Old Jun 20, 2012, 04:16 PM
RCDestroyer is offline
Find More Posts by RCDestroyer
The Crash King
RCDestroyer's Avatar
United States, OH, Richfield
Joined Mar 2010
Originally Posted by EFlapper View Post
Yes, several custom motor mounts of aluminum are available. There is one from Sotog who flys a funcub and contributes to this thread. Go to this website
http://www.smallpartscnc.com/
Dick
thanks!! Is that metal motor mount all it takes to remove vibrations? Also, are there any additional tricks that help remove vibrations?
RCDestroyer is offline Find More Posts by RCDestroyer
Old Jun 20, 2012, 04:54 PM
robbthepilot is offline
Find More Posts by robbthepilot
Victoria B.C. Canada
Joined Aug 2007
I use the plastic mount that came with the kit and have never had any vibrations. I do not see how the aluminum one would stop the vibration. Mount it properly and you will have no problem.
robbthepilot is offline Find More Posts by robbthepilot
Old Jun 20, 2012, 05:29 PM
Freddan is offline
Find More Posts by Freddan
Sweden
Joined Sep 2007
I also use the plastic mount and because my motor didn't really match up I'm actually just using 2 motor screws to hold the motor to the mount but still no vibrations.
Freddan is offline Find More Posts by Freddan
Old Jun 20, 2012, 06:01 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
The alloy mount also gives 300% better cooling then the plastic one which does not have any, apart from the small bit of space around the edge.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Jun 20, 2012, 06:11 PM
EFlapper is offline
Find More Posts by EFlapper
Smooth not Shaky
EFlapper's Avatar
United States, CO, Highlands Ranch
Joined Nov 2011
Yes, I and many have used two tricks to help remove vibrations. First install a piece of square wood dowel between the motor mounts on each side in the slot at the rear of the mount, epoxy in place. second use fiberglass cloth from the front air intake bottom back to the cooling slot in the bottom of the fuselage and epoxy. You need to remove the mold release on this area first with an alcohol wipe. these two steps will stiffen the front of the model which is very flexible.
Dick
EFlapper is offline Find More Posts by EFlapper
Old Jun 20, 2012, 06:33 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
Originally Posted by eddy4753 View Post
So, will we be seeing some videos in the future to enjoy? I just ordered a key-chain camera that I'm going to stick in the windshield @ pilots line of sight for now. I have a complete FPV system in another plane and I think one in a FC could be a lot of fun for rough country takeoffs and landings as well as other strange flying, removed from conventional FPV.
that depends on whether or not the videos show my pathetic landings =)
baconflyer is offline Find More Posts by baconflyer
Old Jun 20, 2012, 08:45 PM
B dog is offline
Find More Posts by B dog
United States, CA, Foster City
Joined Nov 2011
I'm HiTEC servo confused.
None with the 82MG's, I use the 55's on some lighter models but think the 81's are a better choice for the FC.
Dick
I looked up the size of the 81's and they are indentical to the 82MG's and that servo will not fit into the wing cut outs. The HS-55's do fit but have some wiggle room. So my question is when you say, "I use the 55's on some lighter models" are you telling my not to use the HS-55's? Again I was planning on using these for the aleron and flaps only, 82MG's for the tail control.
TIA,
Brian
B dog is offline Find More Posts by B dog
Old Jun 20, 2012, 08:50 PM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
81's for the tail, 55's for the wing!
Kimber is offline Find More Posts by Kimber
Old Jun 20, 2012, 09:47 PM
The Crash King
Joined Mar 2010
Dick
Is there a picture of this wooden dowel modification? I'm having a hard time picturing what your saying. Thanks!
Old Jun 20, 2012, 10:39 PM
RTF Thumper is offline
Find More Posts by RTF Thumper
Big Jim
RTF Thumper's Avatar
United States, ID, Mountain Home
Joined Jun 2011
Great time trying my new lights
Saturday Night Combat 16 June 12.wmv (13 min 24 sec)
RTF Thumper is offline Find More Posts by RTF Thumper
Old Jun 20, 2012, 10:51 PM
EFlapper is offline
Smooth not Shaky
EFlapper's Avatar
Joined Nov 2011
TIA,
Brian
Sorry! I'm not telling you to not use the 55's. I prefer the 81's and made the wing cut out larger for them. The 55's will work and are OK to use. Again, sorry for giving you the wrong impression.
Dick
Old Jun 20, 2012, 11:03 PM
EFlapper is offline
Smooth not Shaky
EFlapper's Avatar
Joined Nov 2011
There , are several posts on this fix way back and hard to find so I hope this picture is good enough to help you understand how.Name: PICT1325.jpg
Description:
Description:
Old Jun 20, 2012, 11:09 PM
The Crash King
Joined Mar 2010
That pic helps a lot! Thanks! The kit comes with a plastic crossbar. How does the wooden one removr the vibrations though? Sorry I'm asking so many questions, I just don't want to ruin my FC by vibrations. Lol
Old Jun 20, 2012, 11:19 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Tighten everything really really tight up in the front. That's what I did and I ahve no vibes with a decent power setup winging a 12x6.
I hated the 13x4, I probably already mentioned that though. Godd example of why we need some pitch on propellers
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 21, 2012, 12:31 AM
Gonzo 1971 is offline
Find More Posts by Gonzo 1971
This is BAT country!
Gonzo 1971's Avatar
United States, MI, Ovid
Joined Nov 2003
Why did you hate that prop?
Gonzo 1971 is offline Find More Posts by Gonzo 1971
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
