Old May 26, 2011, 07:38 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by mbreslin View Post
But I'd like to be able to go vertical at times without worrying about torching the motor. This is the only reason I am considering the 11x5.5 or even 10x5.
mbreslin,
Go back to the bad video I posted (the one with three planes that was too dark). You can see the 11x7 apc e on that Funcub and it goes vertical several times. Just don't try for orbital insertion.
Bill
Prof100 is offline Find More Posts by Prof100
Old May 26, 2011, 07:42 PM
mbreslin is offline
Find More Posts by mbreslin
I fly lawn darts with wings.
United States, CA, Turlock
Joined Apr 2011
Originally Posted by Prof100 View Post
mbreslin,
Bill
This made me laugh out loud. Orbital insertion is something I laugh about trying with my easystar. I've been tempted to get some autofocusing binoculars and some kind of head gear and an altimeter gadget or watch or something I could stick on board and just see how high I could go.
mbreslin is offline Find More Posts by mbreslin
Old May 26, 2011, 08:55 PM
Sparken57 is offline
Find More Posts by Sparken57
*GRAVITY* I hate it :(
Sparken57's Avatar
USA, CA, Downey
Joined Jan 2010
Hi Mbreslin if you want to check your highest Altitude get one of these.
http://www.amazon.com/Eagle-Tree-ALT...f=pd_rhf_p_t_1
Sparken57 is offline Find More Posts by Sparken57
Old May 26, 2011, 10:34 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Options
Or, rent some time on a Saturn 5.
AJ
ajbaker is offline Find More Posts by ajbaker
Old May 27, 2011, 09:17 AM
chickenwing is online now
Find More Posts by chickenwing
More Altitude, Less Attitude!
chickenwing's Avatar
United States, SC, Ninety Six
Joined Mar 2008
Power System Testing
Power System:
E-flite Power 10 1100Kv
* 32A Continuous
* 42A (15 sec)
E-flite 40-Amp Pro Switch-Mode BEC Brushless ESC
* 40A Continuous
* 55A (15 sec)
Sky Lipo 11.1V 2200mAh 40C Battery
APC 11 x 7E Propeller
Testing:
1/2 Throttle:
10.08 Ap
123.1 Wp
1 Tick Past 1/2 Throttle:
20.08 Ap
238.3 Wp
2 Ticks Past 1/2 Throttle:
36.97 Ap
425.1 Wp
I have ordered an APC 11 x 5.5E to test. I'll post the results when it comes in.
chickenwing is online now Find More Posts by chickenwing
Old May 27, 2011, 10:56 AM
mbreslin is offline
Joined Apr 2011
AJ: I've decided to paint first (an awesome shade of blue I haven't decided on yet). Are you happy with the paint you chose? Would you use it again? And can you list the brand/type again please?
Thanks.
Old May 27, 2011, 02:27 PM
mxandrews1 is offline
Find More Posts by mxandrews1
United States, CA, San Gabriel
Prop/Motor question?
Hi gang,
The recommended power pack setup comes with a 13x4 prop Using this power setup, what is the smallest prop I could safely use?
I'm looking for something shorter so blade strikes will be less prone.
mxandrews1 is offline Find More Posts by mxandrews1
Old May 27, 2011, 05:25 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Paint to use.
Thanks.
Ask around what other folks are using. My turned out terrible. I would not use it again for anything. Ask Prof100 what he used. His turned out excellent. He told me buy whatever it was and I forgot right after I found out that it was not available in this area.
After some looking, I found it, I think. Here is what I should have used. THIS is what Prof100 used on his. Take a look at his blog. It is NICE.
AJ
Old May 27, 2011, 05:34 PM
mbreslin is offline
Joined Apr 2011
AJ,
It is automotive touch up paint that comes in small and large cans. They sell acrylic enamel and acrylic lacquer. I used the acrylic enamel chrome yellow. For a top coat I used the clear coat. These automotive paint colors go on flat and gloss is achieved with clear top coat. Film build is minimal to achieve full coverage. No primer is required. The white foam is an excellent palet Good stuff.
You can buy this at most automotive part stores. Advanced Auto and O'Reilly Autoparts are stores in my part of the country. A large can is $6.
You can also repaint your golf cart.
Here is a picture of the can.
Found it, (posting for my reference).
Thanks AJ.
Old May 27, 2011, 05:40 PM
mbreslin is offline
Joined Apr 2011
Originally Posted by ajbaker View Post
mbreslin-How are you doing with your decals?
I saw this while hunting for prof's post, hadn't seen it before, sorry. My plane only came today, I really wish I could get a blue version the of decal sheet. I will probably put some on we'll see.
Old May 27, 2011, 05:44 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
AJ
Yes, I used automotive touch up paint by Duplicolor. They make a acrylic enamel and and acrylic lacquer. I used the chrome yellow acrylic enamel. I have not tested the lacquer on the elapor foam.
I topcoated Future Floor wax which is pure, water based acrylic would work just as well for a top coat. The multi part pictures have accurate color.
Old May 27, 2011, 08:21 PM
Joined Mar 2008
Maidening Tomorrow!
Looks like a fine day to maiden the Fun Cub tomorrow morning.
Aviation Weather Forecast at Greenwood, South Carolina
I'll let you know how it goes.
Old May 27, 2011, 08:37 PM
PikeStaff is online now
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Bon voyage! And good luck!
PikeStaff is online now Find More Posts by PikeStaff
Old May 27, 2011, 08:41 PM
This is a repost:
Old May 27, 2011, 09:14 PM
Joined Mar 2008
Originally Posted by mxandrews1 View Post
This is a repost:
The recommended power pack comes with a 840Kv motor. A low speed/high torque motor screams for a big prop to get the best performance. I probably wouldn't consider a prop less than 11". The answer really depends on how you want to fly. You really need a combo that generates 50-70 watts of power per pound just to stay airborne. 70-90 watts per pound for just cruising. 90-110 watts per pound for decent aerobatic performance. 150-200 watts per pound for unlimited vertical and 3D performance. If you don't already have a watt meter, invest in one. I find mine very helpful.
I think a smaller prop will need a higher pitch number for comparable performance. Take a look at the manual for the motor here... Himax HC3516-840 Motor Manual. See the chart on page 2.
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
