Old Jun 14, 2012, 04:17 PM
BrundleFlyBy is offline
Find More Posts by BrundleFlyBy
Never stop being a kid.
BrundleFlyBy's Avatar
United States, CO, Manitou Springs
Joined Jan 2012
Originally Posted by seansmiller View Post
As promised, here's some shots and description of my landing gear mount build:
Nicely done. But I have to say right offhand it looks like you went to the opposite extreme, and overbuilt it by a good margin. Any idea how much weight was added?
Seems like a little strategic bungeeing and/or reinforcement of the existing gear wire with the single mount might net most of the improvement in performance and durability with a lot less work and added weight.
No doubt yours looks extremely cool, however. I applaud your ingenuity and workmanship.
BrundleFlyBy is offline Find More Posts by BrundleFlyBy
Old Jun 14, 2012, 04:43 PM
Timewarp is offline
Find More Posts by Timewarp
Life is simple Eat, Sleep, Fly
Timewarp's Avatar
Germany, RP, Kaiserslautern
Joined Oct 2011
I have to agree, well done job but way way over kill for this light bird.
Timewarp is offline Find More Posts by Timewarp
Old Jun 14, 2012, 04:46 PM
robbthepilot is offline
Find More Posts by robbthepilot
Victoria B.C. Canada
Joined Aug 2007
That is a lot of work and weight. The option would be to learn to be a better pilot and land this great plane the way it should be landed. A light wire between the struts about 1 1/2 inches from fusalage is plenty. Your does look good. What is the AUW at this point?
robbthepilot is offline Find More Posts by robbthepilot
Old Jun 14, 2012, 04:49 PM
seansmiller is offline
Find More Posts by seansmiller
Denmark, Capital Region of Denmark, KBH
Joined Apr 2012
Thank you Well I started out doing just that (reinforcing the existing gear wire with the single mount with some bungees) and it was still just as worthless in my opinion as the unmodified stock landing gear. The plastic mounting plate kept braking off the fuselage and the single landing gear wire kept bending out of shape... not to mention the dangerously low ground clearance the single wire landing gear provides. It's just too bouncy for my liking! I don't know how much weight I've added but it's not an issue for me. I've tried it light and it didn't work for me.
I fly my FunCub exclusively in pretty rugged terrain (which was why I bought it) and the entire landing gear costruction simply has to be able to cope with the uneven ground. Which it does now
seansmiller is offline Find More Posts by seansmiller
Old Jun 14, 2012, 05:12 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Sean Miller,
Do you plan on spending a lot of time on a race track
How much weight did that add?
It looks cool, but I don't see the point
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 14, 2012, 06:16 PM
robs is offline
Find More Posts by robs
robs's Avatar
United States, NY, Dutchess
Joined Jun 2002
unsuccessful maiden
I've been following this thread for a while and finally broke down to join the fun. However my first two attempts were disappointing.
I went with the stock motor, aluminum motor mount, 13x4 prop (balanced), 3s 2200 lipos pushed back to vent to achieve the recommended CG 80mm from leading edge. Ailerons and flaps are using HXT 900s, while the rudder and elevator are using HS-81s.
First attempt was with the grub screws as specified in the manual (top 3mm, bottom 1.5mm). Take off run was short and uneventful. However, as soon as I lifted there was a hard torque roll to the right and the right wing touched causing a cartwheel. No damage, just disappointment.
I remembered reading that several have not used the offsets and just gone with the default, I removed the grub screws and tried again. The same thing. As soon as the the plane got light on its wheels it would torqued to the right. Of course I pushed it and tried to lift off while trying to moderately correct with rudder and ailerons ... no luck still rolled to the right
Before and after both attempts I checked and ailerons, flaps, rudder, elevator all looked straight and level. Lateral balance seemed fine. Should I be attempting to add left side thrust via the grubscrews? If so how much? What obvious thing am I missing?
robs is offline Find More Posts by robs
Old Jun 14, 2012, 06:48 PM
darknrgy is offline
Find More Posts by darknrgy
darknrgy's Avatar
Joined Mar 2012
You have a bunch of posts so I assume you've gone and checked that everything looks nice and straight. I've seen little bends at the tips of a wing cause major trim issues.
Take off straight against the wind. If you are crabbing the wheels might be a little bit out of alignment and some opposite rudder might be the trick you're looking for. If you are crabbing on the runway and then takeoff, the plane tries to straighten out once airborn which can cause a tip stall.
The straightness of the fin and rudder are pretty critical to trimmed out flight on the funcub.
Is it possible you're not taking off with enough speed or pulling up too hard? If your elevator is trimmed too high it will take off prematurely and immediately stall.
By the way, I have my motor on straight and don't notice any issues like you mentioned. iirc motor torque would throw you over left, not right.
Just as a sanity check, make sure your ailerons are not reversed! Seen this one happened to experienced fliers.
Good luck! I haven't been flying for long so maybe someone else has some better ideas.
Edit: hmmm, looking at your head-on photo, everything does look really straight. Nice decorations by the way :].
darknrgy is offline Find More Posts by darknrgy
Old Jun 14, 2012, 07:30 PM
robs is offline
robs's Avatar
Joined Jun 2002
Thanks for thoughts. I was taking of straight into a very mild breeze. Wheels might have been slightly crabbed, but roll to the right might was after I got lift. I know it wasn't torqure roll. The roll was just so sudden after lift off, that I didn't know how else to describe it.
I went back and did double check my CG. It was between 75-80mm back from the leading edge, so I don't believe this is a CG issue. It must be something out of alignment that I'm just not seeing. Nor could the other guys at the field. Maybe I'll see something when I go over it again tomorrow with fresh eyes..
Old Jun 14, 2012, 07:41 PM
mutha is offline
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
>Some kits had one wing slightly thicker than the other - check your axial balance??
>also you might try to dial in some trim for roll prior to takeoff so you can get it in the air and check ...
> also you should not need anything like WOT to take off.
I have a LOT of down thrust 5+ degrees and about 2-4 degrees RH thrust.
mutha is offline Find More Posts by mutha
Old Jun 14, 2012, 11:16 PM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Mine has never exhibited any kind of torque roll or roll tendencies at all. But, I did have a plane that had terrible constant rolling once airborne, and it drove me crazy. I never did get it figured out as it got destroyed on the 2nd flight. What I suspect was a bad functioning aileron servo and a little tail heaviness or both.
That plane is the only one I've ever owned that just didn't react like a plane should and it freaked me out. Good luck with yours.
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Jun 15, 2012, 01:15 AM
dome78 is offline
Find More Posts by dome78
United States, CA, Mountain View
Joined Jul 2004
Most folks here have their CG from 60 to 80 mm from the leading edge. It may be worth while moving the CG forward a bit - the FC is fairly forging in terms of CG. Mine is at 65mm at it flies straight and great upside and down.
dome78 is offline Find More Posts by dome78
Old Jun 15, 2012, 03:17 AM
mixer421 is offline
Find More Posts by mixer421
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
Could it be a problem with the flaps? Are you using a reversing 'Y' lead or is there flex in one of the control rods? I had to sand quite a lot from the flap hinge line to get one of them to neutralize without the servo chattering.
mixer421 is offline Find More Posts by mixer421
Old Jun 15, 2012, 03:43 AM
Aus is offline
Aus
Find More Posts by Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Australia, ACT, Amaroo
Joined Jul 2011
Originally Posted by mrc3 View Post
... Ended up putting carbon fiber tubing over the linkages to the flaps and Ailerons to stiffen them as they noticeably flexed during servo operation...
Mike,
The standard linkages shouldn't need re-enforcing if everything is running true and free. You may even risk burning out a servo (or four...). I would recommend checking them. For the flaps (and elevator) your swivel push-rod connector needs to be able to rotate as per step 7 of the building instructions:
'Be careful when fitting the retaining nut: tighten it just to the point where the barrel rotates smoothly, but without lost motion...'
Aus is offline Find More Posts by Aus
Old Jun 15, 2012, 03:55 AM
Aus is offline
Aus
Aus
Aus's Avatar
Joined Jul 2011
Although I haven't tried it, the instruction manual (step 30) refers to hand-launching. Have you tried this? Definitely have someone else check your control surface throws and direction first - just in case. And if you do try this, please do it over some long, soft grass...
I hope you work this out as there is definitely something wrong.
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
