Old May 18, 2011, 05:02 PM
bubbleman is online now
Find More Posts by bubbleman
bubbleman's Avatar
United States, TN, Cornersville
Joined Jan 2007
Originally Posted by mbreslin View Post
So while I'm waiting for various parts to come in I thought I would ask, is this a plane that can be flown (turned) using mostly rudder? This will be my first aileron plane and I'd like to ease into them, if not it's not a huge deal but it sure would be nice.
You will be surprised at the ease of the change to ail control.
With the 4 ch setup you will have the ail and ele on the right stick and throttle and rudder on left stick. For easy flying around you will use about the same amount of elevator in the turns as you do with a RET 3 ch. (bank and yank) Steering on the ground will be your first challenge. You will find out what all the talk about the dumb left thumb is about. If you have learned to do a stall turn with the 3ch, you will have to unlearn that and learn with the left hand.
Good flying.
Anton
bubbleman is online now Find More Posts by bubbleman
Old May 18, 2011, 05:26 PM
mbreslin is offline
Find More Posts by mbreslin
I fly lawn darts with wings.
United States, CA, Turlock
Joined Apr 2011
Good flying.
Anton
Thanks, I'm excited, but nervous. (!)
mbreslin is offline Find More Posts by mbreslin
Old May 18, 2011, 05:49 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
We all fly Mode one down under... and in Great Britain...much easier than tying to mix roll and pitch on the same stick...
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old May 18, 2011, 06:08 PM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
I dont think theres as many as there used to be flying Mode 1 in the UK, only us old timers.
I started flying over 30 years ago, i have tried Mode 2 but always seemed weired to me, I have more precise control on Mode 1.
Splitting the primary flight controls of Elevator / Aileron always seemed better, you are not sitting in aircraft so no reason to have them on same stick.
Del-Dredd is offline Find More Posts by Del-Dredd
Old May 18, 2011, 07:00 PM
ajbaker is offline
Find More Posts by ajbaker
Argue for your limitations
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Not typical MPX
Originally Posted by PikeStaff View Post
+1 on the thicker wing - portside. Apparent at the joiners; a good 1/16" taller on the topside. I've tried to get it flat to no success.
Yup. I have exactly the same problem. Poor quality control. I just got mine about two weeks ago.
AJ
BTW- Anyone - Did you have to paint the windows in? Or am I missing the decals somewhere?
ajbaker is offline Find More Posts by ajbaker
Old May 18, 2011, 07:04 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
AJ
AJ,
There are decals.
Bill
Prof100 is offline Find More Posts by Prof100
Old May 18, 2011, 07:26 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Give me windows.
Originally Posted by Prof100 View Post
AJ,
There are decals.
Bill
Obviously, I am going to have to look closer. I only have 2 decal sheets. I will take a picture of what I have if I don't find them.
AJ
UPdate: Duh. They were buried under all the foam packing. Thanks.
Old May 18, 2011, 07:31 PM
mutha is online now
Find More Posts by mutha
RC Airplane (Recently Crashed)
mutha's Avatar
Australia, VIC, Melbourne
Joined Jan 2011
Mine is perfect ... because I haven't had time to open the box yet!!
mutha is online now Find More Posts by mutha
Old May 18, 2011, 07:36 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
I have a second, NIB, Funcub which I will scrutinize the wings and work out a solution to left panel being too thick (if it is).
The final adjustment to the saddle area was no big deal. I have done it before on balsa and other foam planes.
Old May 18, 2011, 07:48 PM
PikeStaff is offline
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
AJ, don't let this really minor aspect turn you off. While it bugs me when on the ground, it cannot be seen when the FunCub is doing what it truly does best. And there is no evidence whatsoever that it affects those incredibly good qualities.
This airplane is wonderful. Any of the perceived problems disappear completely when you're flying it on a calm, cool evening, with the setting sun as your backdrop.
PikeStaff is offline Find More Posts by PikeStaff
Old May 18, 2011, 09:36 PM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Fun Cubbing soon.
Thank you very much for your support. But, don't worry about me. I have built and flown 100's of planes over the last 40+ years and this is nothing. Perhaps I dramatized it too much. It is all good and I am sure I will love it. Thanks again.
AJ
Old May 18, 2011, 09:48 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
AJ
AJ,
You will like it.
Bill
Old May 19, 2011, 01:26 AM
ajbaker is offline
ajbaker's Avatar
Lincoln, CA
Joined Oct 2006
Make the spar stronger?
What do you think about doing the same thing that we do with the Sky Surfer by slipping a 6mm CF tube in the 8mm stock CF tube for additional spar strength (of course, the SkyS is 6mm to start with)? Is it even necessary for a WOT inside loop? Your thoughts?
AJ
Old May 19, 2011, 02:49 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
AJ
As I have never read about a spar failure on the Fun Cub, I would save the additional weight of inserting a small tube into a big tube.
The Fun Cub uses a total of 1000mm of 8/6mm CRP tubing weighing approx. 33g. Adding an inner 6/4mm CRP would provide approx. 37% more strength, it would increase the weight of the tubes by approx. 71%.
There is also no point, making the spars very much stronger than the joining element.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old May 19, 2011, 03:47 AM
Sparken57 is offline
Find More Posts by Sparken57
*GRAVITY* I hate it :(
Sparken57's Avatar
USA, CA, Downey
Joined Jan 2010
Go Green
Originally Posted by Azarr View Post
I don't mind the Multiplex instructions at all. I've had kits From other manufacturers that had no instructions at all, none in my language, and some with just drawings that were barely decipherable.
It just makes sense from a manufacturing viewpoint. Not only does it save the cost of producing and storing a bunch of different manuals, it allows them to ship to any country. Otherwise they would have to maintain separate inventory for each language. Then what happens if you get a large order for the US when you have a warehouse full of kits with German instructions?
Azarr
Don't you think they could save a lot of ink & paper by not sending 4 manuals to every customer ! Lets be green.
Sparken57 is offline Find More Posts by Sparken57
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
