Old Jun 15, 2012, 05:54 AM
robs is offline
Find More Posts by robs
robs's Avatar
United States, NY, Dutchess
Joined Jun 2002
Thanks for the suggestions. Control surfaces direction and neutral state were validated by others at the field along with checking for warped wings, out of alignment fuse, etc. No chattering of servos is heard after powering up or returning to neutral, so I doubt this is related to the servos. Next attempt will be with a much forward CG. If that doesn't work, I'll start playing with the thrustline. But that'll have to wait until after the weekend as work and life are intruding on my flying time.
robs is offline Find More Posts by robs
Old Jun 15, 2012, 08:02 AM
Starving Bushman is offline
Find More Posts by Starving Bushman
Starving Bushman's Avatar
United States, VA, Alexandria
Joined Nov 2011
I am trying to, but do not yet, understand the whole electrical "equation" to ensure a good setup. So I am seeking advice for the best prop for this motor. I have a bigger motor that I will put on the Fun Cub later but I was going to start with this one..........
Turnigy D3530/14 1100KV
Spec.
Battery: 2~4 Cell /7.4~14.8V
RPM: 1100kv
Max current: 22A
No load current: 1.6A
Max power: 315W
Internal resistance: 0.077 ohm
Weight: 73g (including connectors)
Diameter of shaft: 5mm
Dimensions: 35x30m
Prop size: 7.4V/12x6 14.8V/8x4
Max thrust: 1100g
I have 3s 2200mah batteries to use with it so maybe a ?????
I have a watt meter to test but I don't want to just go buy 10 props not knowing what I'll use so any guidance would be appreciated.
Starving Bushman is offline Find More Posts by Starving Bushman
Old Jun 15, 2012, 08:37 AM
mrc3 is offline
Find More Posts by mrc3
United States, MN, Maple Grove
Joined Jun 2011
Spec.
RPM: 1100kv
Max current: 22A
Max power: 315W
Dimensions: 35x30m
Max thrust: 1100g
I would suggest that an APC 11x5.5 be one of the first props you try.
mrc3 is offline Find More Posts by mrc3
Old Jun 15, 2012, 09:11 AM
EFlapper is offline
Find More Posts by EFlapper
Smooth not Shaky
EFlapper's Avatar
United States, CO, Highlands Ranch
Joined Nov 2011
Spec.
RPM: 1100kv
Max current: 22A
Max power: 315W
Dimensions: 35x30m
Max thrust: 1100g
I set your specs into my motocalc software and it came back with APC 10x5 as the best choice. The motor temp was too high with an 11x5. If you do want to check out the bigger props, you should use a heat sensor on a test stand set up. While motocalc is a good tool, it is not always right and I use it to zone in but not as a final answer.
Dick
EFlapper is offline Find More Posts by EFlapper
Old Jun 15, 2012, 10:02 AM
eddy4753 is offline
Find More Posts by eddy4753
eddy4753's Avatar
United States, WI, Milwaukee
Joined Apr 2010
BTW, what is the wing area on the FC.
TIA,
eddy
eddy4753 is offline Find More Posts by eddy4753
Old Jun 15, 2012, 10:27 AM
Joined Nov 2011
Thanks Mike and Dick. That gives me a place to start. As long as I don't exceed to motor's max amp rating I should be okay, right?
Old Jun 15, 2012, 12:46 PM
wjjones is offline
Find More Posts by wjjones
wjjones's Avatar
Joined Jun 2001
Spec.
RPM: 1100kv
Max current: 22A
Max power: 315W
Dimensions: 35x30m
Max thrust: 1100g
I'm in the same boat. Electronics may as well be alchemy or some other dark art to me, too. So this makes me wonder why more folks don't just get the power system recommended by Multiplex, which is already figured out and performs great--is it the cost? I got the recommended system, BTW, and I'm happy with it.
wjjones is offline Find More Posts by wjjones
Old Jun 15, 2012, 01:04 PM
mrc3 is offline
Joined Jun 2011
Several reasons come to mind:
1) Some of us like to tinker and the shopping for the parts is part of the fun.
2) People want different things out of their planes and tailor the power system to match their flying style.
3) Some like to single source their parts so they only have to wait for one shipment. The LHS that carried the fun cub in stock, did not have MFG recommended power system on the shelf.
Old Jun 15, 2012, 01:19 PM
Joined Nov 2011
$15 motor versus $110 power pack. I already have everything else that I need.
Old Jun 15, 2012, 05:05 PM
EFlapper is offline
Smooth not Shaky
EFlapper's Avatar
Joined Nov 2011
Not exceeding the motor's max amps is a good guideline but max amps can be exceeded. The real limit is heat. Most mfg's do not list the max heat limit because of cooling while in flight is not known. A motor in open air can be be run at higher amps than a motor enclosed by cowling. So yes, plan to use max amps as your limit and you will probably not exceed the heat limit of your motor.
Dick
Old Jun 15, 2012, 05:46 PM
bubbleman is offline
Find More Posts by bubbleman
bubbleman's Avatar
United States, TN, Cornersville
Joined Jan 2007
Spec.
RPM: 1100kv
Max current: 22A
Max power: 315W
Dimensions: 35x30m
Max thrust: 1100g
The 10x5 would be the choice for this motor. Look at the recomended props:
cells 2...............3................4
prop 12x6........10x5..........8x4
Anton
bubbleman is offline Find More Posts by bubbleman
Old Jun 15, 2012, 05:52 PM
Aus is offline
Aus
Find More Posts by Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Australia, ACT, Amaroo
Joined Jul 2011
TIA,
eddy
From the building instructions:
Wing area = 38 dm² (589 inches²)
Aus is offline Find More Posts by Aus
Old Jun 15, 2012, 08:41 PM
baconflyer is offline
Find More Posts by baconflyer
cheapskate extroardinairé
United States, CA, Marin
Joined Jul 2011
can i use this motor on it? (on a 4s with a 13x6 prop) http://www.hobbyking.com/hobbyking/s...00KV_815W.html
baconflyer is offline Find More Posts by baconflyer
Last edited by baconflyer; Jun 15, 2012 at 09:04 PM. Reason: forgot to put the link in
Old Jun 15, 2012, 11:48 PM
Matt_flyer is offline
Find More Posts by Matt_flyer
Australia, QLD, Brisbane
Joined May 2012
Hi everyone
At 171 grams the motor is a bit on the heavy side haven't really seen people use a motor that heavy after researching motors. And using 4's is not as common, that should be a rocket ship! The recommended motor here weighs 134 grams http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAAGX
I decided to go the powerful option with a faster motor bit more than 1100 and bit less than 1250 that some people use. The weight of the motor is 141grams. http://www.hobbyking.com/hobbyking/s...dProduct=18120.
For now not certain but a 11x5.5 or a 11x7 prop should be good.
Matt_flyer is offline Find More Posts by Matt_flyer
Old Jun 15, 2012, 11:50 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
My motor weighs 100g which is lighter than the stock motor.
With the alumimun motor mount (8g heavier than stock)
I am nose heavy with my 3S 2650mah pack all the way back as far as it will go.
So anything heavier and you are really going to have to get creative.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
