Old Jun 11, 2011, 12:02 AM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Originally Posted by Prof100 View Post
AJ,
At $2.15 who'd make one? That would decouple the tail wheel from servo.
Bill
Great point. Duh. I should have noticed that. I am going to order both ideas tomorrow. That is, unless someone contributes something else to try. Anyone else want to jump in. We are moving along now is a positive direction and I welcome any suggestions. KISS is sort of the principle that Bill (I hope is OK to include you) and I are working on right now. With all the brilliant guys here, there has got to be at least a couple of other ideas. For right now, we are using Tower Hobbies. But, any hobby store is OK with me.
AJ
ajbaker is offline Find More Posts by ajbaker
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by ajbaker View Post
At first glance, it does not look like it would have enough torque on the steering to keep the wheel turned. I think the caster effect might override the turning??? Hmmm... Don't know. Is that possible? Your thoughts.
AJ
AJ,
At first blush I think it would work perfectly. The servo moves the rudder, rudder turns and moves tail wheel. A HXT900 would be getting a workout. I am running 14 or 16 gram MG servos in mine. Pretty straightforward to me. The mods are dealing with the foam not being as strong as the balsa. The tail of the plane needs a piece of plywood glued in to retain plastic mount. I'd use blind nuts and 4-40 screws. Sure the tail would get heavier but the lipo would have to slid forward.
Bill
Prof100 is offline Find More Posts by Prof100
Old Jun 11, 2011, 12:06 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
AJ,
At first blush I think it would work perfectly. The rudder moves and the wheel follows. Pretty straightforward to me. The mods are dealing with the foam not being as strong as the balsa. The tail of the plane needs a piece of plywood glued in to retain plastic mount. I'd use blind nuts and 4-40 screws. Sure the tail would get heavier but the lipo would have to slid forward.
Bill
Naturally, I trust your glance more than mine in this area. The few grams of extra weight would be negligible. I have LOTS of room to move the battery rearwards. JTSHMPCT.
Oh. BTW - I used a Futaba S3101 servo (34oz. torque) for both the elevator and the rudder from day 1. The HXT900's made me feel a bit uncomfortable even though all the posts that I read say they work just fine. Now, especially, I am glad I did.
AJ
Old Jun 11, 2011, 12:09 AM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
AJ
AJ,
I like the Sullivan design, I will have to order three of them. One for each FUNCUB and one for MUS I have NIB. The Mini Ultra Stick just has a skid, no tail wheel.
Bill
Old Jun 11, 2011, 01:14 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
AJ,
Bill
While I am waiting to order those, I got started on a ground to servo disconnect. I think I am going to need stronger springs. But, I want to try it the way it is right now. The total compression of each spring is exactly equal to the throw of the servo. So, there is no way the servo can get hammered. But, flight info will tell me how much (or if) I need a stronger spring.
Next, I am going to put in a .078 piano wire tail wheel holder.
AJ
Old Jun 11, 2011, 01:56 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Progress.
I had to cut off the elevator to facilitate bending the .078 TW wire. The epoxy is setting up right now (30 min). That is enough for tonight. I took a LOT of pictures. But, this one is enough to show where I am at right now.
AJ
Old Jun 11, 2011, 02:02 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Originally Posted by mavlo77 View Post
not sufficient for real hovering. So that's why I want to test this 13x6.
In the static test I pulled 30 seconds WOT and the motor was just warm, not hot. So was the 40A ESC. As the Funcub is not a plane to fly WOT all the time, I guess it will do fine.
For hovering, you preferably want a prop with low pitch, not more pitch.
Check the current. A 13x6" might be too much prop for your motor.
Weight: 130g
KV(rpm/v): 1000
Max Power: 555W
Battery: 2-4Li-Po
Test Prop: 12x5/11x7
Ri(M Ω): 0.031
ESC(A): 60A
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 11, 2011, 02:08 AM
Joined Sep 2000
I am pretty sure that the real problem stems from the direct connection of the rudder servo to the ground (stupid design).
AJ
Same proven design as used on previous MPX models, like the AcroMaster, Gemini, EasyCub and although those models have been on the market for years, you don't read about "real problems".
Jürgen
Old Jun 11, 2011, 02:23 AM
Joined Sep 2000
The best planes in the world are German designs when voted on in a German RC magazine. No one should be surprised.
It is a vote by the readers of the magazine and of course you also find models from other manufacturers/distributors in the rankings.
Jürgen
Old Jun 11, 2011, 02:30 AM
Joined Sep 2000
Looks rather heavy for a model like the FunCub, but if you need weight in the tail because you are running a heavy motor or FPV gear in the nose, why not?
Jürgen
Old Jun 11, 2011, 02:57 AM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
This one mite be even lighter and has springs to take the shocks , not the servo......But hey whats a few grams when you can move your lipo forward a little.....Nothing
http://www3.towerhobbies.com/cgi-bin...&I=LXHVC4&P=ML
Cheers
Ian
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Jun 11, 2011, 03:08 AM
Joined Sep 2000
So, there is no way the servo can get hammered. ...
When looking at the servo installation, I can understand why AJ had problems applying the decor, as his servo is not installed as intended, but there are also some other issues:
Old Jun 11, 2011, 03:29 AM
Joined Nov 2002
Gee mate...you go to a lot of trouble to ni....er .....'help' others on these forums..
Ian
Old Jun 11, 2011, 03:38 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Cheers
Ian
Talk about KISS. That is excellent. Simple build - very straight forward design. Totally decouples the servo from the any ground attacks. Great feedback. Thank you. - That is why I waited to order stuff from Tower. I will include your suggestion now. I see Jergen has a lot of posts. I feel somehow that they are not helpful to my project, though.
AJ
Old Jun 11, 2011, 03:49 AM
mavlo77 is offline
Find More Posts by mavlo77
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Jürgen
Yes, I realize... actually I was prefering a 13x4 prop for the reason you give (lower pitch). But couldn't find it in the local hobby store (tried 2 or 3 in the past months).
Also I have a 900 kV motor available. Probably that is a better match. But then I need to swap motor when flying in rough field....
So better start looking for 13x4 (and being easy on the throttle) or 12x4 and keep the 1000 kV.
In the meanwhile I still try this prop and being very carefull on the throttle.
Will post video if I have tried it.
mavlo77 is offline Find More Posts by mavlo77
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
