Old Mar 03, 2011, 09:18 AM
bigmoebbq is offline
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
Originally Posted by ToxicBanana View Post
I used HS81 & HS55 and there are more then plenty
I used Hobbypartz 9gr Metal gear all through mine never had a servo fail yet..lol
bigmoebbq is offline Find More Posts by bigmoebbq
Old Mar 03, 2011, 11:24 AM
crobar is offline
Find More Posts by crobar
crobar's Avatar
United States, ID, Athol
Joined Apr 2009
Originally Posted by Sammy70 View Post
That should work fine...
What kind of flexible glue can be used when mounting the servos so they can be readily removed later on for repair etc? I tried RTV but it just seems to remain slimey.
Also I was wondering what the square shaped cups on the rear of the motor mounts are for?
crobar is offline Find More Posts by crobar
Old Mar 03, 2011, 11:25 AM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by crobar View Post
What kind of glue can be used when mounting the servos so they can be readily removed later on for repair etc. I tried RTV but it just seems to remain slimey.
A little dab of hot glue is all I've used on dozens of servo installs....
Sammy70 is offline Find More Posts by Sammy70
Old Mar 03, 2011, 12:06 PM
crobar is offline
crobar's Avatar
Joined Apr 2009
Thanks - I'll give it a try.
Old Mar 03, 2011, 01:14 PM
sotog is offline
Find More Posts by sotog
sotog's Avatar
United States, CA, Santa Barbara
Joined Nov 2009
Originally Posted by SARG5 View Post
What do you folks know about
www.hobbypeople.net
OUT OF CALF.
SARG5
They have been around for a long time and I used to go into their retail store all the time.
At least at the store in Camarillo, CA the service is not that great. I have called numerous times over the years asking if they have a part in stock. They would always say 'yes we have it right here'. I would make the 45min drive to their store to find out they don't, and no one their would admit to even talking to me. Just happened for the last time a month ago. Never going back to their store again!
Never dealt with them on line, but it could just be the employees at that store. Seems like they always hire very unfriendly people there.
But that's just my experience. I'm sure they do well with most people since they have been around for a while.
sotog is offline Find More Posts by sotog
Site Sponsor
Old Mar 03, 2011, 01:16 PM
JBrant is offline
Find More Posts by JBrant
Joined Jul 2005
Attn. Skypileit
Sorry for the delay in answering your question on the weight of my Fun Cub. I had to get my scales back from my son as I did not want to trust my memory. It is on floats right now and as such weighs 31.45 oz. without lipo. Memory told me it was 31.25 oz. on wheels. Seems like the floats should weigh more but this is what I weighed them at.
Jim
JBrant is offline Find More Posts by JBrant
Old Mar 03, 2011, 05:30 PM
SKYPILEIT is offline
Find More Posts by SKYPILEIT
Minekraft & RCG for me
SKYPILEIT's Avatar
Novi, Michigan
Joined Nov 2002
Jim
Thanks Jim
JIM
SKYPILEIT is offline Find More Posts by SKYPILEIT
Old Mar 03, 2011, 08:09 PM
ids911 is offline
Find More Posts by ids911
ids911
ids911's Avatar
GA
Joined Jan 2009
cobar,
try wrapping the servos with blendern tape then hot gluing in place. It makes it easier to remove glue from the servos when repairing or moving them to a "new" plane!
Ian
ids911 is offline Find More Posts by ids911
Old Mar 03, 2011, 08:33 PM
Prof100 is online now
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Originally Posted by ids911 View Post
cobar,
Ian
cobar,
I used to tape up the servos before gluing them in with hot glue. I tried blenderm, blue painters tape and the like. It didn't really make any difference removing or replacing the servos. I chalk it up as a urban legend.
Bill
Prof100 is online now Find More Posts by Prof100
Old Mar 03, 2011, 08:44 PM
mitsudriver274 is offline
Find More Posts by mitsudriver274
Joined Jul 2009
Aileron differential
I have a few flights under my belt with the funcub. I was curious how people are setting up aileron differential, I have a dx6i.
Also I noticed the funcub could use a aileron > rudder mix. What have you guts found that works well
mitsudriver274 is offline Find More Posts by mitsudriver274
Old Mar 03, 2011, 08:49 PM
Prof100's Avatar
Joined Jul 2007
You can do aileron differential (50% less down that up aileron) mechanically with the servos installed in parallel and connected on a "Y." Or you can use two channels and program it in with your radio. Either way works and its a must for any high wing trainer plane. The mechanical method allows you to use fewer channels on your radio. I posted a video on aileron differential and flaps earlier in this thread.
Here it is again:
FunCub aileron and flap demo (benchtop with explanation) (3 min 36 sec)
Old Mar 04, 2011, 01:03 AM
crobar is offline
crobar's Avatar
Joined Apr 2009
Thanks guys for the info on hot melt glue. I will give it a go tomorrow.
Nice video Prof.
Old Mar 04, 2011, 03:52 AM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
What are the length of the funcubs floats?
Dakrat is offline Find More Posts by Dakrat
Old Mar 04, 2011, 06:11 AM
Sammy70 is offline
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Originally Posted by Prof100 View Post
cobar,
I used to tape up the servos before gluing them in with hot glue. i tried blenderm, blue painters tape and the like. It didn't really make any difference removing or replacing the servos. I chalk it up as a urban legend.
Bill
Agreed
Old Mar 04, 2011, 08:35 AM
SARG5 is offline
Find More Posts by SARG5
SARG5
SARG5's Avatar
10 Miles north of Russell, Ks. on US281 hy
Joined Oct 2009
SARG5 reporting SAD TIMES
My Fun Cub went in last evening on the maden flight. I do not went wrong.
Now you understand that I am not the best flyer on the branch.
Take off went great, about a 10 foot roll out. Then things went very wrong. I just cound not get control of the plane. It was all over the sky. Kept getting futher and futher away. At one point it looked like I had control, then it went into the sun, Did not see it hit some 500 yards away.
Wings are OK, It went stright in. The nose is gone. Do not think it is even close to being repairable. Broke the motor mount into 3 pieces. Lipo was damaged. What a mess.
I will do some more testing this AM. But am thinking back. I would say that I had the ailn. reversed. Did not have a problem with alt.. And, I checked, rechecked and looked again at everything.
This is my first VERY BAD CRASH over times. Most have been able to fix up.
I will be checking today. Assume that if I purchase a new fusg., motor mount . I might as well order a new FC. Then use this one for future parts.
SARG5
CRASHING THE SKY WE DEFENDop corn:
SARG5 is offline Find More Posts by SARG5
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
