Old Sep 17, 2011, 12:01 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Prof100 View Post
AJ,
As usual, another well narrated AJ Productions video. I find the motor is using is pretty good but prefer the lighter gold 35-36C 1100 kv.
Bill
Thanks for the props. Yes. I agree on the 35-36C (I have 2 of them as you know) and that is what I would recommend to anyone that was asking about a motor for the FC. It is easily the most popular motor for the FC and it works great. Almost scale like. Here is my actual #'s:
3536C-1100
11x7
2300mah 20C - 352Wp
47 oz. thrust
42 oz. AUW
Will almost go sustained vertical
TGY 35-36-1400 (Japan motor)
10x4.7
2300mah 20C - 432Wp
60 oz. thrust
43 oz. AUW
Sustained vertical is simple and easy to control the rocket ship like movement.
That small amount of extra thrust allows a sustained vertical easily without going out of control at WOT. Or, another way of saying it - provides just enough over 1:1 that controlling it is very easy. That is pretty much why I suffix all of the above by saying it is perfect "for me". It is not at all like the 2505-2835 MD motor in the SkyS which was WAY over powered even for me. But, it sure makes the stock BL motor seem anemic now that it is back in the plane.
In summary, the best thing I can say is "Go Buy One" - you will not be disappointed - I promise. But, I can say that to YOU because I have a small understanding of your needs and your abilities and this motor fits both. If you hate it, I will buy it from you.
Again, for anyone new to the plane, I would still suggest the 35-36C-1100 for starters (or for permanent). It is a very good motor IMO.
AJ
ajbaker is offline Find More Posts by ajbaker
Old Sep 17, 2011, 12:11 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
3536C-1100
11x7
2300mah 20C - 352Wp
47 oz. thrust
42 oz. AUW
10x4.7
2300mah 20C - 432Wp
60 oz. thrust
43 oz. AUW
AJ
AJ,
Like you I have both but prefer the gold 1100 kv version simply because it weighs less and flys great with a 11x7 APCE.
Bill
Prof100 is offline Find More Posts by Prof100
Old Sep 17, 2011, 02:00 AM
mavlo77 is offline
Find More Posts by mavlo77
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Originally Posted by mavlo77 View Post
Could someone get me on the right track for programming crow on a DX8 and a 6 channel receiver for this funcub?
In principle it should be possible when the 2nd aileron is on the gear channel.
Should I select wing type 1 flap, 2 ailerons?
Or should I make a MIX AIL->GEAR? The advantage is that I could somehow assign this to a flight mode switch, so that when I fly on water I can use another flight mode control the gear channel for the water rudder on my floats, which I mix with the rudder (switcheable, and trim with the knob). Of course then I have to connect my 2nd aileron with a Y-lead and no crow function. But I accept that as a trade-off when flying from water.
Any hints of this is possible somehow?
Just to let you that this worked... I mixed the second aileron in a 1 AIL 1 FLAP setting and was able to make crow setting by using a mix for each aileron (FLP->AIL). This way the crow function is automaticly disabled when I switch the flaps to neutral. I also made an elevator compensation
I was surprised that much down elevator is needed to compensate for both ailerons up! Because for flaps (move down) also down elevator is needed, so I expected to need up-elevator .
Another point is that I was not very impressed with crow.
mavlo77 is offline Find More Posts by mavlo77
Old Sep 17, 2011, 04:58 AM
KenLB is offline
Find More Posts by KenLB
United States, FL, Kissimmee
Joined Feb 2011
exceed motor
Woody, hope your still happy with your Exceed 86MB26 motor from Hobby Partz. I went with your suggestion and mine arrived a week or so ago. Starting on my build this weekend.
Thanks for your help.
Ken
KenLB is offline Find More Posts by KenLB
Old Sep 17, 2011, 08:48 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
We had some good FunCub flying today.
Here's a pic of my Uncle's Cub performing a vertical take-off.
Full flaps, full up elevator, full throttle & a 10mph headwind = FUN!
Sammy70 is offline Find More Posts by Sammy70
Old Sep 17, 2011, 08:52 PM
Superduke is offline
Find More Posts by Superduke
Superduke's Avatar
Manhattan Beach, California
Joined Dec 2004
Vibration
Well, I finally finished the Cub and was testing the setup at home. Got the motor up to about 80% and here comes the bad vibration. Prop is balanced so not sure what's going on. I remember reading a few places here that you might need to reinforce the nose area? What a dissappointment.
Suggestions???
Superduke is offline Find More Posts by Superduke
Old Sep 17, 2011, 09:10 PM
RV4flyr is offline
Find More Posts by RV4flyr
RV4flyr's Avatar
Canada, ON, Brampton
Joined Mar 2011
Suggestions???
Yes, I had the same problem. The area behind engine mount needs stiffening. I had some carbon fibre avail. but you can use fibreglass cloth & lay in approx. 2.5 inches deep behind where front engine mount sits with cloth all around even covering side plastic mounts. I used 20 min epoxy between 2 pieces of vapour barrier plastic to squeege epoxy into cloth, then pull wetted cloth out of plastic & lay into mount area. You could also add a wood bulkhead across & behind where your motor sits. Hope I was clear enough for you.
KF
RV4flyr is offline Find More Posts by RV4flyr
bassfisher is offline
Find More Posts by bassfisher
The Balsa Farmer
bassfisher's Avatar
United States, AR, Sherwood
Joined Jul 2005
My Fun Cub (before I install everything)
bassfisher is offline Find More Posts by bassfisher
Old Sep 17, 2011, 09:13 PM
Robert H. May is offline
Find More Posts by Robert H. May
Robert H. May's Avatar
USA, VA, Bedford
Joined Jun 2003
Suggestions???
Superduke,
I reinforced the nose area by laying .5 oz. glass cloth over the side rails, but found that it didn't completely eliminate vibration. In my case, I found that with a CAREFULLY balanced prop, I was fine for first ten or twelve flights, then vibration! It was corrected by insuring that the two motor mount screws were snugged down well with ALL four of the thrust adjusting screws solid against the firewall. I'm left to assume that the motor mount screws had worked loose. I don't know about thread locker on plastic, but if vibration returns, I'm going to try it.
Just my thoughts and experience, for what it's worth....
Bob
Robert H. May is offline Find More Posts by Robert H. May
Old Sep 17, 2011, 09:14 PM
Sammy70 is offline
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by bassfisher View Post
my fun cub (before i install everything)
nice!!
Old Sep 17, 2011, 09:33 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Suggestions???
Yes, it is the dumb design where only two screws that hold the motor to the plane coupled with a floppy foam from end. Well designed planes have a firewall and 4 screws attaching the motor mount to the firewall. Not Multiplex.
The two screws have to kept torqued for starters. Lock washers or star washers (thank you Jurgen) help with that. Stay on them as part of preflight. If they loosen up the motor rocks around.
Second, there is a u-shaped slot on the side rails. Custom fit a piece of plywood or dowel that can be glued in so the two sides are locked together.
Third, recheck the prop balance in case you speed balanced it and it's not what is should be to prevent vibration.
I glassed it with .5 oz cloth and epoxy resin after assembling but I really don't think it did squart. On my second Funcub that's new in a box I am going to put a real firewall in the fuselage and mount the motor using four screws. Picture a conventional firewall with a motor mount.
Bill
Old Sep 17, 2011, 11:08 PM
Lear31A is offline
Find More Posts by Lear31A
Joined Jul 2006
I ordered this motor and I must say that it is a "drop-in" motor for this plane. All four mounting screws align perfectly into the mounting plate. Great service and speedy delivery as well. This was the first time purchasing from Heads Up RC and gotta say, I will be using these guys again for sure..........
http://www.headsuprc.com/servlet/the...8-motor/Detail
Lear31A is offline Find More Posts by Lear31A
Old Sep 17, 2011, 11:13 PM
Chappy110 is offline
Find More Posts by Chappy110
Chappy110's Avatar
WV-northern panhandle
Joined Oct 2008
Nice job on the Cub Bassfisher.
Superduke, as for the vibration problem with the motor, likely, as others have pointed out, the engine mounting screws in the plastic mount are no doubt your problem. I solved that by using the plastic engine mount as a template and cutting my own out of a piece of aluminum I had on hand. I cut away losts of the unnecessary material giving better air flow to the esc & battery as well. I'm no machinest I simply used a drill, a sabre saw, and a drimmel to finish it up. Works great and no vibration.
Chappy110 is offline Find More Posts by Chappy110
Old Sep 17, 2011, 11:31 PM
Lear31A is offline
Joined Jul 2006
Fantastic! great job, the motor mount looks good painted as well! I need to do that myself........
Old Sep 18, 2011, 12:12 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Very creative solution but you could have bought a CNC aluminum mount made by SOTOG from RCgroups directly from him, or at HeadsupRC.
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
