 2010, 09:04 PM
7rider is offline
Find More Posts by 7rider
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
Looks like 224113 is just the wing panels. It appears you'll need 723130 for the wing joiners. Wonder what the wing set at Tower Hobbies includes. Is it just 224113? If so, I don't see any parts corresponding to 723130. Guess one could purchase carbon fiber tube and cut it.
7rider is offline Find More Posts by 7rider
Old Aug 31, 2010, 03:31 AM
spllouder is offline
Find More Posts by spllouder
SW Missouri
Joined Aug 2006
are you runing 25 c 2200 mah 3 s Lipo ? what servos did you use ? ... Thanks i suspect you bought the servo's from same place :P
spllouder is offline Find More Posts by spllouder
Old Aug 31, 2010, 03:34 AM
SW Missouri
Joined Aug 2006
I plan HXT900 or T-Pro s90's for wing servo's and some MG Tail servo's sound good ? . and a 4 Amp External BEC
i Have 5 3S 11.1 V lipo 2200Mah from my HK450 Heli / so i wanna use thoose what is recommend ESC aprage since i sude this batterys ? still 30 Amp ? should i get a bigger mottor ?
Old Aug 31, 2010, 04:16 AM
SW Missouri
Joined Aug 2006
some ppl recomend a TR 35-42D 1000kv Brushless Outrunner eq: AXi 2820
with a 40 amp esc ? does this cause the vibration pppl are complaiting about . i reather use a leas pwerful set up . i just wanna fly no hovering or stunt stuff . ? i wanna place my order soon > i dont wann buy the wrong stuff ? thanks
btw my first ever RC airplave . but i fly Heli's ... i want something to fly when its 7-20 winds when i cant fly the helis saftly ?
Thanks for any input ...
Old Aug 31, 2010, 06:10 AM
SW Missouri
Joined Aug 2006
what size props would i need ?-
Old Aug 31, 2010, 08:23 AM
george2 is offline
Find More Posts by george2
Hungary
Joined Oct 2006
12x6or 13;6,5 APC E on 3 cell lipo.
george2 is offline Find More Posts by george2
Old Aug 31, 2010, 04:07 PM
ekotil is offline
ekotil's Avatar
Joined Jul 2004
The 12.4 pack reading is what the voltage reading was on the watt meter when I ran the test! A full 3 cell is about 12.6 volts when full. My ESC is 54 amps rated with bursts to 60+ amps. The watt reading is based on how many amps the motor is drawing and to what level the volts are reading at full throttle volt drawdown. Volt drawdown was at 11.1 volts multiplied by 55 amps at full throttle which gives 610.5 watts. I showed the watt output as it actully showed on the watt meter. Most specs on electric motors are drastically conservative to keep people from burning them up and turning in warranty claims. The motor mounted easily without any modification! I do wattmeter tests on each motor set-up I do! I have minimal problems and failures on 1 cell to 12 cell set-ups! Electric has been good to me so I do not use IC!
Old Aug 31, 2010, 06:18 PM
Phasor is offline
Find More Posts by Phasor
KG7MNT
Phasor's Avatar
United States, WY, Cheyenne
Joined Jun 2008
Hi all,
I finally got out this morning and did the maiden flight on my Funcub. I am amazed at how slow this thing can fly with only half flaps. My build consisted of the following:
Castle Ice 50 amp ESC
Hyperion ZS 3009 20 turn motor
Spektrum AR-500 receiver
Two HS-81 servos for elevator and rudder
Two HS-65 servos for ailerons
Two HS-55 servos for flaps
APC 10 X 5 prop
Hyperion CX 2100 mah 3S battery
I flew several flights and couldn't be happier! This is my second RC plane. The first is the Sky Surfer from Banana Hobbies. I was very nervous before flying the Funcub, but once it was airborn I settled down and enjoyed how much fun it is to fly. I can't wait to get it back in the air!
Thanks to all who contribute to this thread as that is what convinced me to get the Funcub and I'm glad I did.
Phasor
Phasor is offline Find More Posts by Phasor
Old Aug 31, 2010, 09:52 PM
SW Missouri
Joined Aug 2006
D05010MG 5.7g / .61kg / .07sec Digital Metal Gear Micro Servo
will this work for the tail servo's ?
Old Aug 31, 2010, 10:09 PM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I was looking at picking up a Fun Cub soon. I wanted to use a motor I already had on hand. I was thinking the 3548-1100 in my Magister. Oops, 770W motor at 171g. Me thinks that's a bit to much. Perhaps I'll 'borrow' the motor from my AcroMaster...I forget its specs, but it's probably more in line with what the Fun Cub wants.
Vantasstic is online now Find More Posts by Vantasstic
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 05:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 10:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 10:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 11:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 12:02 PM
