Old Mar 26, 2012, 04:45 AM
FlattyFlier is online now
Find More Posts by FlattyFlier
Team LightRC
FlattyFlier's Avatar
Joined Dec 2003
Thanks, dick. I'll give them a try. I ordered an 11-7 vess last night too. I still don't know what prop size or pitch to run but do far out of the Es the 12-6 has been best but for a motor that big Im not sure if a 12 is enough. But I liked the power and the flight time and my esc never got hot but I'm over speeding it do I've got to try a 12-6 wood and see if I get the same results.
FlattyFlier is online now Find More Posts by FlattyFlier
Old Mar 26, 2012, 06:16 AM
Redbrickman is online now
Find More Posts by Redbrickman
Maintain Thine Airspeed !
Redbrickman's Avatar
Wiltshire UK
Joined Apr 2010
Hi and thanks for the advice. I do like Giant Cod but had almost decided on this Motor
http://www.hobbyking.com/hobbycity/s...dproduct=18225
And being fairly new to electric not sure if GC had an equivalent. I don't want high power as I'm hoping to build light and run on 2cell LiPos. I have plenty of time so would rather get it right than rush it.
That looks like a good motor, may buy one for spares.
Redbrickman is online now Find More Posts by Redbrickman
Old Mar 26, 2012, 06:18 AM
Wiltshire UK
Joined Apr 2010
Old Mar 26, 2012, 08:11 AM
comelit79 is offline
Find More Posts by comelit79
comelit79's Avatar
Italy, Lombardia, Bergamo
Joined Mar 2012
hi,
i'm intresting to scorpion brushless for my funcub. but i'm very undecided..
in your opinion what is best for funcub among them?
Scorpion SII 3020-1110Kv
Scorpion SII 3026-710Kv
Scoprion SII 2036-890Kv ??
Thank You,
Fabio
comelit79 is offline Find More Posts by comelit79
Old Mar 26, 2012, 11:04 AM
EFlapper is offline
Find More Posts by EFlapper
Smooth not Shaky
EFlapper's Avatar
United States, CO, Highlands Ranch
Joined Nov 2011
Originally Posted by comelit79 View Post
hi,
Thank You,
Fabio
Hi Fabio
The 3026-890Kv motor has a broader range of acceptable props and speed vs. vertical climb capability over the 3020-1110Kv. My software rated the 3026-710Kv size last of the three. At any rate, motor calc rated the 3026-890Kv as #1.
Any one of the ones would be a beast in the Fun Cub, very fast horizontal and straight up as well.
Dick
EFlapper is offline Find More Posts by EFlapper
Old Mar 26, 2012, 11:23 AM
comelit79's Avatar
Joined Mar 2012
Originally Posted by EFlapper View Post
Hi Fabio
Dick
then do you think that the 3026-890 Kv as the first? with how esc, prop and lipo ?
believe that they are oversized?
Another solution could be the hacker A30-14l v2 with a 12x6 apc-e and an 2200 3s lipo what do you think about this setup ?
Old Mar 26, 2012, 11:35 AM
jdr43 is offline
Find More Posts by jdr43
jdr43's Avatar
United States, AR, Rogers
Joined Oct 2005
Maiden flight
Maiden flight today. Temp 70 degrees Wind gusts 5 to 10 mph. Takeoff was very smooth and straight at about 1/3 power, required no trim adjustments. Flaps are set at about 80% and when deployed the FC looped so I think I will reduce the flap deflection and add in some down elev. Mix. The landing on pavement with no flaps was very slow and very easy to control. The flight was short about 5 minutes, want to change setting and go back when the wind is less.
jdr43 is offline Find More Posts by jdr43
Old Mar 26, 2012, 12:10 PM
tenrozzero is offline
Find More Posts by tenrozzero
Joined Oct 2011
I used Rust-Oleum Stops Rust Spray, Metallic Yellow (Gloss Protective Enamel) which worked out pretty good on the foam. You can find this at your Walmart Store.
tenrozzero is offline Find More Posts by tenrozzero
Old Mar 26, 2012, 02:20 PM
Bluhammer is offline
Find More Posts by Bluhammer
Bay Area Prop Buster
Bluhammer's Avatar
Bay Area CA
Joined Jan 2011
49er Fun Cub
I thought my FC was a little plain and common so I fixed her up a little with a little SF NFL treatment.
Blu
Bluhammer is offline Find More Posts by Bluhammer
Old Mar 26, 2012, 02:36 PM
Team LightRC
Joined Dec 2003
jdr43, can I get a pic of your main gear mount?
Also, does anyone have a spare stock main gear mount they'd sell me? Mine broke and I dont really wan to spend $30 for a new gear set just to get the one piece
Old Mar 26, 2012, 02:57 PM
RTF Thumper is offline
Find More Posts by RTF Thumper
Big Jim
RTF Thumper's Avatar
United States, ID, Mountain Home
Joined Jun 2011
I have orderd the Himax HC3516-0840 motor with a 13x4 prop does anyone here run this setup?
RTF Thumper is offline Find More Posts by RTF Thumper
Old Mar 26, 2012, 03:00 PM
jdr43 is offline
jdr43's Avatar
Joined Oct 2005
It's mounted on 1/8 ply
Old Mar 26, 2012, 04:02 PM
EFlapper is offline
Smooth not Shaky
EFlapper's Avatar
Joined Nov 2011
I would suggest
Scorpion 3026-890Kv motor
Turnigy dlux 55A esc with SBEC
APC 13x6, 12x6, or 11x5.5 Eprop
2200 Mah 35C or 2650 Mah 25C
One thing to consider on the Scorpio motor is that it is heavy, about 205g. Others on this forum use motors in the 100-150g range. CG will need some help. Also Amp draw is high (40 amps) compared to the HiMax 3516-1130 (I use) at 28 amps, so flight time will suffer.
Dick
Old Mar 26, 2012, 04:23 PM
EFlapper is offline
Smooth not Shaky
EFlapper's Avatar
Joined Nov 2011
[QUOTE=comelit79;21146737
Another solution could be the hacker A30-14l v2 with a 12x6 apc-e and an 2200 3s lipo what do you think about this setup ?[/QUOTE]
This is a good setup, but a 13x7 prop will improve performance with unlimited vertical, the 12x6 will not go vertical.
use a 40 amp esc with an SBEC
Dick
Old Mar 26, 2012, 04:32 PM
EFlapper is offline
Smooth not Shaky
EFlapper's Avatar
Joined Nov 2011
Blu
Hey Blu
Beautiful paint job but 49er scheme? What about a Broncos scheme with Payton Manning in the cockpit?
HaHaHaHa just kidding.
Really man that is one of the best I've seen on the forum, hats off to you!
Dick
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
