Old Mar 11, 2010, 02:25 PM
TipStalled is offline
Find More Posts by TipStalled
Mark 12:30
TipStalled's Avatar
United States, GA, Alpharetta
Joined Jan 2004
Anyone using these ? Looking for some feedback. I presently have a PolyQuest 4 port charger and 2 Thunder Power Balancers. It seems one of my balancers is going bad...at least they both have different indications on the same battery. I don't have a ton-o-bucks and was thinking about getting 2 of these balancers as replacements.
http://www.hobbyking.com/hobbyking/s...duct=7443&pb=1
From what I can gather, these things are MAINLY balancers.....however...using the supplied inputs/outputs on the balancer you can also balance/charge at the same time...is this true ?
Thanks !
TipStalled is offline Find More Posts by TipStalled
Old Mar 11, 2010, 03:32 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
The link you provide is a CHARGE THREW BALANCER. They exist menu brand, I use a FLightPower V-Balancer and it works great.
I also carry it with me to the field so I can check my pack after I land.
freechip is offline Find More Posts by freechip
Old Mar 11, 2010, 03:36 PM
tino_ale is offline
Find More Posts by tino_ale
France
Joined Mar 2008
Smart title
tino_ale is offline Find More Posts by tino_ale
Old Mar 11, 2010, 03:54 PM
Mark 12:30
TipStalled's Avatar
Joined Jan 2004
Originally Posted by tino_ale View Post
Smart title
Fixed it...
Old Mar 11, 2010, 05:24 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
here is the manual for it. it is a balancer only. You still need a charger to charge the packs while it does the balancing.
http://www.promatchracing.com/B6plus.pdf
earlwb is offline Find More Posts by earlwb
Old Mar 11, 2010, 06:11 PM
Mark 12:30
TipStalled's Avatar
Joined Jan 2004
Thanks, I did find the manual online but the diagrams have me confused !
The confusing parts is when charge/balancing more than 1 pack per CC7 board...I completely get the use as a charge balancer with one pack per CC7 board. It would appear that in order to use this as a charge balancer for MULTIPLE PACKS per CC7 board you must use the + and - outputs on the B6Plus on seperate packs to the CC7 board. This could be somewhat daunting using Deans plugs as I do...however...if using bullet connectors it is a snap !
So the question.....if using it charge balancing for multiple packs do you, in essence, hook up your packs in series with the + and - outputs on the B6Plus ?
Can you hook up multiple packs to the CC7 board and use multiple inputs from another charger to charge the packs ? I would think the answer is no....but that is why I have it posted.
Discussion http://www.tdlmodels.com/ sebbe Vendor Talk 2 Mar 01, 2010 04:21 PM
Discussion http://www.cyclonetoy.com/index_1.asp jperales_88 Vendor Talk 2 Feb 17, 2008 02:53 PM
Discussion http://www.cyclonetoy.com/index_1.asp jperales_88 Mini Helis 0 Feb 16, 2008 10:22 AM
Discussion [img]http://www.radrowdies.com/vt/asp/Affil-0/itemcat-boys/BO_ID-726/Desc_ID-1/tv/gfx j bolt Sport Planes 0 Nov 27, 2007 07:10 PM
