Old Apr 26, 2010, 04:49 PM
eran_k is offline
Find More Posts by eran_k
Eventually...I will fly
Israel
Originally Posted by -MM- View Post
I use standard setup for EasyCub with 2s2100mAh or 3s950mAh battery.
So if it fly so well on the easycub setup, why does MPX sugest such a bigger and heavier setup? just the motor is almost twice the weight og the easycub unit,wont it effect the CG drasticly?
maybe it's a good idea is to find an "in between"" setup
Eran
eran_k is offline Find More Posts by eran_k
Old Apr 26, 2010, 07:36 PM
gnko is offline
Find More Posts by gnko
gnko's Avatar
Joined Jul 2007
Originally Posted by -mm- View Post
yes, with 3s battery.
Martin
and standard prop 10x7?
George
gnko is offline Find More Posts by gnko
Old Apr 27, 2010, 04:01 AM
-MM- is offline
Find More Posts by -MM-
Joined Sep 2005
Prop is standard 10x5.
The MPX-FunCub motor setup makes sense if you like to pull gliders or maybe to do torque rolls
I also try the Himax HC 3510 – 1100 with 12x5,5 prop. This is the best compromise in my opinion.
Martin
-MM- is offline Find More Posts by -MM-
Old Apr 27, 2010, 09:52 AM
-MM- is offline
Joined Sep 2005
Martin,
Looking at the pictures, it appears you added quite a bit of motor down thrust on the EasyCub. How much downthrust was added and are you using the same COG as in the manual?
Oh I forgot to answer this. sorry!
I make no changes. Down thrust and COG are same as recommended in EasyCub manual.
Maybe with stronger motor, you need some more down thrust.
Martin
Old Apr 27, 2010, 10:18 AM
Phoenex is offline
Find More Posts by Phoenex
Phoenex's Avatar
USA, IL, Champaign
Joined Jul 2005
Motor-battery combos
Just to give you guys and idea of how light the wing loading is on this plane, I will describe my setup a bit and how it flys. I have a converted EasyCub much the same as MM. The motor I am using weighs 89grams(250watts), battery 200grams with no weight added for COG. I have only flown it once on maiden flight. I took off on an asphalt runway no flaps into a 6 to 8 mph headwind. I was focused on tracking down the runway straight with my thumb ready on the rudder. I throttled up to about 1/2 to 2/3's throttle, the plane rolled out to about 6 feet the nose lifted up and it was airborne before I could even touch the rudder. I had no down thrust setup on the motor since it was shown to mount it straight on in the EasyCub manual. The plane did climb a lot and several clicks of down trim on the elevator was needed. I noticed the motor thrust line is setup differently in the FunCub manual so perhaps the climbing will be different on the FunCub. I tried out the two position flaps once I gain a bit of altitude and into the wind. I could slow down the plane to the point it almost looked like a kite just hanging into the wind. I flew it around awhile trimming the plane out a bit, checking out the power setup and then landed. Again I did not use the flaps and into a headwind. I used just a little throttle on final bringing it into the wind. The plane slowed down so much before touchdown, there was only about a 2 foot roll out.
Phoenex is offline Find More Posts by Phoenex
Old Apr 27, 2010, 10:34 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
In this case, I will order the Tuning Drive Li-Batt set for the ParkMaster 3D.
Same motor as the EasyCub set, but with the new 30A ESC (with BEC suitable for 6-7 servos), prop adapter and 3s950mAh battery.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Apr 27, 2010, 12:52 PM
blinske is offline
Find More Posts by blinske
Clintonville, WI
Joined Jun 2008
Really good news!! I just received a reply from Multiplex Customer Support that the FunCub is in stock. Checking the Tower Hobbies website, it shows them on order at $119.99 for the kit. I'm looking forward to ordering one as soon as a delivery date is established.
blinske is offline Find More Posts by blinske
Old Apr 27, 2010, 04:02 PM
PandaDixie is offline
Find More Posts by PandaDixie
Got the RC bug ;)
Tenby West Wales U.K
Joined Jan 2010
Thats good news
Hope its the same here in the U.K.
Andy
PandaDixie is offline Find More Posts by PandaDixie
Old Apr 27, 2010, 04:07 PM
Got the RC bug ;)
Joined Jan 2010
Brentford have it in stock here in the U.K
http://www.brentfordrc.co.uk/scripts...idproduct=2481
Happy days (If its true!!)
Andy
Old Apr 27, 2010, 04:13 PM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
The Modelspot ......http://www.modelspot.com/fun-cub---d...2010-738-p.asp
dekan is offline Find More Posts by dekan
Old Apr 28, 2010, 03:43 AM
benski is offline
Find More Posts by benski
USA, WA, Port Angeles
Joined Nov 2009
Yippee!"I'ma gonna hafta fetch me one-uh them, I reckon'.
benski is offline Find More Posts by benski
Old Apr 28, 2010, 04:53 AM
Joined Sep 2000
Andy
I find it hard to believe, as the FunCub isn't even available in German shops yet. I have got mine on backorder.
Jürgen
Old Apr 28, 2010, 05:24 AM
gt35r is offline
Find More Posts by gt35r
Perth, Western Australia
Joined Mar 2006
Those web site links are for pre-orders, not in stock!
gt35r is offline Find More Posts by gt35r
Old Apr 28, 2010, 05:31 AM
RichPrior is offline
Find More Posts by RichPrior
RichPrior's Avatar
Buckingham U.K
Joined Mar 2008
brentford link says its in stock.........
RichPrior is offline Find More Posts by RichPrior
Old Apr 28, 2010, 06:28 AM
Joined Sep 2000
But it also says on the same page "*** PRE-ORDER THIS BRILLIANT AIRCRAFT ***", i.e. the item is obviously not in stock yet.
Jürgen
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 05:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 10:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 10:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 11:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 12:02 PM
