Old May 23, 2011, 01:15 PM
desmobob is offline
Find More Posts by desmobob
Arc, spark and smoke...
desmobob's Avatar
upstate NY; Lake George region
Joined Mar 2006
Originally Posted by desmobob View Post
I plan to maiden my FunCub tomorrow morning with a Master Airscrew 11x5 E prop while I'm waiting for my 11x5.5Es to arrive. I'll let you know how it works out!
I finally got to fly my FunCub yesterday. I'm very pleased with it!
My set-up:
-E-Flite Power 10 motor
-Castle Creations Thunderbird 36 ESC
-Dimension Engineering SportBEC BEC (set at 5V output)
-Futaba 7ch FAAST Rx, 7C Tx
-Zippy 3s 2200mah 40C and Lightmax 3s 2100mah 40C batteries
-Master Airscrew 11x5 e-prop
-Hi-Tec HS-81 rudder and elevator servos
-Hi-Tec HS-65 aileron servos
-Turnigy TGY-90S flap servos
I had intended to use an APC 11x5.5E prop, but didn't have one handy. The MA 11x5 worked very well. I have a couple of 11x5.5Es on the way.
I was flying mixed-throttle flights with my timer at 8 minutes. On one flight, I decided to push a little further and hit the low voltage cut-off very soon afterward. I moved my timer back to 7 minutes. The flight batteries were just warm after flights. I never remembered to feel the ESC or motor to see how they were. I was having too much fun!
It was a windy day (wind sock out straight at times) but the FunCub had no trouble. With half flaps, I could get airborne in approximate one foot. Without the headwind, I figure it may roll as far as two feet before getting off the ground.... I didn't try any full flap take-offs.
One thing I noticed on the first circuit around the field is that the FunCub maintained the bank angle I put it at. It didn't seem to self-correct like a typical high-wing model. It liked healthy rudder inputs for turns. It felt solid and stable and I was impressed with the way it flew. Maybe it's because it's made of foam, or because of the cartoonish looks of the over-size wheels, but I guess I was expecting it to fly like a trainer. I was happy to find it flies like a Cub!
I had programmed 20% down elevator to full flaps in the Tx and the half flap flight was perfect: no pitch change. It was not enough for full flaps though, and the FunCub still would pitch up a bit with the flaps all the way down.
As far as CG, I didn't actually measure it. I knew I was well forward of the manual's recommendation and flew with the rear of the flight battery even with the forward edge of the cooling hole in the bottom of the fuse. This seemed to be just right for normal flying, but the FunCub required a considerable amount of down elevator for inverted flight.
I used the manual's recommended settings for the motor mount thrust angles and the model maintained a steady pitch during abrupt throttle changes. I used one of Sotog's CNC aluminum motor mounts and was surprised when guys in the club who had never seen a FunCub commented on the nice motor mount.
I had loads of fun with the plane and will surely fly it a lot.
I hope everyone has good luck and lots of enjoyment from their FunCubs!
Good flying,
desmobob
desmobob is offline Find More Posts by desmobob
Old May 23, 2011, 02:05 PM
MLT67 is offline
Find More Posts by MLT67
Joined Nov 2005
Originally Posted by Jurgen Heilig View Post
You can always start with a smaller prop to make it tamer for your daughter.
Make sure that you have the newer Airboss ESC with SBEC, otherwise you need a seperate BEC to power those servos.
Jürgen
Thank you for your reply - I ran this combo in a EF 48" Extra so it's a proven combo for me and yes it is the new ESC with a 6 volt switching BSC. My concern was that the motor might be too big/heavy but if you guys think it's not then I'll give it a try. I'll start off with a 12 x 6 and go from there. I've read so many good things about this plane - I think it will be a good aileron trainer for my daughter but also very fun for me as well.
Thanks again for the help.
MLT
MLT67 is offline Find More Posts by MLT67
Old May 23, 2011, 02:18 PM
morrigan is offline
Find More Posts by morrigan
morrigan's Avatar
Deutschland, BW, Ebersbach an der Fils
Joined May 2011
Hi,
Alu mount plate arrived last week. Solved my vibration Probs a bit. It even worked with the original motor mount as well, but as using only 2 instead of 4 screws had vibration if motor shaft was bend a bit or a screw was not fit perfekt.
With 4 screws it ist better.
Even the Air Flow and cooling is better. Motor comes down quit cool now.
As you can see in the photo air could flow now on the outside of the motor as well the alu mount himself could take a bit of the heat
The Photos in the Water was taken in the Garden Pond yesterday. First Time with Floats. Looking forward to fly with them.
On water it works without water ruder. Was steerable with ruder only...
Had over 60 Flys now with FC.
Turnigy 35-42 1250 Kv @ 11x5.5 prob. Tried a 10 x 5 Prop Yesterday. Less Thrust, a bit slower, but didn´t save a lot of energy. Was wondering about that.
Normaly could fly between 10 and 15 minutes, but also could emty a 2200maH Battery in less than 5 minutes.
I love the FC, but i have a big Problem.
What Plane i will buy next? What Plane make me half as happy as the Funcub doo?
Think next Plane will be a Fun Cub again
Testet 1300 mah Batterys as well. Could feel the difference between wight.
I think it could be interested to have a lightwight Fun Cub als well as a overpowered Fun Cub.
What are the other Planes for ???
morrigan is offline Find More Posts by morrigan
Old May 23, 2011, 02:37 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Bigger vertical fin and rudder ...
on newer Fun Cub kits - see picture:
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 23, 2011, 02:46 PM
F1 Rocket is offline
Find More Posts by F1 Rocket
Melbourne, FL
Joined Dec 2004
Cool Looks like there will be a super duper FunCub in my future. Do you know if there is a part number change?
Danny
F1 Rocket is offline Find More Posts by F1 Rocket
Site Sponsor
Old May 23, 2011, 03:29 PM
GBX is online now
GBX
Find More Posts by GBX
GBX
Illinois
Joined Jan 2005
Sold my twister kit
So the Fun cub will be my first official Build with Multiplex
Plan on using a Hacker A30-16 V2
I will hold out untill the New Updated Funcub stock is in the states
Jürgen do you know if it will have a new stock number?
Geoff
GBX is online now Find More Posts by GBX
Old May 23, 2011, 03:33 PM
mbreslin is offline
Find More Posts by mbreslin
I fly lawn darts with wings.
United States, CA, Turlock
Joined Apr 2011
Originally Posted by GBX View Post
Sold my twister kit
Geoff
Sucks I just ordered last night.
Oh well I can always grab a tail set or something later? Who knows.
mbreslin is offline Find More Posts by mbreslin
Old May 23, 2011, 03:36 PM
mavlo77 is offline
Find More Posts by mavlo77
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Ordered mine 6 weeks ago, and it has the big rudder.
mavlo77 is offline Find More Posts by mavlo77
Old May 23, 2011, 03:40 PM
mbreslin is offline
Joined Apr 2011
Cool, hopefully they've made it to the states. Thanks for the info.
Old May 23, 2011, 04:00 PM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Need some help with the connectors
Solved
Old May 23, 2011, 04:09 PM
guy hanson is offline
Find More Posts by guy hanson
guy hanson's Avatar
Joined Jan 2011
Here is my new Fun Cub
weight is 38 ounces with 1800ma 3 cell pack and the EFlite 10 motor and 40 amp EFlite ESC
The other model is 16 ozs at 400squares - a stand off profile of a Pilatus Porter. homely but very quick
Fun planes for the summer -if summer ever comes to us
guy hanson is offline Find More Posts by guy hanson
Old May 23, 2011, 04:15 PM
guy hanson's Avatar
Joined Jan 2011
Mine was from Horizon-two weeks ago and is latest version.
Old May 23, 2011, 04:45 PM
morrigan is offline
morrigan's Avatar
Joined May 2011
Flight Video. Sorry for poor video quality (and flight skill)
next time i have to hire jürgen, he makes better videos (mayby Pilots are better )
Multiplex Fun Cub slow and low, vertical (10 min 49 sec)
Vids are taken by Keycam and digital Photo, so no zoom change is possible while taking video.
Bernd
Old May 23, 2011, 04:58 PM
mbreslin is offline
Joined Apr 2011
http://www.youtube.com/watch?v=W8h7kuSbd0k
Bernd
I love the slow flying with the flaps down, I thought you were underpowered at first until later in the video you were moving quite fast.
I can't wait to do the same.
Can you share your setup please?
Thanks.
Edit:
Scheduled Delivery: 27-May-2011
Just got shipping from advantage hobby, was worried I wouldn't get it in time to spend the weekend building, looks like I will, can't wait!
Old May 23, 2011, 07:16 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
You are the one who said you just copy Prof100! I am seriously thinking of parroting someone else! Do you think 11x7 is too much prop for that motor?
Thanks.
I don't know is the simple answer. I plan on using whatever prop combination that will consume around 30A WOT. I am a WOT sort of guy and I have burned up enough ESC's and motors to learn to stay within the specs of the motor. I will let you know when I post my final configuration here.
AJ
ajbaker is offline Find More Posts by ajbaker
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
