Old May 28, 2011, 05:30 PM
More Altitude, Less Attitude!
chickenwing's Avatar
United States, SC, Ninety Six
Joined Mar 2008
Originally Posted by SON OF PALEFACE View Post
FWIW....I think this is a FUN plane not a 3D ...its not deigned for 3D , there are much better planes for that....any plane can just hack around the sky , I have fun low and slow seeing how slow I can fly it ect......so I slow it down and then pop the flaps with what I think is the right amount of down mix for that flap position..........whatever turns your crank.....
I was very pleasantly surprised at just how slow this plane could fly. I'm a big fan of low and slow myself. Most of the models I fly are not built for speed. I like to relax. The Fun Cub could be the perfect plane. Slow when you want it. Power when you need it.
chickenwing is offline Find More Posts by chickenwing
Old May 28, 2011, 06:43 PM
I fly lawn darts with wings.
United States, CA, Turlock
Joined Apr 2011
So it looks like my fc will take a few more days, somehow between 3 weeks ago and now I managed to lose the sotog mount. Ordered another.
mbreslin is offline Find More Posts by mbreslin
Old May 28, 2011, 07:14 PM
Why so serious?
2500GENE's Avatar
United States, FL, Cape Coral
Joined Dec 2007
You said I could take it. Geeze.
2500GENE is offline Find More Posts by 2500GENE
Old May 28, 2011, 07:26 PM
Joined Apr 2011
When will it stop Gene, when will it stop.
Old May 28, 2011, 07:28 PM
Why so serious?
2500GENE's Avatar
Joined Dec 2007
I think it's around 12/22/2012 or so. Not sure.
Old May 28, 2011, 08:50 PM
Joined Apr 2011
How far did you guys extend the linkage cover/tubes toward the rear of the plane? Just long enough to fill the groove and the rest just the bare wire?
Thanks.
Old May 28, 2011, 08:51 PM
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Thanks.
I made mine go about an inch past the grooves.
Also glued a little foam block under that last inch to angle the tubes out where they need to go.
Sammy70 is offline Find More Posts by Sammy70
Old May 28, 2011, 09:51 PM
Joined Apr 2011
Thanks Sammy. Next question.
From Prof100's blog: "On next FunCub 2 build use the approach seen below that Landcruiser used, that is use a scrap piece of push rod tube glued into rudder"
Can someone explain the purpose of this a little?
Thanks.
Old May 28, 2011, 10:00 PM
JOHN 3:16
Sammy70's Avatar
Central Ohio
Joined Feb 2008
So that the tail wheel wire won't be riding inside the foam rudder only.
Glue a section of c/fiber tube or plastic tube into the rudder and then slide/glue the tail wheel wire into that tube. Clear as mud?
Old May 28, 2011, 10:07 PM
Joined Apr 2011
Got it, thanks.
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Thanks.
It is just a much simpler way to form the wire and mount the tail wheel gear. The stock design is a regular rubics cube of a design.
Prof100 is offline Find More Posts by Prof100
Old May 28, 2011, 10:55 PM
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Flapping around
Originally Posted by Azarr View Post
1. Is there an ideal flap speed?
2. Am I correct in thinking I want to set a delay in the elevator compensation so that it reaches it's position at the same time the flap does?
I mostly fly 3D stuff, lots of experience with flaperons and elevators moving opposite each other for tight maneuvers, but none with straight, scale type flap use.
Azarr
1. Whatever you choose is correct.
2. Well, yes. If you want to make your task easy, use one of THESE. It has more features than you need. But, it will do anything that you desire.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 29, 2011, 01:34 AM
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Motor suggestion.
Originally Posted by Prof100 View Post
AJ,
No, the Funcub will fly best with a low KV motor. Never mind the modifications you will have to make to mount it in the FC. Keep the little MicroDan 2505's for SS and pusher jets. The MD 2510, 970 KV would work if you wanted to build a lightweight Funcub. http://www.gobrushless.com/shop/inde...&ref=MD2510-LE
The MD2505 and Grayson Super Mega will both work fine in a SS, Easy Star, etc. I do believe the 34 gram weight of the MD 2505 is a distinct advantage. For me, I am hooked on Microdan motors.
BTW, Dr. Kiwi, as I recall, never tested the 2505, 2535KV motor. He tested a 1800kv or so.
Bill
That is precisely what I want to do. Since we have shared ideas together several times, you figured out what I was up to right away. Some people lack imagination. Your suggestion is perfect for my needs. Thank you very much for your input. Also, I am planning on getting rid of the LG and never setting up ailerons and flaps. I am pretty sure I can still balance it using a 1500mah LiPo. I will use whatever it the lightest I can use and still get CG. With several other weight reduction methods, I think I can get the FC below 33 oz. Of course, I will start with a brand new one. I will order just the foam stuff because the rest of the stuff I need, I can build a lot lighter. Thanks again for your feedback.
AJ
Old May 29, 2011, 02:53 AM
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
The stock design is just a 90° bend in the wire also. You just do the bend in another direction, so that you can glue the wire more firmly to the rudder horn.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 29, 2011, 02:58 AM
Joined Sep 2000
Originally Posted by ajbaker View Post
Also, I am planning on getting rid of the LG and never setting up ailerons and flaps....
In this case it is no longer a FunCub, but an EasyCub, which is much better suited for rudder/elevator only, because it has the correct dihedral for that.
Jürgen
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 Video Piloting (FPV/RPV) 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
