Old Mar 11, 2010, 10:22 PM
nac is offline
nac
Find More Posts by nac
nac
nac's Avatar
Melbourne, Australia
Build Log
Sukhoi PAK FA - EASYBUILD
Hey Guys,
The next 6mm Depron Easybuild is here.
Depron = 6mm
Wing span = 72cm (~28”)
Length = 100cm (~39”)
SETUP :-
Static thrust = Minimum 650g
Prop = 6x4 (up to 8" possible)
Motor = 2000kv
ESC = 25A minimum
Battery = 1350mAh 3s1p 25C Li-Po
Radio = 3CH
Elevon throw = +/- 20 degrees
Expo = 40%
COG = 6cm from wing break
Features include:-
Simple thrust vectoring.
Ample expansion space for large diameter prop up to 8".
Only two servos required for elevon controls.
Possibility of adding ailerons if required.
Tabbed construction for easy alignment.
Scaleable down to 50%, still with 4.5" inch prop.
Self angled vertical stabilisers.
Battery/Electronics compartment with access hatch.
See post #20 for some build photos.
http://www.rcgroups.com/forums/showp...1&postcount=20
See PDF for change Log.
NAC
nac is offline Find More Posts by nac
Old Mar 11, 2010, 10:26 PM
ksqm is offline
Find More Posts by ksqm
United States, VA, Hampton
Joined Mar 2009
Subscribed!!! Will see how soon I can get to build. Trying to decide between 50% and 66% scale. Either way, she'll be souped up with an 1806N 2500kv motor.
Ksqm
ksqm is offline Find More Posts by ksqm
Old Mar 11, 2010, 10:28 PM
nac is offline
nac
nac
nac's Avatar
Some pics of the Sukhoi PAK FA
Some pics of the Sukhoi PAK FA.....
Old Mar 11, 2010, 10:30 PM
nac is offline
nac
nac
nac's Avatar
Ksqm
I printed out 50% on four A4 sheets just for fun. It looks like an indoor micro.
Old Mar 11, 2010, 10:40 PM
ksqm is offline
Joined Mar 2009
I did a ToxicToast F14, with Maybz tail feathers at 14.5 WS from 6mm depron. It's nice with an 1811 2000Kv motor. I see this 14" to 18" WS/6mm depron and an 1806N 2500Kv motor. It'll never fly indoors.
Ksqm
Old Mar 11, 2010, 11:16 PM
ids911 is offline
Find More Posts by ids911
ids911
ids911's Avatar
GA
Joined Jan 2009
Nick I Have a set of print outs at 100% and 50%. The 50% templates have been cutout and dry fit tested. So far all looks ok. Tabs line up, etc Will use 3mm depron for the 50% build. Thinking of using the guts of the PZ SU-26m, which will be interesting, should keep it lite, servo line up may not work though, will see
Ian
ids911 is offline Find More Posts by ids911
Old Mar 11, 2010, 11:21 PM
nac is offline
nac
nac
nac's Avatar
Perhaps try 60%. You should be able to fit a 5" prop.
Old Mar 12, 2010, 12:30 AM
grubby is offline
Find More Posts by grubby
grubby's Avatar
Denver Colorado
Joined Jan 2010
I hope someone does a cnc kit for this when it gets the bugs worked out. I can cut foam in a straight line to save my life.
I have a electronics setup with out a home.
Also have some 5in stuff as well.
grubby is offline Find More Posts by grubby
Old Mar 12, 2010, 04:42 AM
Giedi_Prime is offline
Find More Posts by Giedi_Prime
When I fly, Birds attack
Giedi_Prime's Avatar
Aveiro, Portugal
I'm just half way of cutting all the depron parts!!!
Giedi_Prime is offline Find More Posts by Giedi_Prime
Old Mar 12, 2010, 09:21 AM
Kangaman is offline
Find More Posts by Kangaman
Kangaman's Avatar
North Hollywood
Joined Jun 2006
All I can say is that you are a very bad man
Come on Aussie c'mon, c'mon...
Paul
Kangaman is offline Find More Posts by Kangaman
Old Mar 12, 2010, 12:16 PM
profilefan is online now
Find More Posts by profilefan
profilefan's Avatar
United States, NY, New Hyde Park
Joined Jun 2008
Originally Posted by nac View Post
Hey Guys,
The next 6mm Depron Easybuild is almost here.
NAC
http://nickcara.homeserver.com/NAC/welcome.html
Thanks NAC for the BETA plans, i was working on this as well but you made my life much easier.
Hope you don't mind but i shrunk your plans down to a 65% version which came out to 18.25 wingspan.
I'll post pics when i get it done, trying to decide if i should do it in EPP or 6mm depron.
-Steven
profilefan is online now Find More Posts by profilefan
Old Mar 12, 2010, 02:23 PM
nac is offline
nac
nac
nac's Avatar
-Steven
Thats fine.
Be aware that the battery compartment cover needs to be lengthened by around 5mm along with a few other changes.
BETA plans updated to V1.03.
Old Mar 14, 2010, 05:16 PM
ids911 is offline
ids911
ids911's Avatar
GA
Joined Jan 2009
Nick, one good set of plans! Almost have this one built. Now deciding on color scheme. Found this other picture of the PAK FA, think I'll do it this way.
Old Mar 14, 2010, 05:58 PM
nac is offline
nac
nac
nac's Avatar
The plans are almost good to go. I have a couple of minor changes to do. And then just need to wait for a maiden to check cg.
Old Mar 14, 2010, 07:35 PM
crxmanpat is online now
Find More Posts by crxmanpat
Foam abuser!
crxmanpat's Avatar
Mesa, AZ
Joined Jan 2006
Ksqm
Subscribed as well. I would go to 66% with the 1806N motor.
Pat
crxmanpat is online now Find More Posts by crxmanpat
Discussion RCPowers F-22 EasyBuild Parkjet- Pix & Flight Report GrouchoN38KF Pusher Prop Jet Models 1 Feb 23, 2011 08:56 PM
Discussion Sukhoi PAK T-50 makes its first flight! Tumbler Electric Ducted Fan Jet Talk 10 Feb 01, 2010 02:42 AM
Discussion Anyone Have a PAK FA T-50 3-View? yellow13 Foamies (Scratchbuilt) 2 Jan 31, 2010 06:06 PM
Discussion PAK FA Russian fighter video CaptDH Pusher Prop Jet Models 2 Jan 29, 2010 11:17 PM
