Old Mar 30, 2012, 10:47 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by Kimber View Post
Yes, semi functional!
Kimber,
Nice looking gear. Did you make or buy it?
Bill
Prof100 is offline Find More Posts by Prof100
Old Mar 30, 2012, 10:49 PM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Originally Posted by RTF Thumper View Post
Waiting on weather now
Nice job Jim, she's a classic!
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Mar 31, 2012, 12:32 AM
Kimber is offline
Find More Posts by Kimber
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Originally Posted by Prof100 View Post
Kimber,
Bill
Now I have been insulted!
We made it!
Kimber is offline Find More Posts by Kimber
Old Mar 31, 2012, 04:56 AM
mixer421 is offline
Find More Posts by mixer421
Agricultural flyer
mixer421's Avatar
United Kingdom, England, Kent
Joined Aug 2007
Originally Posted by Mchone, Jake View Post
Sounds great. What store did you get it at?
In the UK it's available from B&Q, a major hardware chain but it's also in most hobby stores. Part of my confusion was because most of the advice was from the US and most of those brands are hard to find here. I'm also a cheapskate!
mixer421 is offline Find More Posts by mixer421
Old Mar 31, 2012, 08:20 AM
FlattyFlier is online now
Find More Posts by FlattyFlier
Team LightRC
FlattyFlier's Avatar
Joined Dec 2003
Originally Posted by EFlapper View Post
Hi Jake
The subject motor is an Exceed Rocket 3020-950. If so and you want I'll check it out on the Fun Cub is that's where you want to use it.
Dick
Yeah that's what I have and before you sad I could use a 12" prop. Thanks.
FlattyFlier is online now Find More Posts by FlattyFlier
Old Mar 31, 2012, 08:23 AM
Team LightRC
Joined Dec 2003
I found it. I can order online if I can't find it in a store. The Estes spray I used gets pulled off very easly and isn't very thick at all so you can easly see where the stickers and tape used to be.
Old Mar 31, 2012, 10:14 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
We made it!
Impressive. Take a bow.
Old Mar 31, 2012, 11:12 AM
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Dumb question?
I need to increase my aileron throws. The control horns have no options and my control rods are already out to the end of the servo arms.
Do I have to replace the servo arms with longer ones (a major pain), or can I safely increase my HXT900 servo throws beyond 100%
Old Mar 31, 2012, 11:18 AM
EFlapper is offline
Find More Posts by EFlapper
Smooth not Shaky
EFlapper's Avatar
United States, CO, Highlands Ranch
Joined Nov 2011
Sadly the Vess website does not give out some critical data on their Props. My software needs data on Power multiplier and Thrust multiplier (of the prop) to determine how much power and thrust the Propeller produces.
So I have to backward engineer the results to obtain the data. Either I or you need to set it up in static and using a watts up (or equivocal) meter and measure the watts, volts, and amps consumed and RPM produced by the motor/prop combo.
I know that once you measure this combo you will know right away if it is a safe to use combo and may think that's enough. But, you may also want know how much thrust it actually produces and be able to predict the climb rate of your Fun Cub using different Vess prop diameters and pitches.
Once I have that data I can use it to calculate any Vess prop's output.
Make sense ??
Dick
EFlapper is offline Find More Posts by EFlapper
Old Mar 31, 2012, 11:28 AM
Scooter04 is offline
Find More Posts by Scooter04
Scooter04's Avatar
Columbus, OH
Joined Jul 2007
I would increase past 100% before changing the arms unless you have real short arms or something. Just double check your throws with a gauge afterwards and don't assume that both servos ended up increasing the same. It varies depending on if you used sub trim and how much to center your servos. As a general rule I mechanically center everything as much as possible and then use the radio to fine tune. I think that comes from the helicopter world.
Sometimes really long arms get the geometry of the control rod way out of whack and can be tough on servos. Just my 2 cents.
Scooter04 is offline Find More Posts by Scooter04
Old Mar 31, 2012, 11:40 AM
Team LightRC
Joined Dec 2003
Very good post!
Old Mar 31, 2012, 11:44 AM
Team LightRC
Joined Dec 2003
Dick. Sorry for the trouble, man. I didn't mean for you to have to try to find the best vess prop. I just order edit because it was cheap and had big paddles.
I'll fly it tomarrow. I'm not looking for the optimum prop now that I know the motor isn't junk and can make the plane do what I want. I just want the same thrust from a wood prop that the 12-6E gave me. I didn't want to order a 13" vessso I took the next step down
Results from the 11-7 tomarrow
Thanks!
Old Mar 31, 2012, 12:02 PM
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
Thanks, that was painless! I adjusted the throws for 135% and now up is close to 30mm from 22mm. That should improve those rolls a lot
Blu
Old Mar 31, 2012, 02:48 PM
RTF Thumper is offline
Find More Posts by RTF Thumper
Big Jim
RTF Thumper's Avatar
United States, ID, Mountain Home
Joined Jun 2011
A Double Maiden
Bowsonn and I got her done, all I can say is WoW what a great plane.
Rember theses are maiden flights in stiff wind. The planesd are high and the vids will get better.
31 Mar 12 Maiden of Two Fun Cubs.wmv (4 min 46 sec)
RTF Thumper is offline Find More Posts by RTF Thumper
Old Mar 31, 2012, 03:07 PM
Redbrickman is offline
Find More Posts by Redbrickman
Maintain Thine Airspeed !
Redbrickman's Avatar
Wiltshire UK
Joined Apr 2010
I've been reading up on the safe paint types for Elapor and became totally confused.I So I bit the bullet and after cleaning thoroughly with kitchen spray cleaner and a good rinse and dry I sprayed a small strip inside the canopy with 'Plasti-kote' fast dry rattle can enamel. Two coats gave a fairly good gloss cover spraying from about 10". I left it to cure for 24hrs then gave it a polish with spray can silicon furniture polish. I've stuck various sticky tapes, blue masking, HD parcel, insulating etc., and all have removed without lifting the paint. Cheap and cheerful worked for me, maybe it won't for you!
You can also use Holts duplicolor acrylic car paints, which I think are the same as the Krylon often mentioned here. A good preparation on the elapor foam is IPA - Iso propyl alcohol.
You will also find the Plasticote clear laquer very good for sealing the paint. I used it on top of the Holts paint with great success.
Redbrickman is offline Find More Posts by Redbrickman
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
