Espritmodel.com Heli Air
Old Dec 25, 2011, 09:31 PM
USA, ME, Ellsworth
Joined May 2010
Brad -
My kit was missing a bunch of the plastic parts. I called multiplex and the next week I had a complete parts pack on my doorstep. No questions asked.
The rudder and tail wheel are connected to each other and share a common servo.
Nigels_world is offline Find More Posts by Nigels_world
Old Dec 25, 2011, 09:45 PM
Flying MPX these days
QuasiLoco's Avatar
United States, FL, Naples
Joined Dec 2011
Thanks Boyd!
Brad, double check your males, too. Should be 4 of em. In my kit two were taped together end to end and appeared to be one.
I would double check the rest of the parts and then call Multiplex. There is a diagram of all the parts that should be in the kit on page 18 of the manual titled Abb.2.
Also, you will definitely want a servo that will power the rudder and the wheel (they are connected). Most highwing planes suffer from something called adverse yaw as a result of drag produced by ailerons. For this reason, it is helpful to dial in some rudder when turning.
QuasiLoco is offline Find More Posts by QuasiLoco
Old Dec 25, 2011, 09:47 PM
BradSimmons's Avatar
United States, KY, Danville
Joined Aug 2011
Nigel - good to know, I was hoping they'd be decent to work with. :-)
BradSimmons is offline Find More Posts by BradSimmons
Old Dec 25, 2011, 09:48 PM
Joined Aug 2011
Quasi,
4 MALE wing spreader plates?
Old Dec 25, 2011, 09:50 PM
Joined Aug 2011
I got my servos from another company - he only sent me four - two aileron servos and two smaller ones - so I probably have what I need?
Old Dec 25, 2011, 09:58 PM
Angier,N.C.
Joined Sep 2008
Link to progress on my Fun Cub
http://www.facebook.com/media/set/?s...8384054&type=1
larrysoaring is offline Find More Posts by larrysoaring
Old Dec 25, 2011, 10:05 PM
Joined Aug 2011
Larry, looks awesome. This is my first build - so not really sure what to do - or need to do, let alone modify. :-)
This looks like a fun plane though.
Old Dec 25, 2011, 10:20 PM
QuasiLoco's Avatar
Joined Dec 2011
Brad, sorry - I was confused.
About your servos - on mine the aileron servos are the smaller ones (HS-55 equivelant) and the larger ones (HS-65 equivalent) are for tail surfaces.
Old Dec 25, 2011, 10:28 PM
Angier,N.C.
Joined Sep 2008
Fun Cub build
Thanks Brad,I love Multiplex airplanes,been flying the Mentor for a year now and is the favorite of my fleet.The Fun Cub will rate right next to it I'm sure.
Old Dec 27, 2011, 07:50 AM
The Balsa Farmer
bassfisher's Avatar
North Little Rock, AR
Joined Jul 2005
Brad - just follow the thread - Best thing I can recommend is that you find a good instructor pilot if this is first plane and you have no experiance as an rc pilot. Will save you a lot of $$ in the long run. This is a great plane as a trainer (IMO) if it is setup correctly. My FC has become my favorite plane to just throw in the car (and if I bring more planes to the flying field) it is my warm up the "thumbs" plane
bassfisher is offline Find More Posts by bassfisher
Old Dec 27, 2011, 02:31 PM
United States, IL, Libertyville
Joined Jan 2011
Just finished my build. First kit since a kid. That took longer than I thought but she looks good. Question though: I got the Emax 2812/10 which has a 5mm shaft. It came with prop adapter but the APC 10x5.5 prop needs to be bored out to fit the shaft (0.313"). I tried on my drill press but it looks slightly off center. My bits are flat bottom with pilot tips. What should I do to ensure a properly centered bore? Wish I had adapter for that shaft that didn't require boring props. Any suggestions? Thanks.
daver22 is offline Find More Posts by daver22
Old Dec 27, 2011, 02:40 PM
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
You want to ream the prop bore using a reamer such as the General Tools hand reamer shown below.
Prof100 is offline Find More Posts by Prof100
Old Dec 27, 2011, 03:00 PM
Too much is just not enough...
Woody_99's Avatar
Joined Jan 2009
Take a look at the APC website. They talk about how to resize the prop to fit different shafts, and how to use the little adapters that came with your prop.
Good chance that you can oversize the hole you drilled a bit, and use the "precision" spacer they speak about.
I think that's the way it is meant to work anyhow. (at least that's what I've been doing and it seems to work.)
Woody_99 is offline Find More Posts by Woody_99
Old Dec 27, 2011, 03:12 PM
Joined Jan 2011
Thanks guys. I looked up the reamer and ordered one of those. Seems to make good sense Appreciate the info. Dave
Old Dec 27, 2011, 03:19 PM
Prof100's Avatar
Joined Jul 2007
Even with the advised precision spacer it still requires reaming to fit most collets.
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 Video Piloting (FPV/RPV) 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
