Old Jun 05, 2012, 10:31 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
We thought ours was ready, but due to a radio problem, lack of a decent instruction
manual, we have to go back and redo all the servo settings. That means cutting our
some foam to get to the screws or removing the glued in servos in the wing. The
ones in the sides are not a problem. The flap servos are OK.
None of our servos are properly centered. So trim and travel are limited in one
direction....
We have several planes to redo.............
Kimber is offline Find More Posts by Kimber
Old Jun 05, 2012, 11:52 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Not perfecty centered servos in resting position is what sucks about using y cables; cant use sub trim to adjust each servo indepently
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jun 05, 2012, 12:36 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Yeah, after looking it over, limited room, and the fact that this plane does not need to be slowed down, I opted out of adding flaps for now. If you want to slow down, harrier! She's a cub, they harrier beautifully.
Not to mention, it's simple when setting up flaps with my Aurora 9, not the case with my DX7. Unfortunately, since I am setting up a buddy box, I have to use my Spektrum gear.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jun 05, 2012, 02:40 PM
darknrgy is offline
Find More Posts by darknrgy
darknrgy's Avatar
Joined Mar 2012
Originally Posted by johnnyrocco123 View Post
Unless I am reading it wrong, this is how multiples recommends the thrust angle????
Looks a bit much. Is this a good starting point??
Did you add shims to do thrust angle or something? I actually don't remember seeing anything about it in the manual. I put mine on straight and it flies great as far as I can tell. One funny thing about the geometry of the plane is that the wings looks like they already have a positive AOA compared to the rest of the plane. Seeing how this plane does a lot of acrobatics maybe a symmetrical thrust is better? Don't know much about this yet...
darknrgy is offline Find More Posts by darknrgy
Old Jun 05, 2012, 02:55 PM
You down with EPP?
Houston, Tx
Joined May 2009
Page 22 of the instruction manual, it says to put in a lot of down thrust. The picture shows the 4 adjustment screws screwed into the motor mount. Top two screws come out the back 3mm, bottom 2 screws come out the back 1.5mm.
Old Jun 05, 2012, 03:10 PM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
Originally Posted by A Rdnek View Post
So what is wrong with Parkzone/Hangar9 stuff?
Ron
absolutely nothing....I like diversity...thats all....there were 4 wildcats for example...
JDMJim is offline Find More Posts by JDMJim
Old Jun 05, 2012, 03:14 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Without the downthrust you will get a lot of ballooning at anything over two thirds throttle.
Unless of course your motor is low powered.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Jun 05, 2012, 03:19 PM
Kimber is offline
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
We are using Tactic raidos. The little book they give you sucks.
There is a beep at the end of the trim travel and other at center and then
another at the other end of the travel. Brad was using the center beep as
the other end, so we only had half what was there and depending on which
way he he started and then everything was out of wack. We called Tactic
and they got us going. We really like the wireless buddy box feature.
Old Jun 05, 2012, 03:35 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Prof100 is offline Find More Posts by Prof100
Old Jun 06, 2012, 03:35 AM
Aus is offline
Aus
Find More Posts by Aus
Aus
ʎןɟ inverted ɹǝpunuʍop
Aus's Avatar
Australia, ACT, Amaroo
Joined Jul 2011
direction....
Wow, I feel your pain. I had a similar issue a while back where I re-used a model memory without doing a reset. It took me a while and a lot of frustration before I realised it had all this sub-trim in the radio (from the previous model in that memory location).
I highly recommend using a servo tester when building. They usually have three modes:
1. Neutral - centres the servo.
2. Manual - allows you to drive the servo via a rotary dial on the tester.
3. Auto - this drives the servo from full positive to full negative deflection at a speed set by the rotary dial. Great for running new servos for a few minutes before installing to hopefully weed out any bad ones.
If you use a servo tester in your build, you really have no need to connect a receiver until near the end. I'm sure you can get them at most hobby shops but I just use one from HobbyKing which I highly recommend. It was only $3.56 using the swarm buddy-code combo price.
http://www.hobbyking.com/hobbyking/s...vo_Tester.html
http://rcsearch.info/hobbyking/buddy...=0&y=0#catalog
I hope this helps, Aus.
Aus is offline Find More Posts by Aus
Old Jun 06, 2012, 11:48 AM
joshet89 is offline
Find More Posts by joshet89
MD1 HACK
joshet89's Avatar
United States, OH, Wadsworth
Joined Jan 2010
Had my FC out last weekend and got some great shots! What a great plane pretty sure I'll never be without one
My setup is a 130g Omega 60amp hobby wing ESC, reccommended Hitecs all around. Played with a lot of different props anything from a 12x6SF to a 14x7 and pretty much settled on 12x8, great combo of power speed and flight times.
joshet89 is offline Find More Posts by joshet89
Old Jun 06, 2012, 12:19 PM
You down with EPP?
Houston, Tx
Joined May 2009
I could have sworn I had an Omega 130g in my motor box, but apparently I didn't.
I ended up with a 480+ from head's-up R/C.
I would have loved that Omega, plenty of power, but that extra 30 grams of weight would have had me adding lead to the tail.
As is, I placed the Rx under the wing, with the satellite against the bottom back wall (vent hole). My Sky 3S 2650mah 40C pack is all the way back, and it seems to balance perfectly.
I have a 12x6 for maiden. Should fly in the next hours or so.
Maxed out throws for 3D
Old Jun 06, 2012, 12:21 PM
EFlapper is offline
Find More Posts by EFlapper
Smooth not Shaky
EFlapper's Avatar
United States, CO, Highlands Ranch
Joined Nov 2011
[QUOTE=joshet89;21819668]Had my FC out last weekend and got some great shots! What a great plane pretty sure I'll never be without one
Hi
That's some pretty country you are flying in and your cub looks super. The flight shots look right at home in the scene and the pilot is doing a great job. You must have some time on the sticks, right on.
Dick B.
EFlapper is offline Find More Posts by EFlapper
Old Jun 06, 2012, 12:25 PM
ben_beyer is offline
Find More Posts by ben_beyer
United States, TX, Canyon
Joined Jan 2011
Does the Omega 130 bolt up to the included firewall or do you need to modify it?
ben_beyer is offline Find More Posts by ben_beyer
Old Jun 06, 2012, 12:41 PM
joshet89 is offline
MD1 HACK
joshet89's Avatar
Joined Jan 2010
The 130 is a horse in this application, 9 minute lazy flights with a gens ace 2650 on the 12x8
I did add a little weight to the tail b/c I wanted to keep the battery in the middle as much as possible b/c I wanted to keep some flexibility of mounting the GoPro in some different locations. Right now I have 2 GoPro mounts one on the canopy and one on the wing. GoPro on there makes for some awesome pics
Originally Posted by EFlapper View Post
Hi
Dick B.
Thanks! These pics were at my club field in NE Ohio and it is a great place to fly. I have had the FC since last september and it comes to the field every time I go out
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
